Hello everyone,
I just installed docker - I can’t start it via “systemctl start docker”.
Error message:
Job for docker.service failed because the control process exited with error code.
Relevant output jornalctl -xe:
> Sep 27 17:30:44 kkkkkkLaptop dbus-daemon[696]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.1397' (uid=0 pid=37335 comm="sudo systemctl start docker " label="unconfined")
Sep 27 17:30:44 kkkkkkLaptop dbus-daemon[696]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Sep 27 17:30:44 kkkkkkLaptop sudo[37335]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Sep 27 17:30:44 kkkkkkLaptop audit[37335]: USER_ACCT pid=37335 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="kkkkkk" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop audit[37335]: CRED_REFR pid=37335 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop sudo[37335]: kkkkkk : TTY=pts/2 ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl start docker
Sep 27 17:30:44 kkkkkkLaptop sudo[37335]: pam_unix(sudo:session): session opened for user root(uid=0) by kkkkkk(uid=0)
Sep 27 17:30:44 kkkkkkLaptop kernel: audit: type=1101 audit(1601220644.950:411): pid=37335 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="kkkkkk" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop kernel: audit: type=1110 audit(1601220644.950:412): pid=37335 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop kernel: audit: type=1105 audit(1601220644.950:413): pid=37335 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop audit[37335]: USER_START pid=37335 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Failed to create compat systemd cgroup /system.slice/docker.socket: Read-only file system
Sep 27 17:30:44 kkkkkkLaptop systemd[37339]: Failed to attach 37339 to compat systemd cgroup /system.slice/docker.socket: No such file or directory
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Starting Docker Socket for the API.
░░ Subject: A start job for unit docker.socket has begun execution
░░ Defined-By: systemd
░░ A start job for unit docker.socket has begun execution.
░░ The job identifier is 4751.
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Listening on Docker Socket for the API.
░░ Subject: A start job for unit docker.socket has finished successfully
░░ A start job for unit docker.socket has finished successfully.
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Failed to create compat systemd cgroup /system.slice/docker.service: Read-only file system
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Failed to attach 37340 to compat systemd cgroup /system.slice/docker.service: No such file or directory
Sep 27 17:30:44 kkkkkkLaptop systemd[37340]: Failed to attach 37340 to compat systemd cgroup /system.slice/docker.service: No such file or directory
Sep 27 17:30:44 kkkkkkLaptop systemd[1]: Starting Docker Application Container Engine...
░░ Subject: A start job for unit docker.service has begun execution
░░ A start job for unit docker.service has begun execution.
░░ The job identifier is 4673.
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.147266179+02:00" level=info msg="Starting up"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.150879453+02:00" level=info msg="libcontainerd: started new containerd process" pid=37353
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.151038444+02:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.151089167+02:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.151189418+02:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.151269732+02:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.220501227+02:00" level=info msg="starting containerd" revision=84aacd583ae0c99739b9a736cbfad37f1a6aa37f version=v1.4.0-110-g84aacd58
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.331305719+02:00" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." type=io.containerd.content.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.331530464+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.aufs\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.331638786+02:00" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.aufs" error="invalid aufs configuration"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.331683613+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.btrfs\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332071233+02:00" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.btrfs\"..." error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332137691+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.devmapper\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332186760+02:00" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.devmapper" error="devmapper not configured"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332216182+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.native\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332284146+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332604245+02:00" level=info msg="loading plugin \"io.containerd.snapshotter.v1.zfs\"..." type=io.containerd.snapshotter.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332700378+02:00" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.zfs" error="invalid zfs configuration"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332757904+02:00" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." type=io.containerd.metadata.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332830038+02:00" level=warning msg="could not use snapshotter devmapper in metadata plugin" error="devmapper not configured"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332909792+02:00" level=warning msg="could not use snapshotter zfs in metadata plugin" error="invalid zfs configuration"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.332981413+02:00" level=warning msg="could not use snapshotter aufs in metadata plugin" error="invalid aufs configuration"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333032397+02:00" level=info msg="metadata content store policy set" policy=shared
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333348255+02:00" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333440533+02:00" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333588815+02:00" level=info msg="loading plugin \"io.containerd.service.v1.introspection-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333737147+02:00" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333833351+02:00" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.333923507+02:00" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334047759+02:00" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334129388+02:00" level=info msg="loading plugin \"io.containerd.service.v1.leases-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334199037+02:00" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334277137+02:00" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334346473+02:00" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334660067+02:00" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.334896353+02:00" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337135112+02:00" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337291605+02:00" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337452044+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337500804+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337540655+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337578392+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337614271+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337654125+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337691770+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337744511+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337782997+02:00" level=info msg="loading plugin \"io.containerd.internal.v1.opt\"..." type=io.containerd.internal.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337881680+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337929523+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.337971196+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.338029389+02:00" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.338638328+02:00" level=info msg=serving... address=/var/run/docker/containerd/containerd-debug.sock
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.338775937+02:00" level=info msg=serving... address=/var/run/docker/containerd/containerd.sock.ttrpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.338901661+02:00" level=info msg=serving... address=/var/run/docker/containerd/containerd.sock
Sep 27 17:30:45 kkkkkkLaptop dockerd[37353]: time="2020-09-27T17:30:45.339002888+02:00" level=info msg="containerd successfully booted in 0.124077s"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.357242361+02:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.357360759+02:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.357434379+02:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.357491681+02:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.360409048+02:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.360499765+02:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.360576483+02:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.360615536+02:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Sep 27 17:30:45 kkkkkkLaptop systemd[1]: var-lib-docker-overlay2-check\x2doverlayfs\x2dsupport183330538-merged.mount: Succeeded.
░░ Subject: Unit succeeded
░░ The unit var-lib-docker-overlay2-check\x2doverlayfs\x2dsupport183330538-merged.mount has successfully entered the 'dead' state.
Sep 27 17:30:45 kkkkkkLaptop systemd[1104]: var-lib-docker-overlay2-check\x2doverlayfs\x2dsupport183330538-merged.mount: Succeeded.
░░ The unit UNIT has successfully entered the 'dead' state.
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.392523296+02:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Sep 27 17:30:45 kkkkkkLaptop plasmashell[1256]: Source is not a predicate or a device.
Sep 27 17:30:45 kkkkkkLaptop plasmashell[1256]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:124: TypeError: Value is undefined and could not be converted to an object
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.399981736+02:00" level=warning msg="Your kernel does not support cgroup memory limit"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.400056530+02:00" level=warning msg="Unable to find cpu cgroup in mounts"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.400086873+02:00" level=warning msg="Unable to find blkio cgroup in mounts"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.400112139+02:00" level=warning msg="Unable to find cpuset cgroup in mounts"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.400137208+02:00" level=warning msg="Unable to find pids cgroup in mounts"
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.401231343+02:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Sep 27 17:30:45 kkkkkkLaptop dockerd[37340]: time="2020-09-27T17:30:45.401426240+02:00" level=info msg="stopping healthcheck following graceful shutdown" module=libcontainerd
Sep 27 17:30:46 kkkkkkLaptop dockerd[37340]: failed to start daemon: Devices cgroup isn't mounted
Sep 27 17:30:46 kkkkkkLaptop systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit docker.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Sep 27 17:30:46 kkkkkkLaptop systemd[1]: docker.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit docker.service has entered the 'failed' state with result 'exit-code'.
Sep 27 17:30:46 kkkkkkLaptop systemd[1]: Failed to start Docker Application Container Engine.
░░ Subject: A start job for unit docker.service has failed
░░ A start job for unit docker.service has finished with a failure.
░░ The job identifier is 4673 and the job result is failed.
I tried it with docker and with docker-git - both time the same result.
The permissions for the files in /sys/fs/cgroup/unified/system.slice are as follows:
> insgesamt 0
drwxr-xr-x 66 root root 0 27. Sep 17:30 .
dr-xr-xr-x 5 root root 0 27. Sep 16:36 ..
drwxr-xr-x 2 root root 0 27. Sep 16:50 apparmor.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 avahi-daemon.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 avahi-daemon.socket
drwxr-xr-x 2 root root 0 27. Sep 16:03 bluetooth.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 boot-efi.mount
-r--r--r-- 1 root root 0 27. Sep 17:08 cgroup.controllers
-r--r--r-- 1 root root 0 27. Sep 16:03 cgroup.events
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.freeze
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.max.depth
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.max.descendants
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.procs
-r--r--r-- 1 root root 0 27. Sep 17:08 cgroup.stat
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.subtree_control
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.threads
-rw-r--r-- 1 root root 0 27. Sep 17:08 cgroup.type
drwxr-xr-x 2 root root 0 27. Sep 16:54 containerd.service
-rw-r--r-- 1 root root 0 27. Sep 17:08 cpu.pressure
-r--r--r-- 1 root root 0 27. Sep 17:08 cpu.stat
drwxr-xr-x 2 root root 0 27. Sep 16:03 cronie.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 dbus.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 dbus.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 dm-event.socket
-rw-r--r-- 1 root root 0 27. Sep 17:08 io.pressure
drwxr-xr-x 2 root root 0 27. Sep 16:50 kmod-static-nodes.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 ldconfig.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 lvm2-lvmetad.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 lvm2-lvmetad.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 lvm2-lvmpolld.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 lvm2-monitor.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 media-Windows.mount
-rw-r--r-- 1 root root 0 27. Sep 17:08 memory.pressure
drwxr-xr-x 2 root root 0 27. Sep 16:03 ModemManager.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 -.mount
drwxr-xr-x 2 root root 0 27. Sep 16:03 NetworkManager.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 NetworkManager-wait-online.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 org.cups.cupsd.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 org.cups.cupsd.socket
drwxr-xr-x 2 root root 0 27. Sep 17:18 pamac-daemon.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 polkit.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 rtkit-daemon.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 run-user-1000.mount
drwxr-xr-x 2 root root 0 27. Sep 16:03 sddm.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 snapd.apparmor.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 snapd.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-binfmt.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-coredump.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-journal-catalog-update.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-journald-audit.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-journald-dev-log.socket
drwxr-xr-x 2 root root 0 27. Sep 16:03 systemd-journald.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-journald.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-journal-flush.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 systemd-logind.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-modules-load.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-random-seed.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-remount-fs.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-rfkill.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-sysctl.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-sysusers.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 systemd-timesyncd.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-tmpfiles-setup-dev.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-tmpfiles-setup.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-udevd-control.socket
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-udevd-kernel.socket
drwxr-xr-x 2 root root 0 27. Sep 16:03 systemd-udevd.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-udev-trigger.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-update-done.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-update-utmp.service
drwxr-xr-x 2 root root 0 27. Sep 16:50 systemd-user-sessions.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 system-getty.slice
drwxr-xr-x 2 root root 0 27. Sep 16:03 system-modprobe.slice
drwxr-xr-x 3 root root 0 27. Sep 16:50 system-systemd\x2dbacklight.slice
drwxr-xr-x 3 root root 0 27. Sep 16:50 system-systemd\x2dfsck.slice
drwxr-xr-x 2 root root 0 27. Sep 16:50 tlp.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 tmp.mount
drwxr-xr-x 2 root root 0 27. Sep 16:03 udisks2.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 upower.service
drwxr-xr-x 2 root root 0 27. Sep 16:03 wpa_supplicant.service
Does anyone here have made similar experiences and solved the “problem”?
Many thanks for all your help.
Kind regards,
Deniz
