68.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:48:41 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:48:41 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:48:41 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:48:43 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 14:48:43 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:48:43 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.796508830-05:00" level=info msg="Starting up"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.799646981-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.799710796-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.799772666-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.799798960-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.802687332-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.802792708-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.802885239-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.802946131-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.874396966-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.885731203-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.885799859-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.885822805-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.885840405-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.886321630-05:00" level=info msg="Loading containers: start."
Nov 18 14:48:43 dockerd[3511]: time="2020-11-18T14:48:43.977725241-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:48:43 dockerd[3511]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:48:43 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:48:43 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:48:43 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:48:46 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 14:48:46 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:48:46 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 14:48:46 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:48:46 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:54:36 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.946333046-05:00" level=info msg="Starting up"
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.949870808-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.949938000-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.949996584-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.950028937-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.952355029-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.952423105-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.952480745-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:36 dockerd[4340]: time="2020-11-18T14:54:36.952528170-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.075464826-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.082813732-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.082876204-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.082908459-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.082938654-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.083627698-05:00" level=info msg="Loading containers: start."
Nov 18 14:54:37 dockerd[4340]: time="2020-11-18T14:54:37.181532216-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:54:37 dockerd[4340]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:54:37 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:54:37 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:54:37 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:54:39 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 14:54:39 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:54:39 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.344833153-05:00" level=info msg="Starting up"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.347652892-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.347720655-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.347772805-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.347809493-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.352084905-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.352189560-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.352300876-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.352360576-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.443737972-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.450580439-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.450664183-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.450696758-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.450735983-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.451280968-05:00" level=info msg="Loading containers: start."
Nov 18 14:54:39 dockerd[4394]: time="2020-11-18T14:54:39.542336889-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:54:39 dockerd[4394]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:54:39 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:54:39 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:54:39 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:54:41 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 14:54:41 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:54:41 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.827999430-05:00" level=info msg="Starting up"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.831372749-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.831440707-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.831491188-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.831526896-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.833852141-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.833918195-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.834019496-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.834059382-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.912797115-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.919661389-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.919720147-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.919747930-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.919772879-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:54:41 dockerd[4447]: time="2020-11-18T14:54:41.920325636-05:00" level=info msg="Loading containers: start."
Nov 18 14:54:42 dockerd[4447]: time="2020-11-18T14:54:42.010850431-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:54:42 dockerd[4447]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:54:42 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:54:42 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:54:42 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:54:44 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 14:54:44 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:54:44 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 14:54:44 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:54:44 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:59:49 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.787962435-05:00" level=info msg="Starting up"
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.791307991-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.791398009-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.791503555-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.791561169-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.794152785-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.794220506-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.794297135-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:49 dockerd[5483]: time="2020-11-18T14:59:49.794338838-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.315312661-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.334346517-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.334426018-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.334451025-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.334471707-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.334988894-05:00" level=info msg="Loading containers: start."
Nov 18 14:59:51 dockerd[5483]: time="2020-11-18T14:59:51.429961368-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:59:51 dockerd[5483]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:59:51 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:59:51 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:59:51 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:59:53 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 14:59:53 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:59:53 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.596780156-05:00" level=info msg="Starting up"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.599605424-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.599673862-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.599746882-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.599780011-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.602266054-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.602328157-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.602381018-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.602410799-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.687046338-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.694677359-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.694730138-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.694750937-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.694766795-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.695173322-05:00" level=info msg="Loading containers: start."
Nov 18 14:59:53 dockerd[5540]: time="2020-11-18T14:59:53.786550421-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:59:53 dockerd[5540]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:59:53 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:59:53 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:59:53 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:59:55 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 14:59:55 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:59:55 systemd[1]: Starting Docker Application Container Engine...
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.095466265-05:00" level=info msg="Starting up"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.098973096-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.099060559-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.099136324-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.099186028-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.101614114-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.101677017-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.101719900-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.101757392-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.177752145-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.188851041-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.188933814-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.188967887-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.188996943-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.189635739-05:00" level=info msg="Loading containers: start."
Nov 18 14:59:56 dockerd[5591]: time="2020-11-18T14:59:56.283269681-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 14:59:56 dockerd[5591]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 14:59:56 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 14:59:56 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:59:56 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 14:59:58 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 14:59:58 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 14:59:58 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 14:59:58 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 14:59:58 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:00:01 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.149801941-05:00" level=info msg="Starting up"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.153057837-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.153117992-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.153188565-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.153255568-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.156780505-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.157182770-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.157579624-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.157847746-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.244920904-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.252694552-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.252750273-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.252782692-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.252813141-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.253532539-05:00" level=info msg="Loading containers: start."
Nov 18 15:00:01 dockerd[5676]: time="2020-11-18T15:00:01.348736129-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:00:01 dockerd[5676]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:00:01 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:00:01 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:00:01 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:00:03 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 15:00:03 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:00:03 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.598553223-05:00" level=info msg="Starting up"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.601281275-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.601345700-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.601414183-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.601442248-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.603900004-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.604019603-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.604076271-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.604128365-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.698576686-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.705573307-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.705656096-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.705690696-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.705712952-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.706206518-05:00" level=info msg="Loading containers: start."
Nov 18 15:00:03 dockerd[5729]: time="2020-11-18T15:00:03.816549152-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:00:03 dockerd[5729]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:00:03 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:00:03 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:00:03 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:00:05 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 15:00:05 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:00:05 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.095708124-05:00" level=info msg="Starting up"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.099228191-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.099311623-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.099386517-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.099424228-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.101807224-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.101889048-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.101933247-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.101957776-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.163802974-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.171162639-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.171209353-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.171228967-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.171244331-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.171651489-05:00" level=info msg="Loading containers: start."
Nov 18 15:00:06 dockerd[5780]: time="2020-11-18T15:00:06.260218175-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:00:06 dockerd[5780]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:00:06 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:00:06 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:00:06 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:00:08 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 15:00:08 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:00:08 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 15:00:08 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:00:08 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:05:40 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.332089576-05:00" level=info msg="Starting up"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.334619680-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.334675746-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.334725214-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.334754037-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.336522528-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.336586151-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.336621684-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.336641542-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.388249662-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.394578743-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.394633090-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.394655226-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.394672844-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.395089222-05:00" level=info msg="Loading containers: start."
Nov 18 15:05:40 dockerd[6831]: time="2020-11-18T15:05:40.492871939-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:05:40 dockerd[6831]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:05:40 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:05:40 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:05:40 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:05:42 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 15:05:42 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:05:42 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.846672867-05:00" level=info msg="Starting up"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.849775831-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.849846815-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.849897155-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.849930079-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.852396027-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.852473493-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.852514331-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.852552830-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.926190415-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.933487128-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.933548232-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.933570545-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.933587815-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:05:42 dockerd[6882]: time="2020-11-18T15:05:42.934133838-05:00" level=info msg="Loading containers: start."
Nov 18 15:05:43 dockerd[6882]: time="2020-11-18T15:05:43.024211359-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:05:43 dockerd[6882]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:05:43 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:05:43 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:05:43 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:05:45 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 15:05:45 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:05:45 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.343198165-05:00" level=info msg="Starting up"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.346643250-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.346731227-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.346800566-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.346850726-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.350735211-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.351135835-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.351495533-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.351793119-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.427397688-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.435877227-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.435930920-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.435953984-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.435972217-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.436474551-05:00" level=info msg="Loading containers: start."
Nov 18 15:05:45 dockerd[6943]: time="2020-11-18T15:05:45.525956170-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:05:45 dockerd[6943]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:05:45 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:05:45 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:05:45 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:05:47 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 15:05:47 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:05:47 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 15:05:47 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:05:47 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:05:58 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.027809680-05:00" level=info msg="Starting up"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.032060343-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.032150159-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.032209289-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.032273400-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.035021303-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.035105335-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.035171876-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.035213509-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.146506671-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.155892306-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.155958909-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.155982218-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.155999651-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.156502376-05:00" level=info msg="Loading containers: start."
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.251163780-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:05:59 dockerd[7061]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:05:59 dockerd[7061]: time="2020-11-18T15:05:59.252095072-05:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Nov 18 15:05:59 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:05:59 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:05:59 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:06:01 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 15:06:01 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:06:01 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.594413581-05:00" level=info msg="Starting up"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.597555541-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.597636211-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.597739837-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.597777632-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.603722569-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.604172263-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.604545078-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.604855358-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.702270780-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.710260750-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.710313817-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.710335967-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.710354193-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.710848438-05:00" level=info msg="Loading containers: start."
Nov 18 15:06:01 dockerd[7113]: time="2020-11-18T15:06:01.802455347-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:06:01 dockerd[7113]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:06:01 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:06:01 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:06:01 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:06:03 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 15:06:03 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:06:03 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.093442203-05:00" level=info msg="Starting up"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.096597728-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.096659379-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.096706999-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.096741310-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.099211272-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.099266129-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.099304342-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.099327761-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.168687992-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.177845529-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.177916292-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.177938784-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.177956445-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.178475375-05:00" level=info msg="Loading containers: start."
Nov 18 15:06:04 dockerd[7167]: time="2020-11-18T15:06:04.268866816-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:06:04 dockerd[7167]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:06:04 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:06:04 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:06:04 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:06:06 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 15:06:06 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:06:06 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 15:06:06 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:06:06 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:08:06 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.040394669-05:00" level=info msg="Starting up"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.041842673-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.041872834-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.041896486-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.041913869-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.042986684-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.043017777-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.043036808-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.043052097-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.080124411-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.085548881-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.085573487-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.085582800-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.085590190-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.085793015-05:00" level=info msg="Loading containers: start."
Nov 18 15:08:07 dockerd[7895]: time="2020-11-18T15:08:07.155098721-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:08:07 dockerd[7895]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:08:07 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:08:07 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:08:07 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:08:09 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 15:08:09 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:08:09 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.346419104-05:00" level=info msg="Starting up"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.349885638-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.349970376-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.350044639-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.350079162-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.352417835-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.352470821-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.352527539-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.352592176-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.430256422-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.436940938-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.437002989-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.437024971-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.437043346-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.437503009-05:00" level=info msg="Loading containers: start."
Nov 18 15:08:09 dockerd[7987]: time="2020-11-18T15:08:09.532443078-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:08:09 dockerd[7987]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:08:09 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:08:09 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:08:09 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:08:11 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 15:08:11 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:08:11 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.806872949-05:00" level=info msg="Starting up"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.809736866-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.809786744-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.809834065-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.809865218-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.812363677-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.812423068-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.812462408-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.812499947-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.885029999-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.891271229-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.891327120-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.891348116-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.891365453-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.891809854-05:00" level=info msg="Loading containers: start."
Nov 18 15:08:11 dockerd[8037]: time="2020-11-18T15:08:11.983302356-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:08:11 dockerd[8037]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:08:11 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:08:11 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:08:11 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:08:14 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 15:08:14 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:08:14 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 15:08:14 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:08:14 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:13:51 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.768414924-05:00" level=info msg="Starting up"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.771811852-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.771881433-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.771961772-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.772005695-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.775685190-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.775810814-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.775879406-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.775963551-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.852665350-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.859724260-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.859798403-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.859820075-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.859837003-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.860296177-05:00" level=info msg="Loading containers: start."
Nov 18 15:13:51 dockerd[9315]: time="2020-11-18T15:13:51.968051389-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:13:51 dockerd[9315]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:13:51 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:13:51 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:13:51 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:13:54 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 15:13:54 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:13:54 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.347886132-05:00" level=info msg="Starting up"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.350846221-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.350896676-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.350944179-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.350979688-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.353347056-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.353406670-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.353468312-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.353518139-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.460333595-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.467828147-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.467886227-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.467917340-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.467947835-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.468553393-05:00" level=info msg="Loading containers: start."
Nov 18 15:13:54 dockerd[9411]: time="2020-11-18T15:13:54.572693811-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:13:54 dockerd[9411]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:13:54 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:13:54 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:13:54 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:13:56 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 15:13:56 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:13:56 systemd[1]: Starting Docker Application Container Engine...
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.844840953-05:00" level=info msg="Starting up"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.848230981-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.848323766-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.848376191-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.848422950-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.850905889-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.850982245-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.851074057-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.851115482-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.957721769-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.966268748-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.966322584-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.966343826-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.966360765-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 15:13:56 dockerd[9466]: time="2020-11-18T15:13:56.966874683-05:00" level=info msg="Loading containers: start."
Nov 18 15:13:57 dockerd[9466]: time="2020-11-18T15:13:57.065449034-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 15:13:57 dockerd[9466]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 15:13:57 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 15:13:57 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:13:57 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 15:13:59 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 15:13:59 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 15:13:59 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 15:13:59 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 15:13:59 systemd[1]: Failed to start Docker Application Container Engine.
-- Reboot --
Nov 18 16:34:38 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.451631223-05:00" level=info msg="Starting up"
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.551083134-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.551144129-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.551196498-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.551222810-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.554760074-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.554824822-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.554885476-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:38 dockerd[5463]: time="2020-11-18T16:34:38.554928326-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.170529374-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.211249008-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.211324610-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.211346305-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.211363558-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.211885887-05:00" level=info msg="Loading containers: start."
Nov 18 16:34:40 dockerd[5463]: time="2020-11-18T16:34:40.491586085-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:34:40 dockerd[5463]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:34:40 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:34:40 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:34:40 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:34:42 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 16:34:42 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:34:42 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.666515172-05:00" level=info msg="Starting up"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.669806255-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.669909248-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.670021650-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.670067398-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.672524602-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.672578664-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.672619963-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.672646714-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.791577349-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.804830240-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.804892585-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.804914833-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.804932738-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.805382403-05:00" level=info msg="Loading containers: start."
Nov 18 16:34:42 dockerd[5530]: time="2020-11-18T16:34:42.897689830-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:34:42 dockerd[5530]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:34:42 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:34:42 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:34:42 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:34:45 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 16:34:45 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:34:45 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.181950654-05:00" level=info msg="Starting up"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.185201137-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.185279729-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.185350560-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.185390504-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.190391758-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.190454401-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.190498381-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.190525311-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.365763666-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.377841878-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.377910669-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.377933754-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.377951820-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.378373370-05:00" level=info msg="Loading containers: start."
Nov 18 16:34:45 dockerd[5582]: time="2020-11-18T16:34:45.473331213-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:34:45 dockerd[5582]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:34:45 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:34:45 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:34:45 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:34:47 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 16:34:47 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:34:47 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 16:34:47 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:34:47 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:40:37 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.429046673-05:00" level=info msg="Starting up"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.432597675-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.432664394-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.432730804-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.432771768-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.435222607-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.435306029-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.435371637-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.435410087-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.571267805-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.577676437-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.577729439-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.577752843-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.577771214-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.578241839-05:00" level=info msg="Loading containers: start."
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.671081276-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:40:37 dockerd[6370]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:40:37 dockerd[6370]: time="2020-11-18T16:40:37.671964058-05:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Nov 18 16:40:37 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:40:37 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:40:37 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:40:39 systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Nov 18 16:40:39 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:40:39 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.917124811-05:00" level=info msg="Starting up"
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.920393956-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.920469326-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.920520477-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.920545662-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.922936585-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.923004454-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.923101584-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:39 dockerd[6421]: time="2020-11-18T16:40:39.923189688-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.027495112-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.035421303-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.035476840-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.035498573-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.035515120-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.035956338-05:00" level=info msg="Loading containers: start."
Nov 18 16:40:40 dockerd[6421]: time="2020-11-18T16:40:40.126955772-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:40:40 dockerd[6421]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:40:40 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:40:40 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:40:40 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:40:42 systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Nov 18 16:40:42 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:40:42 systemd[1]: Starting Docker Application Container Engine...
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.438125449-05:00" level=info msg="Starting up"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.441494091-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.441586363-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.441647044-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.441680163-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.444111531-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.444161869-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.444201517-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.444240506-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.525341192-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.532242839-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.532308506-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.532337502-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.532362244-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.532945173-05:00" level=info msg="Loading containers: start."
Nov 18 16:40:42 dockerd[6477]: time="2020-11-18T16:40:42.622905379-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 16:40:42 dockerd[6477]: failed to start daemon: Error initializing network controller: list bridge addresses failed: PredefinedLocalScopeDefaultNetworks List: [172.17.0.0/16 172.18.0.0/16 172.19.0.0/16 172.20.0.0/16 172.21.0.0/16 172.22.0.0/16 172.23.0.0/16 172.24.0.0/16 172.25.0.0/16 172.26.0.0/16 172.27.0.0/16 172.28.0.0/16 172.29.0.0/16 172.30.0.0/16 172.31.0.0/16 192.168.0.0/20 192.168.16.0/20 192.168.32.0/20 192.168.48.0/20 192.168.64.0/20 192.168.80.0/20 192.168.96.0/20 192.168.112.0/20 192.168.128.0/20 192.168.144.0/20 192.168.160.0/20 192.168.176.0/20 192.168.192.0/20 192.168.208.0/20 192.168.224.0/20 192.168.240.0/20]: no available network
Nov 18 16:40:42 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 16:40:42 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:40:42 systemd[1]: Failed to start Docker Application Container Engine.
Nov 18 16:40:44 systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 18 16:40:44 systemd[1]: Stopped Docker Application Container Engine.
Nov 18 16:40:44 systemd[1]: docker.service: Start request repeated too quickly.
Nov 18 16:40:44 systemd[1]: docker.service: Failed with result 'exit-code'.
Nov 18 16:40:44 systemd[1]: Failed to start Docker Application Container Engine.
-- Reboot --
Nov 18 18:27:00 systemd[1]: Starting Docker Application Container Engine...
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.714926779-05:00" level=info msg="Starting up"
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.809763605-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.809818943-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.809866864-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.809896050-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.817890227-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.817924008-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.817956077-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 18 18:27:00 dockerd[943]: time="2020-11-18T18:27:00.817974007-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.018448741-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.045700284-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.045767945-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.045788045-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.045803471-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.046294972-05:00" level=info msg="Loading containers: start."
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.308901710-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.415308244-05:00" level=info msg="Loading containers: done."
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.630132990-05:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.630676743-05:00" level=info msg="Docker daemon" commit=4484c46d9d graphdriver(s)=overlay2 version=19.03.13-ce
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.632084890-05:00" level=info msg="Daemon has completed initialization"
Nov 18 18:27:01 dockerd[943]: time="2020-11-18T18:27:01.719801666-05:00" level=info msg="API listen on /run/docker.sock"
Nov 18 18:27:01 systemd[1]: Started Docker Application Container Engine.
Nov 18 18:33:15 dockerd[943]: time="2020-11-18T18:33:15.255752483-05:00" level=info msg="Processing signal 'terminated'"
Nov 18 18:33:15 systemd[1]: Stopping Docker Application Container Engine...
Nov 18 18:33:15 dockerd[943]: time="2020-11-18T18:33:15.257407709-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 18 18:33:15 dockerd[943]: time="2020-11-18T18:33:15.258161438-05:00" level=info msg="Daemon shutdown complete"
Nov 18 18:33:15 dockerd[943]: time="2020-11-18T18:33:15.258181619-05:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Nov 18 18:33:15 systemd[1]: docker.service: Succeeded.
Nov 18 18:33:15 systemd[1]: Stopped Docker Application Container Engine.
-- Reboot --
Nov 19 07:48:39 systemd[1]: Starting Docker Application Container Engine...
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.518701003-05:00" level=info msg="Starting up"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.612286904-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.612319883-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.612348600-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.612367231-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.621224281-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.621261565-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.621284315-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.621314310-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.834404521-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.859849613-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.859919163-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.859939466-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.859956041-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 19 07:48:40 dockerd[964]: time="2020-11-19T07:48:40.862819230-05:00" level=info msg="Loading containers: start."
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.276570944-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.368918470-05:00" level=info msg="Loading containers: done."
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.584471515-05:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.585030705-05:00" level=info msg="Docker daemon" commit=4484c46d9d graphdriver(s)=overlay2 version=19.03.13-ce
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.586920943-05:00" level=info msg="Daemon has completed initialization"
Nov 19 07:48:41 systemd[1]: Started Docker Application Container Engine.
Nov 19 07:48:41 dockerd[964]: time="2020-11-19T07:48:41.653990970-05:00" level=info msg="API listen on /run/docker.sock"
Nov 19 13:38:22 dockerd[964]: time="2020-11-19T13:38:22.615372889-05:00" level=info msg="Processing signal 'terminated'"
Nov 19 13:38:22 dockerd[964]: time="2020-11-19T13:38:22.616919086-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 19 13:38:22 dockerd[964]: time="2020-11-19T13:38:22.617512648-05:00" level=info msg="Daemon shutdown complete"
Nov 19 13:38:22 dockerd[964]: time="2020-11-19T13:38:22.617573049-05:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Nov 19 13:38:22 systemd[1]: Stopping Docker Application Container Engine...
Nov 19 13:38:22 systemd[1]: docker.service: Succeeded.
Nov 19 13:38:22 systemd[1]: Stopped Docker Application Container Engine.
-- Reboot --
Nov 19 13:39:12 systemd[1]: Starting Docker Application Container Engine...
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.601827557-05:00" level=info msg="Starting up"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.677187232-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.677238974-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.677307069-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.677338110-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.686222582-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.686263000-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.686300668-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.686325108-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.892901417-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.917752472-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.917821336-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.917842480-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.917858905-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 19 13:39:13 dockerd[927]: time="2020-11-19T13:39:13.918348985-05:00" level=info msg="Loading containers: start."
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.328261272-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.411933978-05:00" level=info msg="Loading containers: done."
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.623112941-05:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.623823576-05:00" level=info msg="Docker daemon" commit=4484c46d9d graphdriver(s)=overlay2 version=19.03.13-ce
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.625840332-05:00" level=info msg="Daemon has completed initialization"
Nov 19 13:39:14 dockerd[927]: time="2020-11-19T13:39:14.688125522-05:00" level=info msg="API listen on /run/docker.sock"
Nov 19 13:39:14 systemd[1]: Started Docker Application Container Engine.
Nov 19 17:09:56 dockerd[927]: time="2020-11-19T17:09:56.292258735-05:00" level=info msg="Processing signal 'terminated'"
Nov 19 17:09:56 systemd[1]: Stopping Docker Application Container Engine...
Nov 19 17:09:56 dockerd[927]: time="2020-11-19T17:09:56.294201224-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 19 17:09:56 dockerd[927]: time="2020-11-19T17:09:56.295124157-05:00" level=info msg="Daemon shutdown complete"
Nov 19 17:09:56 systemd[1]: docker.service: Succeeded.
Nov 19 17:09:56 systemd[1]: Stopped Docker Application Container Engine.
-- Reboot --
Nov 19 21:11:58 systemd[1]: Starting Docker Application Container Engine...
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.568176773-05:00" level=info msg="Starting up"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.638907962-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.638960391-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.638996232-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.639020024-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.646800623-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.646832296-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.646859798-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.646874464-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.865135566-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.890149963-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.890220393-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.890255993-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.890282234-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 19 21:11:59 dockerd[940]: time="2020-11-19T21:11:59.891074381-05:00" level=info msg="Loading containers: start."
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.297494651-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.383282344-05:00" level=info msg="Loading containers: done."
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.597464994-05:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.598032693-05:00" level=info msg="Docker daemon" commit=4484c46d9d graphdriver(s)=overlay2 version=19.03.13-ce
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.600013761-05:00" level=info msg="Daemon has completed initialization"
Nov 19 21:12:00 dockerd[940]: time="2020-11-19T21:12:00.669850837-05:00" level=info msg="API listen on /run/docker.sock"
Nov 19 21:12:00 systemd[1]: Started Docker Application Container Engine.
Nov 19 22:43:05 systemd[1]: Stopping Docker Application Container Engine...
Nov 19 22:43:05 dockerd[940]: time="2020-11-19T22:43:05.771372555-05:00" level=info msg="Processing signal 'terminated'"
Nov 19 22:43:05 dockerd[940]: time="2020-11-19T22:43:05.772160991-05:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Nov 19 22:43:05 dockerd[940]: time="2020-11-19T22:43:05.772450675-05:00" level=info msg="Daemon shutdown complete"
Nov 19 22:43:05 systemd[1]: docker.service: Succeeded.
Nov 19 22:43:05 systemd[1]: Stopped Docker Application Container Engine.
-- Reboot --
Nov 20 07:51:17 systemd[1]: Starting Docker Application Container Engine...
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.559443930-05:00" level=info msg="Starting up"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.655785755-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.655821407-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.655858447-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.655879354-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.665726023-05:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.665754629-05:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.665780689-05:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 <nil>}] <nil>}" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.665801260-05:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.891596483-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.913415929-05:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.913479111-05:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.913501737-05:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.913519750-05:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 20 07:51:18 dockerd[969]: time="2020-11-20T07:51:18.914071655-05:00" level=info msg="Loading containers: start."
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.199761016-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.303056771-05:00" level=info msg="Loading containers: done."
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.530592251-05:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.531201765-05:00" level=info msg="Docker daemon" commit=4484c46d9d graphdriver(s)=overlay2 version=19.03.13-ce
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.533252457-05:00" level=info msg="Daemon has completed initialization"
Nov 20 07:51:19 systemd[1]: Started Docker Application Container Engine.
Nov 20 07:51:19 dockerd[969]: time="2020-11-20T07:51:19.603278172-05:00" level=info msg="API listen on /run/docker.sock"
