Ive installed docker and pulled down nextcloud. Im trying to get a minimal copy running so i can see if it serves my purposes.
So im running the command:
sudo docker run -d -p 8080:80 --name nextcloud -v config:/var/www/html/config -v data:/var/www/html/data nextcloud
It starts fine, but it does not create the config or data folders on my system. I have no /var/www/ folder… Do I need to create these manually, or should the docker image create them for me?
Hope it helps, regards. I could not say anymore about the command line instructions, that is what I use to run docker on Openmediavault in a virtual machine.
