Just posting a fix for others.
If you install docker on manjaro arm (in my case mate for rockpro64) then you might be missing apparmor. When you then try to spin up a container you’ll get this error
Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: unable to apply apparmor profile: apparmor failed to apply profile: write /proc/self/attr/apparmor/exec: no such file or directory: unknown
at the github issue link below the solution was found and is simply to install the missing apparmor package and reboot.
opened 09:53AM - 06 Feb 21 UTC
closed 07:35AM - 16 Feb 21 UTC
* [x] This is a bug report
* [ ] This is a feature request
* [x] I searched… existing issues before opening this one
### Expected behavior
docker run should be able to run the container
### Actual behavior
Running` docker run hello-world` gives this error
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: apply apparmor profile: apparmor failed to apply profile: write /proc/self/attr/exec: invalid argument: unknown.
ERRO[0001] error waiting for container: context canceled
I Installed docker using pacman package manager in manjaro.
**Output of `docker version` :**
Client:
Version: 20.10.3
API version: 1.41
Go version: go1.15.7
Git commit: 48d30b5b32
Built: Tue Feb 2 02:34:18 2021
OS/Arch: linux/amd64
Context: default
Experimental: true
Server:
Engine:
Version: 20.10.3
API version: 1.41 (minimum version 1.12)
Git commit: 46229ca1d8
Built: Tue Feb 2 02:33:45 2021
Experimental: false
containerd:
Version: v1.4.3
GitCommit: 269548fa27e0089a8b8278fc4fc781d7f65a939b.m
runc:
Version: 1.0.0-rc93
GitCommit: 12644e614e25b05da6fd08a38ffa0cfe1903fdec
docker-init:
Version: 0.19.0
GitCommit: de40ad0
**Output of `docker info` :**
Client:
Context: default
Debug Mode: false
Plugins:
app: Docker App (Docker Inc., v0.9.1-beta3)
buildx: Build with BuildKit (Docker Inc., v0.5.1-tp-docker)
Server:
Containers: 7
Running: 0
Paused: 0
Stopped: 7
Images: 1
Server Version: 20.10.3
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 io.containerd.runtime.v1.linux runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 269548fa27e0089a8b8278fc4fc781d7f65a939b.m
runc version: 12644e614e25b05da6fd08a38ffa0cfe1903fdec
init version: de40ad0
Security Options:
apparmor
seccomp
Profile: default
Kernel Version: 5.10.13-1-MANJARO
OSType: linux
Architecture: x86_64
CPUs: 8
Total Memory: 7.628GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: No blkio weight support
WARNING: No blkio weight_device support
