Today I started having this problem (I update my laptop every day, basically, from the stable channel) where docker-desktop where it wants to update qemu, but the options provided (qemu-git and qemu-headless-git) conflict with qemu-desktop which is installed and maybe used by docker-desktop until now? Here’s the full output (without rebuilding the packages as I’ve tried that a couple of times to see if it helped):
$ yay -Syua
:: Searching AUR for updates...
:: There are 2 providers available for qemu>=8.0.4:
:: Repository AUR
1) qemu-git 2) qemu-headless-git
Enter a number (default=1):
-> Packages not in AUR: libsidplay systemd-fsck-silent webkit2gtk-5.0
:: 1 dependency will also be installed for this operation.
aur/qemu-git -> 20:8.1.0.r83.g50e7a40af3-1
:: 1 package to upgrade/install.
1 aur/docker-desktop 4.22.0-2 -> 4.22.1-3
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
-> Excluding packages may cause partial upgrades and break systems
AUR Dependency (1): qemu-git-20:8.1.0.r83.g50e7a40af3-1
AUR Explicit (1): docker-desktop-4.22.1-3
:: PKGBUILD up to date, skipping download: docker-desktop
:: PKGBUILD up to date, skipping download: qemu-git
2 qemu-git (Build Files Exist)
1 docker-desktop (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
2 docker-desktop (Installed) (Build Files Exist)
1 qemu-git (Build Files Exist)
==> Diffs to show?
==> Making package: docker-desktop 4.22.1-3 (Fri 25 Aug 2023 08:43:16 PM WEST)
==> Retrieving sources...
-> Found docker-desktop-4.22.1-x86_64.pkg.tar.zst
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with md5sums...
docker-desktop-4.22.1-x86_64.pkg.tar.zst ... Passed
==> Making package: qemu-git 20:8.1.0.r83.g50e7a40af3-1 (Fri 25 Aug 2023 08:43:22 PM WEST)
-> Updating qemu git repo...
-> Found qemu-guest-agent.service
-> Found 65-kvm.rules
qemu ... Skipped
qemu-guest-agent.service ... Passed
65-kvm.rules ... Passed
:: (1/2) Parsing SRCINFO: docker-desktop
:: (2/2) Parsing SRCINFO: qemu-git
==> Making package: qemu-git 20:8.1.0.r83.g50e7a40af3-1 (Fri 25 Aug 2023 08:43:29 PM WEST)
qemu ... Skipped
==> Extracting sources...
-> Creating working copy of qemu git repo...
Cloning into 'qemu'...
done.
==> Starting prepare()...
==> Starting pkgver()...
==> Sources are ready.
-> qemu-git-20:8.1.0.r83.g50e7a40af3-1 already made -- skipping build
==> Making package: qemu-git 20:8.1.0.r83.g50e7a40af3-1 (Fri 25 Aug 2023 08:43:43 PM WEST)
==> WARNING: Using existing $srcdir/ tree
loading packages...
resolving dependencies...
:: qemu-git and qemu-desktop are in conflict (qemu). Remove qemu-desktop? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
-> Failed to install layer, rolling up to next layer.error:error installing: [/home/bruno/.cache/yay/qemu-git/qemu-git-20:8.1.0.r83.g50e7a40af3-1-x86_64.pkg.tar.zst] - exit status 1
==> Making package: qemu-git 20:8.1.0.r83.g50e7a40af3-1 (Fri 25 Aug 2023 08:44:08 PM WEST)
qemu ... Skipped
done.
==> Making package: qemu-git 20:8.1.0.r83.g50e7a40af3-1 (Fri 25 Aug 2023 08:44:24 PM WEST)
==> Making package: docker-desktop 4.22.1-3 (Fri 25 Aug 2023 08:44:25 PM WEST)
==> Missing dependencies:
-> qemu>=8.0.4
==> ERROR: Could not resolve all dependencies.
-> error making: docker-desktop-exit status 8
loading packages...
:: qemu-git and qemu-desktop are in conflict (qemu). Remove qemu-desktop? [y/N] y
:: removing qemu-desktop breaks dependency 'qemu>=5.2.0' required by docker-desktop
:: removing qemu-desktop breaks dependency 'qemu-desktop' required by gnome-boxes
-> error installing: [/home/bruno/.cache/yay/qemu-git/qemu-git-20:8.1.0.r83.g50e7a40af3-1-x86_64.pkg.tar.zst] - exit status 1
It also doesn’t matter if I try to remove qemu-desktop or not (not removing won’t go through, and removing doesn’t work because docker-desktop and gnome-boxes depends on it). Additionally, choosing qemu-git or qemu-headless-git yields the same result.
The only relevant reference I’ve seen online is Qemu-base & Qemu-desktop conflicting dependencies - Unsupported Software (AUR & Other) - Garuda Linux Forum which is old and not really applicable here, I think. I also found nothing on GitHub - docker/desktop-linux: Bug reports for Docker Desktop for Linux
Docker Desktop works, it’s just not updating, which is annoying.
Any help will be appreciated, thanks!
