when i press mod+d nothing happens…how to fix dmenu…1st time in a wm
Try to open your /home/USERNAME/i3/config and check if the entry
bindsym $mod+d exec...
is available and not commented out.
It is not commented out
start program launcher
bindsym $mod+d exec --no-startup-id dmenu_recency
Is dmenu
installed? Is it running? Try to start it with dmenu_run
. Good reference is here .
It is installed…dmenu_run shows no locale support…there is a Manjaro page stating exactly this issue…so I have tried that…still not running with mod+d
I am thinking of switching to openbox
No, don’t give up too soon! There’s a little “Troubleshooting” chapter in the link I gave you. Try it.
Hahaha…ok…I’ll try to resolve this😃
‘sudo locale-gen’
‘sudo localectl set-locale LANG=en_US.UTF-8’
Reboot
This solved the issue
