Displayport screens not automatically set to resolution after turning them off and back on
For some reason, my 2 displayport screens aren’t being set to any resolution after turning them off and back on again. currently i’ve been working around it with an xrandr command. If i switch to a TTY window, it does work. I looked around but couldn’t seem to find anything online, so i hope someone can help me with this issue
Welcome to the forum! :wave:
Please post your system info as outlined here:
Here you go:
  Kernel: 5.19.16-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=da07754f-2038-47d3-a564-fc9794a0a969 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Micro-Star product: MS-7C84 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.50
    date: 01/20/2021
  ID-1: hidpp_battery_0 charge: 24% condition: N/A volts: 3.7 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> status: discharging
  Device-1: nintendo_switch_controller_battery_0003:057E:2009.0024
    model: N/A serial: N/A charge: Full status: full
  RAM: total: 31.27 GiB used: 15.94 GiB (51.0%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2880 high: 3601 min/max: 2200/5176 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2879
    3: 3600 4: 2880 5: 2879 6: 2200 7: 2880 8: 2880 9: 2200 10: 3599 11: 3601
    12: 2652 13: 2881 14: 2880 15: 2880 16: 3138 17: 2984 18: 2879 19: 2200
    20: 2879 21: 2880 22: 2883 23: 2878 24: 2200 25: 2200 26: 3600 27: 3497
    28: 2632 29: 2879 30: 2200 31: 2879 32: 2880 bogomips: 217698
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Gigabyte driver: nvidia
    v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
    (as of 2022-10) arch: Lovelace code: AD1xx process: TSMC n4 (5nm)
    built: 2022-23+ pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.0
    chip-ID: 10de:2684 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 6440x2560 s-dpi: 101 s-size: 1620x644mm (63.78x25.35")
    s-diag: 1743mm (68.63")
  Monitor-1: DP-1 pos: bottom-l res: 1920x1080 hz: 60 dpi: 102
    size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
  Monitor-2: DP-2 pos: top-right res: 1080x2560 dpi: 82
    size: 334x798mm (13.15x31.42") diag: 865mm (34.06") modes: N/A
  Monitor-3: DP-4 pos: primary,middle-c res: 3440x1440 dpi: 109
    size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2 v: 4.6.0 NVIDIA
    520.56.06 direct render: Yes
  Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 10de:22ba
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound API: ALSA v: k5.19.16-4-MANJARO running: yes
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 26:00.0
  IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
  Local Storage: total: 5.69 TiB used: 3.29 TiB (57.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 34.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 33.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250BX100SSD1
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: MU02
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1CH162
    type: HDD rpm: 7200 serial: <filter> rev: CC47
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.24 TiB (69.3%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: da07754f-2038-47d3-a564-fc9794a0a969
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: 4C07-EFBC
  ID-3: /mnt/1tb-hdd raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 70.25 GiB (7.7%) fs: ext4 dev: /dev/sdb maj-min: 8:16 label: 1TB HDD
    uuid: d2b22a2c-9fc6-4ad9-8278-625c66b640ca
  ID-4: /mnt/970-evo raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 704.07 GiB (76.9%) fs: ext4 dev: /dev/nvme1n1 maj-min: 259:3
    label: 970 EVO uuid: 5b3737f4-261a-4d3a-91f9-c508785c6341
  ID-5: /mnt/crucial-ssd raw-size: 232.89 GiB size: 228.17 GiB (97.98%)
    used: 20.61 GiB (9.0%) fs: ext4 dev: /dev/sda maj-min: 8:0
    label: crucial-ssd uuid: 83da9c4d-444f-4d13-b7c7-406ec9147500
  ID-6: /mnt/wd-black raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.28
    TiB (71.4%) fs: ext4 dev: /dev/sdc maj-min: 8:32 label: WD Black
    uuid: f1243109-6ce5-4a4a-93ce-d5b096853c1c
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-2: 1-6:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-6.1:6 info: Logitech Cordless Mouse Receiver
    type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Device-2: 1-6.3:9 info: Glorious GMMK Pro type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 320f:5044 class-ID: 0300 serial: <filter>
  Device-3: 1-6.4:10 info: Nintendo Switch Pro Controller type: HID
    driver: nintendo,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 057e:2009 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0605 class-ID: 0900
  Device-1: 3-5:3 info: Micro Star MYSTIC LIGHT type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 1462:7c84 class-ID: 0300 serial: <filter>
  Hub-6: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-8: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 49.1 C mobo: N/A gpu: nvidia temp: 34 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 60%
  Processes: 523 Uptime: 19h 18m wakeups: 83 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
  clang: 14.0.6 Packages: 1384 pm: pacman pkgs: 1371 libs: 354
  tools: pamac,yay pm: flatpak pkgs: 13 Shell: Zsh v: 5.9 running-in: konsole
  inxi: 3.3.22
Seems there was a bug report created for the issue i seem to have as well
