I made a script as a simple productivity tool that presents important data in the form of a calendar. It monitors critical dates, simplifies event addition via APIs, and calculates timespans for various event types. It’s a project that I’ve found personally fun to use and quite useful, so I’m sharing it in the hopes that it might be of use to others as well. It’s an early stage and your feedback and contributions on GitHub are most welcome.
Designed for developers, dLine streamlines event management and schedule navigation without requiring you to leave the terminal. The script utilizes the OpenHolidaysAPI and provides an easy access to localized holidays specific for your region (in case you live in Europe).
Short intro on YouTube: https://www.youtube.com/shorts/aZMAY2oSTks
Usage/Examples
dline -a 2024/07/04 2 Refactor myFunction
- Adding a new event (
yyyy/mm/dd x desc
), wherex
is the category code,desc
is an arbitrary description with a special case where the description may start withhh:mm
time format (which will eventually trigger a scheduled reminder as a popup) and may end with any hashtag (e.g.#projectX
) for easier event handling related to a single topic.
dline -d "#projectX"
- Deleting all events tagged with
#projectX
dline -f 4 6 8
- Toggling visibility of events with codes 4 (Birthday & Anniversary), 6 (Vacation) and 8 (School Holiday).
dline -i GCA
- Triggers an import of calendar(s) from Google Calendar in interractive mode. Read the docs from the project
gcalcli
first. The same operation will be triggered during the very first run, so you may want to run it again if you need to import a new calendar.
dline -s 1
- In case you’re a student, run this to make sure your School Holidays are shown as days off, not as work days.
dline -s 0
- If you’re a parent, use this command to view School Holidays in your region as regular work days. It serves as a reminder to stay informed about when your kids will be off from school.
Easter Egg Alert!
Dear fellow devs, speaking of the xz
drama that shook the Linux community quite recently… Yeah, the one where someone tried to sneak in a backdoor.
Well, fear not! We’ve got your back. Introducing our harmless Easter Egg — a digital wink to keep things light. No backdoors here, just a playful challenge.
Your Mission:
- Inspect the Code: Dive into the repo like a code detective.
- Search High and Low: Look for anything quirky. Comments, function names, variable spells — anything out of the ordinary.
- When You Spot It: Celebrate! You’ve cracked the code (literally) and found my appropriate Easter Egg, right after Easter.
And guess what? The first sleuth to find it gets a virtual high-five and a spot in our “Hall of Fame”.
Remember, it’s all in good fun. No secret societies or secret handshakes required. Happy hunting, code warriors and have fun!
