So I’ve been facing an issue whenever I tried to docker build
or docker compose
with installing packages or trying to ping from inside the container
My solution for the time being was running docker build image-name --network=host
to properly build my images.
After a week from searching and going through stack-overflow and arch wiki i came upon a solution which I will post below.
Here are the following specs for docker and IpTables
Docker:
Docker version 20.10.17, build 100c70180f
IPTables:
iptables v1.8.8 (nf_tables)
First check your cat /etc/docker/daemon.json
I got the following output
{"iptables": false}
And my iptables -L -n
showed the following output
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
Chain OUTPUT (policy ACCEPT)
If you got the same issue continue with the steps
Delete the file sudo rm /etc/docker/daemon.json
Restart docker daemon sudo systemctl restart docker.service
Just to be safe I also restarted the dock.socket sudo systemctl restart docker.socket
After these changes the iptables -L -n
Output
Chain FORWARD (policy ACCEPT)
DOCKER-USER all -- 0.0.0.0/0 0.0.0.0/0
DOCKER-ISOLATION-STAGE-1 all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
DOCKER all -- 0.0.0.0/0 0.0.0.0/0
Chain DOCKER (6 references)
ACCEPT tcp -- 0.0.0.0/0 172.22.0.2 tcp dpt:3000
ACCEPT tcp -- 0.0.0.0/0 172.22.0.3 tcp dpt:80
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- 0.0.0.0/0 0.0.0.0/0
RETURN all -- 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (6 references)
DROP all -- 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-USER (1 references)
And after that I was able to use docker like before.
Solution was taken from this stackoverflow thread
Stackoverflow solution
Hope this helps someone else as well.
system
Closed
9 July 2022 21:13
3
