In my manjaro gnome system I can ping 8.8.8.8 and ip address of any website but not the domain names and I got the error Temporary failure in name resolution.
I checked the file /etc/resolv.conf and it’s empty.
I tried updating the dns in the gui settings and also with nmcli con mod 'connection name' ipv4.dns 8.8.8.8. But after re-activating the connection and also multiple reboots nothings is changed and the resolv.conf file is still empty.
Also tried setting the nameserver 8.8.8.8 in the /etc/resolvconf/resolv.conf.d/base file, but still no luck.
I cannot update my system or install any other softwares with pacman due to this problem.
Can somebody help me solve this?
can you provide
inxi -Fza
Your issue is not a basic issue with Manjaro - but a local network configuration.
Such issue is is next to impossible to troubleshoot remotely.
The first step is to restart your router and thus the dns service.
Undo/Revert any customization you may have made in networkmanager.
/etc/resolv.conf is controlled by the resolvconf program and written by NetworkManager.
You can control resolvconf using the /etc/resolvconf.conf file to set a specific nameserver - and this is great for troubleshooting. It is highly recommended to locate the actual issue interfering with setting a nameserver
name_servers 8.8.8.8
run resolvconf to update the resolv.conf
sudo resolvconf -u
then reset your network (from your inxi the eno1 is your nic)
sudo ip link set eno1 down
sudo ip link set eno1 up
systemd-resolved
In some situations it may help to remove openresolv package and enable systemd-resolved.service.
sudo pacman -R openresolv
sudo systemctl enable --now systemd-resolved.service
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7b4eedc1-e7c5-4b37-8b33-941faedb2220 rw quiet splash apparmor=1
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: Hewlett-Packard product: HP EliteDesk 800 G1 SFF
v: N/A serial: <superuser required> Chassis: type: 4
Mobo: Hewlett-Packard model: 1998 serial: <superuser required>
BIOS: Hewlett-Packard v: L01 v02.53 date: 10/20/2014
Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2631 high: 3293 min/max: 800/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2561 2: 1377 3: 3293
4: 3293 bogomips: 26350
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Hewlett-Packard EliteDesk 800 G1 driver: i915 v: kernel
arch: Gen-5.75 process: Intel 45nm built: 2010 ports: active: VGA-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-size: <missing: xdpyinfo>
Monitor-1: VGA-1 model: LG (GoldStar) HD PLUS built: 2016 res: 1600x900
hz: 60 dpi: 92 gamma: 1.2 size: 440x250mm (17.32x9.84") diag: 506mm (19.9")
ratio: 16:9 modes: max: 1600x900 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Hewlett-Packard EliteDesk 800 G1 driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard EliteDesk 800 G1
driver: e1000e v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a
class-ID: 0200
Local Storage: total: 74.53 GiB used: 20.64 GiB (27.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Maxtor model: STM380811AS
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: E scheme: MBR
ID-1: / raw-size: 74.53 GiB size: 72.81 GiB (97.69%) used: 20.64 GiB (28.4%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 206 Uptime: 37m wakeups: 0 Memory: 7.67 GiB
used: 1.26 GiB (16.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1331
pm: pacman pkgs: 1327 libs: 321 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 4 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
Thank you! I didn’t remove openresolv and yet enabling systemd-resolved service solved the problem.
