Docker is no longer accessible without creating a symlink from /run/docker.sock to /var/run/docker.sock
That makes no sense at all because /var/run
is just a link to /run
$ ls -l /var/run
lrwxrwxrwx 1 root root 6 Sep 3 18:14 /var/run -> ../run
Whatever problem you’re having is far more likely to be related to permissions. Try “docker.sock permissions” in your favourite search engine.
For me, this is not the case
sudo ls -l /var/run
total 24
-rw-r--r-- 1 root root 5 Sep 19 11:42 crond.pid
---------- 1 root root 0 Sep 19 11:18 cron.reboot
drwx------ 7 root root 4096 Sep 19 11:43 docker
-rw-r--r-- 1 root root 4 Sep 19 11:43 docker.pid
lrwxrwxrwx 1 root root 16 Sep 19 11:58 docker.sock -> /run/docker.sock
drwxr-xr-x 3 root root 4096 Sep 19 11:19 expressvpn
drwxr-xr-x 2 root $MYUSER 4096 Sep 19 11:16 faillock
drwxr-xr-x 4 root root 4096 Sep 19 11:42 NetworkManager
I also tried purging and reinstalling/reconfiguring docker from scratch. Happy to provide other logs as needed, but I don’t believe I have made changes that would result in an actual directory here instead of the symlink like you describe
You must have, because Manjaro sets up /var/run
as a symlink to /run
. This is the upstream default — i.e. from Arch, and from systemd
itself as their upstream.
Strange. Thanks for the comments. I ended up being able to solve this by:
- Stop/Disable/Remove Docker
- Reboot
sudo rm -rf /var/run
- Reboot.
/var/run
is now a symlink again
ls -al /var/run
lrwxrwxrwx 1 root root 6 Sep 19 14:04 /var/run -> ../run
- Reinstall/start/enable Docker. docker.sock is now in
/run
and docker commands for thedocker
group run correctly again.
