Hello!
I want to connect 2 monitors via Dell Universal Dock UD22 and use them with laptop screen. I followed DisplayLink arch wiki instruction, and
- Installed
evdi-git
withyaourt -S evdi-git
- Installed
displaylink
withyaourt -S displaylink
- Enabled
displaylink.service
withsystemctl status displaylink
- Create file
/etc/X11/xorg.conf.d/20-evdi.conf
with following content:
Section "OutputClass"
Identifier "DisplayLink"
MatchDriver "evdi"
Driver "modesetting"
Option "AccelMethod" "none"
EndSection
After reboot only one of the monitor connected to dock works. Pls send help.
Usefull info:
● displaylink.service - DisplayLink Manager Service
Loaded: loaded (/usr/lib/systemd/system/displaylink.service; disabled; preset: disabled)
Active: active (running) since Wed 2023-05-17 11:32:24 CEST; 33min ago
Process: 16394 ExecStartPre=/sbin/modprobe evdi (code=exited, status=0/SUCCESS)
Main PID: 16396 (DisplayLinkMana)
Tasks: 9 (limit: 18802)
Memory: 3.6M
CPU: 134ms
CGroup: /system.slice/displaylink.service
└─16396 /usr/lib/displaylink/DisplayLinkManager
May 17 11:32:24 jcz-pc systemd[1]: Starting DisplayLink Manager Service...
May 17 11:32:24 jcz-pc systemd[1]: Started DisplayLink Manager Service.
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x48 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 9 associated providers: 0 name:modesetting
inxi -Gazy
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-7,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: DisplayLink Dell Universal Hybrid Video Dock
driver: cdc_ncm,snd-usb-audio type: USB rev: 3.2 speed: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 bus-ID: 2-3.3:4 chip-ID: 17e9:6013 class-ID: 0a00
serial: <filter>
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 04f2:b6d0
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-7 mapped: DP-3-6-6 pos: left model: HP E231 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,right model: AU Optronics 0x323d built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
inxi -F
Host: jcz-pc Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce
v: 4.18.1 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20W1S2JS34 v: ThinkPad T14 Gen 2i
serial: <superuser required>
Mobo: LENOVO model: 20W1S2JS34 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N34ET42W (1.42 )
date: 08/12/2021
ID-1: BAT0 charge: 50.5 Wh (97.9%) condition: 51.6/50.5 Wh (102.2%)
Info: quad core model: 11th Gen Intel Core i5-1145G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 1524 min/max: 400/4400 cores: 1: 2600 2: 669 3: 1010
4: 966 5: 2600 6: 667 7: 2600 8: 1086
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.1.26-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
IF: wlp0s20f3 state: up mac: a8:64:f1:bd:77:de
Device-2: Intel Ethernet I219-LM driver: e1000e
IF: enp0s31f6 state: down mac: 84:a9:38:30:78:fb
IF-ID-1: enp0s13f0u3u3i5 state: down mac: 0c:37:96:87:d8:a7
Device-1: Intel AX201 Bluetooth driver: btusb type: USB
Local Storage: total: 476.94 GiB used: 29.2 GiB (6.1%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1001 size: 476.94 GiB
ID-1: / size: 451.48 GiB used: 29.2 GiB (6.5%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 472 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.87 GiB used: 0 KiB (0.0%)
dev: /dev/dm-1
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2274
Processes: 312 Uptime: 53m Memory: available: 15.33 GiB
used: 5.97 GiB (38.9%) Shell: fish inxi: 3.3.27
