Dnsdig - script to test common resolvers
There were a few occasions to post this in a few threads.
So now I put it in a place.
Feel free to recommend DNS providers I should add (or remove).
Or anything else I suppose.
Example run
 Test common resolvers by calculating average response times of 3 queries.
DNS            Primary         Secondary
AdGuard        94.140.14.14    94.140.15.15
CleanBrowsing  185.228.168.9   185.228.169.9
Cloudflare     1.1.1.1         1.0.0.1
Comodo         8.26.56.26      8.20.247.20
Control-D      76.76.2.2       76.76.10.2
Google         8.8.8.8         8.8.4.4
Neustar        156.154.70.2    156.154.71.2
NextDNS        45.90.28.105    45.90.30.105
OpenDNS        208.67.222.222  208.67.220.220
Quad9          9.9.9.9         149.112.112.112
 Do you wish to flush the DNS cache? y
Current DNS X.X.X.X
Avg time:  6  ms
Avg time:  40  ms
Avg time:  9.66667  ms
Cloudflare 1.1.1.1
Comodo 8.26.56.26
Avg time:  242.667  ms
Control-D 76.76.2.2
Avg time:  16.3333  ms
Google 8.8.8.8
Avg time:  60.6667  ms
Avg time:  8.66667  ms
Avg time:  7.33333  ms
Avg time:  26.3333  ms
Quad9 9.9.9.9
Avg time:  10.3333  ms
That is very cool, i used to use GRC.com tool for that purpose on windows. Just a small note, looking at the script: resolvectl service is not the default resolver on a new manjaro install, so this part will not work.
P.s. according to this (read all of it) there is no cache by default, so it does not matter.
Nice work :+1: - with your permission - I will add it to the [root tip] [How To] Basic network know-how and troubleshooting.
When one is experiencing slow network it may as well be a slow dns resolver - this script is quite handy.
I am using bind on a rpi to resolve dns using root servers so I am getting an average of 1s for my current resolver :slight_smile:
How about using drill instead of dig? After all drill is default present on Manjaro. as a drop-in replacement for dig.
DIGGER="dig"
if ! command -v $DIGGER > /dev/null; then
    $DIGGER="drill"
fi
    echo "no capable digger found"
    exit 1
fi
Thanks both @ManjaroDevOps @Teo … I will incorporate both of your observations/suggestions into some updates (at some point).
This one is easy :slight_smile:
drill is not an complete drop-in replacement for dig. I really like drill, but drill does not support query options like dig and this is unfortunate.
Of course +short is nice but not that important. But for example with +https or +tls you can easily test DoH or DoT.
dig manjaro.org A @anycast.uncensoreddns.org +https
dig manjaro.org A @anycast.uncensoreddns.org +https +short
Wrong use of the phrase drop-in - my apology.
For the common use drill is might fine.
I’ve done some updates for checking for other caches to flush, merged your MR @ManjaroDevOps, and some other stuff.
Readme now reflects some extra things like drill and the ability to use
bash <(curl -s https://gitlab.com/cscs/dnsdig/-/raw/main/dnsdig)
So did I about 20 years ago. They’re awesome. :grin:
I’ve been working on it also after i forked yesterday, will commit in my fork soon, after i finished the total rewrite and incorporated the changes you added :wink:
:point_up: :point_up_2: Just a preview @cscs :face_with_hand_over_mouth: :wink:
