Dkms build kernel failed
Hello
when I boot to manjaro recive this output
[Failed] Failed to start Load AppArmor profiles.
[Failed] Failed to start Load AppArmor managed internally by snapd
[Failed] Failed to start Clean up module from old kernel
[Failed] Failed to start TLP system startup/shutdown
next boot manjaro live boot from usb and enter below command
sudo mount /dev/sda4 /mnt
sudo mount /dev/sda3 /mnt/home
sudo mount /dev/sda2 /mnt/boot
manjaro-chroot /mnt/
and get this output
chroot: failed to run command '/bin/sh': No such file or directory
how can I fix?
Chroot is complaining because it can’t find /bin/sh inside the chroot environment, so it can’t drop you on a shell there. Mount your device, then check inside:
manjaro-chroot -a
Edit - should be manjaro-chroot /mnt /bin/bash
Hi,
You shloud be able to tell chroot to use bash :
chroot /mnt/ /bin/bash
and then do this symlink:
ln -s /bin/bash /bin/sh
## or
ln -s /bin/dash /bin/sh   ### this is what I personally do
sudo umount /mnt/boot
sudo umount /mnt/home/
umount /mnt/
manjaro-chroot -a
output
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda4]
 --> mount: [/mnt]
mount: /mnt: /dev/sda4 already mounted on /mnt.
 --> mount: [/mnt/boot]
mount: /mnt/boot: /dev/sda2 already mounted on /mnt/boot.
 --> mount: [/mnt/home]
mount: /mnt/home: /dev/sda3 already mounted on /mnt/home.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
/usr/bin/env: 'bash': No such file or directory
[manjaro@manjaro ~]$ sudo chroot /mnt/ /bin/bash
/usr/bin/grub-probe: error: cannot find a device for / (is /dev mounted?).
[manjaro /]# ln -s /bin/bash /bin/sh
## or
ln: failed to create symbolic link '/bin/sh': File exists
[manjaro /]# rm /bin/sh
## or
now when I boot to manjaro, see grub terminal!
for the symlink: use the f option (force) => ln -sf /bin/bash /bin/sh
for grub : it’s another issue and I don’t know how to fix this
/usr/bin/env: 'bash': No such file or directory #### <---- ?
are you dual booting with windozs?
Try to restore grub:
sudo grub-install /dev/sda --recheck
sudo update-grub
and reboot.
If this is not helping probably your boot partition /dev/sda1 is corrupted and you need to restore it via Windoze tools.
no just installed manjaro
show again this…
my main issue is /usr/bin/env: 'bash': No such file or directory
if fix them can fix grub
please help me to fix bash issue :pray:
What happens when you try bash grub-mkconfig -o /boot/grub/grub.cfg. What is the output of echo $PATH
[manjaro /]#  bash grub-mkconfig -o /boot/grub/grub.cfg
bash: bash: command not found
[manjaro /]# echo $PATH
/home/manjaro/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
seems like bash is not even installed
Fixed :sunglasses:
My guess is that the last time I installed the package dkms could not build the kernel properly
So I reinstalled Linux with sudo pacman -S linux
As a result, dkms rebuilt the kernel and the problem was fixed
Read about DKMS
Thank you all for your help
Good luck
@ishaan2479 @oguere @anon12891489
