Hello, my usb Asus monitor has been very laggy since the AUR displaylink package was updated to 5.4-3. I am wondering either is there a way to downgrade the package or another way?
Here is the output to inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=41b5e77f-aea6-4e67-93a5-664479adb001 rw quiet
cryptdevice=UUID=77b502ae-f416-426b-aedc-de4e854f3e72:luks-77b502ae-f416-426b-aedc-de4e854f3e72
root=/dev/mapper/luks-77b502ae-f416-426b-aedc-de4e854f3e72 apparmor=1
security=apparmor
resume=/dev/mapper/luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0
udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82DQ v: Lenovo V14-ARE serial: <filter>
Chassis: type: 10 v: Lenovo V14-ARE serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697WIN serial: <filter>
UEFI: LENOVO v: DZCN33WW date: 09/24/2020
ID-1: BAT0 charge: 31.4 Wh (96.6%) condition: 32.5/35.3 Wh (92.2%)
volts: 8.5 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
status: Unknown cycles: 6
RAM: total: 7.21 GiB used: 4.27 GiB (59.3%)
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 3 MiB bogomips: 28448
Speed: 1582 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1582 2: 2250 3: 1976 4: 1448 5: 1994 6: 1448
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:4
chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
Device-3: DisplayLink ASUSTEK MB169B+ type: USB driver: usbfs bus-ID: 4-1:2
chip-ID: 17e9:ff0b class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: DVI-I-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.32-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 01:00.0
chip-ID: 168c:003e class-ID: 0280
IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-3:3 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Device-1: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Device-2: luks-77b502ae-f416-426b-aedc-de4e854f3e72 maj-min: 254:0
type: LUKS dm: dm-0 size: 229.37 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 229.37 GiB
Local Storage: total: 853.2 GiB used: 317.45 GiB (37.2%)
model: PC SN520 SDAPMUW-256G-1101 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD
serial: <filter> rev: 20290001 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A
rotation: SSD serial: <filter> rev: 90WD scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC MS PRO
size: 119.08 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 1.00 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Flash Drive FIT size: 29.88 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 224.77 GiB (97.99%)
used: 77.87 GiB (34.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-77b502ae-f416-426b-aedc-de4e854f3e72 label: N/A
uuid: 41b5e77f-aea6-4e67-93a5-664479adb001
used: 26 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 02D5-A444
ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 8 GiB
used: 540.8 MiB (6.6%) fs: fuse source: ERR-102 label: N/A uuid: N/A
ID-4: /run/timeshift/backup raw-size: 307.48 GiB size: 301.59 GiB (98.08%)
used: 238.47 GiB (79.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
label: VM_timeshift uuid: 117afe71-328c-488e-90c4-487cf503eeff
ID-1: swap-1 type: partition size: 8.8 GiB used: 576.8 MiB (6.4%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 label: N/A
uuid: a3c4745a-3fbd-40e1-9d38-a4bb513d2d09
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-2: /dev/sda2 maj-min: 8:2 size: 157.78 GiB fs: bitlocker label: N/A
uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 499 MiB fs: ntfs label: N/A
uuid: 507C2C557C2C37DC
ID-4: /dev/sdb1 maj-min: 8:17 size: 119.07 GiB fs: exfat label: Backup
uuid: 3534-6433
ID-5: /dev/sdc1 maj-min: 8:33 size: 2.89 GiB fs: iso9660
label: MANJARO_KDE_202 uuid: 2020-12-07-13-36-18-00
ID-6: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: EC08-A711
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-1:2 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 248a:8367 class-ID: 0301
Hub-2: 1-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 1-3:4 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b624
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Device-1: 2-2.4:3
info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 304mA chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Realtek USB2.0-CRW type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:0177 class-ID: 0806 serial: <filter>
Device-2: 3-3:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: DisplayLink ASUSTEK MB169B+ type: Video driver: usbfs
interfaces: 2 rev: 3.2 speed: 5 Gb/s power: 504mA chip-ID: 17e9:ff0b
System Temperatures: cpu: 55.0 C mobo: 0 C gpu: amdgpu temp: 40.0 C
Processes: 331 Uptime: 23h 32m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1733
pacman: 1701 lib: 458 flatpak: 10 snap: 22 Shell: Bash v: 5.1.0
running-in: yakuake inxi: 3.3.04
