Hello, I have made a new VM with manjaro and BTRFS on AMD64 platform.
I have installed docker with command:
# pacman -S docker docker-compose
and I tried to build a custom .yml with command:
# docker compose up -d --build
the command gets stuck on “exporting layers”. After a long time it goes to timeout.
The same configuration was working with ext4 filesystem.
Are you aware of any issue of Docker with BTRFS filesystem?
