Some time back I downgraded my kernel because my Fn Lock Indicator feature got lost. Now everytime an updates happens and the previous kernel reaches the EOL I have to manually use the mhwd feature in settings or use commandline to upgrade to the latest.
(361/460) upgrading linux60 [---------------------------------------------------------------------------------------] 100%
>>> NOTE, 6.0.19 is the last maintenance release of the 60 kernel series.
This kernel is now marked 'End Of Life' (EOL).
It is recommend to switch to the newer linux61 series:
'sudo mhwd-kernel -i linux61'
How can I make this automatic during an update so that when an update comes it upgrades the kernel automatically and I don’t have to worry about anything.
There was a time then there was a meta-package with the latest kernel and one for the LTS.
It was dropped because it introduced too many possibilities for errors. One of which you actually witnessed.
Rolling realease distros are not meant for unattended upgrades.
can I ask one off topic question ?
I received an update and I am from stable branch but here there isn’t any announcement of stable update instead of an unstable update. Should I be concerned ?
I had around 460 packages updates with linux 6.1.7 or something and I really am stuck with this kernel
I know it is the latest but my brightness isn’t working at all.
I tried
Is that the reason I am not able to downgrade to linux515 when I tried downgrading ?
I wanted to downgrade my kernel to linux 515 but it doesn’t by some reason… with this
I have the package in my pacman cache but the kernel doesn’t get switched to linux515. It remains linux61. Can you help me on how to figure out the downgrade ?
Grub doesn’t appear in my boot process. Can you tell me which key shows that ?
I thought it was e but turns or it isn’t.
I hope I am not very irritating
Hope you have a great day
