Whenever I start a new session on my PC the “do not disturb” is enabled by default.
I searched a lot here on the forum, but I didn’t find any topic talking about it, is there any way it doesn’t come enabled at the beginning of the session?
Only one other that I can think of, and it may not apply to you. If you are using a laptop with an external monitor that mirrors what is shown on the laptop’s internal monitor, then open up System Settings and check the following…
Personalization → Notifications
Untick the checkbox for “Do Not Disturb mode: Enable when screens are mirrored”.
==== EDITED ====
I didn’t tell you I was dumb, I found it after I posted it here, I’ll test it and I’ll be right back to mark it as solved if that’s the case he he
