Hello
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=73af93b2-0824-465a-9ed3-a4f540eb9da9 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5603 date: 07/28/2020
Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138
L2 cache: 3072 KiB
bogomips: 86437
Speed: 3007 MHz min/max: 1550/3600 MHz boost: disabled Core speeds (MHz):
1: 3007 2: 1719 3: 1616 4: 1465 5: 1772 6: 2470 7: 1674 8: 1456 9: 2748
10: 1506 11: 2219 12: 2917
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 08:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 528x297mm (20.8x11.7")
s-diag: 606mm (23.9")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 93 size: 525x297mm (20.7x11.7")
diag: 603mm (23.7")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 08:00.1 chip ID: 10de:10f0
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.3 chip ID: 1022:1457
Device-3: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-6:4 chip ID: 046d:082b
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k
port: e000 bus ID: 03:00.0 chip ID: 8086:1539
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 647.02 GiB (55.6%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM014-1EJ164 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SM14 scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 2B6Q scheme: GPT
ID-1: / raw size: 70.53 GiB size: 69.17 GiB (98.07%) used: 43.48 GiB (62.9%)
fs: ext4 dev: /dev/sdb7
ID-2: /home raw size: 50.70 GiB size: 49.78 GiB (98.19%)
used: 34.94 GiB (70.2%) fs: ext4 dev: /dev/sdb5
ID-1: swap-1 type: file size: 8.00 GiB used: 337.2 MiB (4.1%) priority: -2
file: /swapfile
System Temperatures: cpu: 46.2 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 362 Uptime: 9d 8h 45m Memory: 15.64 GiB used: 10.09 GiB (64.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 5/9 clang: 11.0.0 Packages:
pacman: 1662 lib: 419 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
Few days ago, someone in this forum make me notice that the kernel 5.8 is EOL, so I decided to switch to 5.9.
While upgrading, i found different errors during dkms modules installation, as you can see below
The following packages will be installed:
linux59
linux59-virtualbox-host-modules
linux59-nvidia-455xx
linux59-headers
Starting
resolving dependencies...
Packages (4) linux59-5.9.11-3 linux59-headers-5.9.11-3 linux59-nvidia-455xx-455.45.01-4 linux59-virtualbox-host-modules-6.1.16-9
Total Download Size: 118.06 MiB
Total Installed Size: 220.35 MiB
:: Retrieving packages...
downloading linux59-5.9.11-3-x86_64.pkg.tar.zst...
downloading linux59-headers-5.9.11-3-x86_64.pkg.tar.zst...
downloading linux59-virtualbox-host-modules-6.1.16-9-x86_64.pkg.tar.zst...
downloading linux59-nvidia-455xx-455.45.01-4-x86_64.pkg.tar.zst...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux59...
Optional dependencies for linux59
crda: to set the correct wireless channels of your country [installed]
installing linux59-virtualbox-host-modules...
===> You must load vboxdrv module before starting VirtualBox:
===> # modprobe vboxdrv
installing linux59-nvidia-455xx...
In order to use nvidia module, reboot the system.
installing linux59-headers...
(1/6) Arming ConditionNeedsUpdate...
(2/6) Updating module dependencies...
(3/6) Install DKMS modules
==> dkms install --no-depmod -m v4l2loopback-dc -v 1.6 -k 5.9.11-3-MANJARO
Error! Bad return status for module build on kernel: 5.9.11-3-MANJARO (x86_64)
Consult /var/lib/dkms/v4l2loopback-dc/1.6/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m v4l2loopback-dc -v 1.6 -k 5.9.11-3-MANJARO' returned 10
==> dkms install --no-depmod -m vboxhost -v 6.1.16_OSE -k 5.9.11-3-MANJARO
Consult /var/lib/dkms/vboxhost/6.1.16_OSE/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m vboxhost -v 6.1.16_OSE -k 5.9.11-3-MANJARO' returned 10
==> dkms install --no-depmod -m zenpower -v 0.1.12 -k 5.9.11-3-MANJARO
Consult /var/lib/dkms/zenpower/0.1.12/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m zenpower -v 0.1.12 -k 5.9.11-3-MANJARO' returned 10
==> dkms install --no-depmod -m rtl8723bu -v 245 -k 5.9.11-3-MANJARO
Consult /var/lib/dkms/rtl8723bu/245/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m rtl8723bu -v 245 -k 5.9.11-3-MANJARO' returned 10
==> dkms install --no-depmod -m i2c-piix4-aura -v 5.6.11 -k 5.9.11-3-MANJARO
Consult /var/lib/dkms/i2c-piix4-aura/5.6.11/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m i2c-piix4-aura -v 5.6.11 -k 5.9.11-3-MANJARO' returned 10
==> dkms install --no-depmod -m i2c-ch341 -v 20190628 -k 5.9.11-3-MANJARO
Consult /var/lib/dkms/i2c-ch341/20190628/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m i2c-ch341 -v 20190628 -k 5.9.11-3-MANJARO' returned 10
==> depmod 5.9.11-3-MANJARO
(4/6) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.11-3-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
(5/6) Updating Kernel initcpios for Nvidia-DRM...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.80-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> Starting build: 5.8.18-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
(6/6) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found Windows Boot Manager on /dev/sdb2@/efi/Microsoft/Boot/bootmgfw.efi
done
Done
Booting the system up, I noticed that sensors and other stuff didn’t work.
Searching through the wiki and randomly online, I wasn’t able to understand where’s the problem at.
So i tried to reinstall the kernel, but with the same results.
I tried to install the 5.10 experimental kernel also, and the log showed the same errors during dkms installation.
I also tried this command: dkms autoinstall (specifing the 5.9 kernel)
Error! Could not locate dkms.conf file.
File: /var/lib/dkms/rtl8723bu/240/source/dkms.conf does not exist.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...(bad exit status: 2)
make -j12 KERNELRELEASE=5.9.11-3-MANJARO -C /usr/lib/modules/5.9.11-3-MANJARO/build SUBDIRS=/var/lib/dkms/i2c-ch341/20190628/build modules...(bad exit status: 2)
Building module:
make -j12 KERNELRELEASE=5.9.11-3-MANJARO...
Kernel cleanup unnecessary for this kernel. Skipping...
DKMS: build completed.
i2c-piix4.ko.xz:
Running module version sanity check.
- Original module
- Found /usr/lib/modules/5.9.11-3-MANJARO/kernel/drivers/i2c/busses/i2c-piix4.ko.xz
- Storing in /var/lib/dkms/i2c-piix4-aura/original_module/5.9.11-3-MANJARO/x86_64/
- Archiving for uninstallation purposes
- Installation
- Installing to /usr/lib/modules/5.9.11-3-MANJARO/kernel/drivers/i2c/busses/
depmod.....
DKMS: install completed
But same errors…
So I’m asking you guys, pls pardon my English and where’s the problem at?
Thank you!
