DNS is blocked or has slow response
Hello everyone,
I am using the Microsoft Onedrive Client from abraunegg but since I reinstalled my system the client does not start. The result of onedrive --synchronize is
(base) manjaro% onedrive --synchronize
Configuration file successfully loaded
Cannot connect to Microsoft OneDrive Service - Network Connection Issue
ERROR: Microsoft OneDrive API returned an error with the following message:
  Error Message:    Timeout was reached on handle 55E6756618E0
  Calling Function: testNetwork()
Unable to reach Microsoft OneDrive API service, unable to initialize application
In the FAQ it says that I should run the command
curl -I --connect-timeout 5 --max-time 5 https://login.microsoftonline.com
The result I get is
(base) manjaro% curl -I --connect-timeout 5 --max-time 5 https://login.microsoftonline.com
curl: (28) Resolving timed out after 5000 milliseconds
[…] you need to fix your local environment so that the curl command executes successfully. Once this does, the OneDrive Client will operate normally.
But I have no idea how I could do so. Can anyone give me some hints on what to try or help me otherwise?
That would help me a lot!
David
PS:
Information about my software and hardware:
manjaro%  inxi -Fazy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=116ef32c-01ce-4135-b673-172a7f9c2c4d rw quiet splash apparmor=1
  Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: P8B75-M LX PLUS v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 0501 date: 10/10/2012
  Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  L2 cache: 6 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23956
  Speed: 1596 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1596 2: 1597
  3: 1597 4: 1597
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
  vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0152
  Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Gigabyte driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:11c6
  Display: wayland server: X.org 1.20.10 compositor: gnome-shell
  driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display ID: 0 resolution: <missing: xdpyinfo>
  OpenGL: renderer: NVE6 v: 4.3 Mesa 20.3.1 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1e20
  Device-2: NVIDIA GK106 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b
  Device-3: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 1-4:2 chip ID: 0c45:6366 serial: <filter>
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
  driver: rtl8192ce v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8178
  vendor: ASUSTeK P8 series driver: r8169 v: kernel port: c000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: enp4s0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 47.01 GiB (5.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010DLE630
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: A650
  ID-1: / raw size: 48.83 GiB size: 47.81 GiB (97.92%) used: 16.41 GiB (34.3%)
  fs: ext4 dev: /dev/sda9 maj-min: 8:9
  ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
  used: 324 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7
  ID-3: /home raw size: 50.63 GiB size: 49.59 GiB (97.94%)
  used: 30.61 GiB (61.7%) fs: ext4 dev: /dev/sda10 maj-min: 8:10
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda8 maj-min: 8:8
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 28.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 1260
  Processes: 218 Uptime: 16m wakeups: 0 Memory: 7.64 GiB
  used: 2.11 GiB (27.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
  pacman: 1376 lib: 382 flatpak: 0 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.2.01
You could try changing the DNS server, the one that is automatically used is the one your provider … provides and it may be not the fastest.
You could do that in your router, or
From the network manager icon
select to edit the connection
in the tab ipv4 properties change the method from
automatic
to
automatic, addresses only
and put (for example) 8.8.8.8,1.1.1.1 in the field “additional DNS Servers”
… you can use just one (8.8.8.8)
if you use two, do it like written here - a comma and no whitespace in between
safe and reconnect
or
systemctl restart NetworkManager
from a terminal
If that doesn’t help someone else is probably more knowledgeable than me.
This is not a Manjaro issue - but a network issue.
Because it is so easy to mess your network - you have to know what you are doing.
If you have slow nslookups it can be any number of things - but usually it boils down to the system cannot find the server specified in resolv.conf.
DNS Benchmark for the rescue.
https://www.grc.com/dns/benchmark.htm
Thank you! The tools tells me that
I am however not sure what to make of that and whether I should take any action.
Great, putting 8.8.8.8,1.1.1.1 in the field did the job.
Thank you so much!
Good. You are welcome!
In case you don’t know:
8.8.8.8 is one of Googles public nameservers
1.1.1.1 is one of Cloudflares public nameservers
… but not everybody likes the companies behind them, so this is me informing you what you have just done :stuck_out_tongue_winking_eye:
They are reliable and very fast compared to many providers own nameserver including my own provider and I do use them myself.
Your ISP is doing really bad job! Glad that you decided to use alternative nameserver and improved your network :slight_smile:
But as others pointed out, you must be aware that your new DNS belongs to Google who have no remorse tracking you everywhere and making money off you.
I spin off my own DNS server based on BIND. Nothing public out there can beat ~15ms response time from my server and ~0ms for cached queries :sunglasses: :grin: And it’s great for privacy too.
I’m interested in doing something like that for a long time.
As a pretty much installable solution there is pdnsd, which survives reboots.
I only have a laptop - and no server …
You reminded me to setting that up again.
I did use that back in my dialup modem days …
