Hi. Yes, but sry. was my bad. Seams like it does not build in live mode. (pkgconf)
Anyway. After the installation I did the following steps:
- install linux513-headers
- Installed evdi
There I got the error, it couldnt be configured.
Here the logs
Build:
Preparing...
Cloning evdi build files...
Checking evdi dependencies...
Warning: evdi-1.9.1-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
Building evdi...
==> Making package: evdi 1.9.1-1 (Fr 03 Sep 2021 21:33:14 CEST)
==> Retrieving sources...
-> Found evdi-1.9.1-1.tar.gz
==> Validating source files with md5sums...
evdi-1.9.1-1.tar.gz ... Passed
==> Extracting sources...
-> Extracting evdi-1.9.1-1.tar.gz with bsdtar
==> Starting prepare()...
==> Starting build()...
cc -I../module -std=gnu99 -fPIC -D_FILE_OFFSET_BITS=64 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -c -o evdi_lib.o evdi_lib.c
evdi_lib.c: In function ‘find_unused_card_for’:
evdi_lib.c:475:44: warning: ‘%s’ directive output may be truncated writing up to 4095 bytes into a region of size 4089 [-Wformat-truncation=]
475 | snprintf(link_path, PATH_MAX - 7, "%s/device", dirname);
521 | if (!is_correct_parent_device(evdi_path, parent_device))
In file included from /usr/include/stdio.h:866,
from evdi_lib.c:17:
/usr/include/bits/stdio2.h:71:10: note: ‘__builtin___snprintf_chk’ output between 8 and 4103 bytes into a destination of size 4089
71 | return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
72 | __glibc_objsize (__s), __fmt,
73 | __va_arg_pack ());
evdi_lib.c:526:74: warning: ‘/drm’ directive output may be truncated writing 4 bytes into a region of size between 1 and 4096 [-Wformat-truncation=]
526 | snprintf(evdi_drm_path, PATH_MAX - strlen(evdi_path), "%s/drm", evdi_path);
from evdi_lib.c:17:
/usr/include/bits/stdio2.h:71:10: note: ‘__builtin___snprintf_chk’ output between 5 and 4100 bytes into a destination of size 4096
evdi_lib.c: In function ‘evdi_check_device’:
evdi_lib.c:619:50: warning: ‘/drm/card’ directive output may be truncated writing 9 bytes into a region of size between 1 and 4096 [-Wformat-truncation=]
619 | snprintf(card_path, PATH_MAX, "%s/drm/card%d", path, device);
from evdi_lib.c:17:
/usr/include/bits/stdio2.h:71:10: note: ‘__builtin___snprintf_chk’ output between 11 and 4116 bytes into a destination of size 4096
cc evdi_lib.o -shared -Wl,-soname,libevdi.so.0 -o libevdi.so.1.9.1 -lc -lgcc -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now
cp libevdi.so.1.9.1 libevdi.so
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "evdi"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding changelog file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: evdi 1.9.1-1 (Fr 03 Sep 2021 21:33:17 CEST)
==> Cleaning up...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules
==> Unable to remove module evdi/1.9.1 for kernel 5.13.12-1-MANJARO: Not found in dkms status output.
DKMS remove...
Deleting module version: 1.9.1
completely from the DKMS tree.
Done.
Configuring evdi...
DKMS install...
Creating symlink /var/lib/dkms/evdi/1.9.1/source ->
/usr/src/evdi-1.9.1
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j8 KERNELRELEASE=5.13.12-1-MANJARO all INCLUDEDIR=/lib/modules/5.13.12-1-MANJARO/build/include KVERSION=5.13.12-1-MANJARO DKMS_BUILD=1....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.13.12-1-MANJARO (x86_64)
Error while configuring evdi
Consult /var/lib/dkms/evdi/1.9.1/build/make.log for more information.
Error: evdi: command failed to execute correctly
Arming ConditionNeedsUpdate...
Install DKMS modules
==> dkms install --no-depmod -m evdi -v 1.9.1 -k 5.13.12-1-MANJARO
==> Warning, `dkms install --no-depmod -m evdi -v 1.9.1 -k 5.13.12-1-MANJARO' returned 10
==> depmod 5.13.12-1-MANJARO
Refreshing PackageKit...
evdi Log
DKMS make.log for evdi-1.9.1 for kernel 5.13.12-1-MANJARO (x86_64)
Fr 3. Sep 21:25:26 CEST 2021
make KBUILD_VERBOSE=1 M=/var/lib/dkms/evdi/1.9.1/build SUBDIRS=/var/lib/dkms/evdi/1.9.1/build SRCROOT=/var/lib/dkms/evdi/1.9.1/build CONFIG_MODULE_SIG= -C /lib/modules/5.13.12-1-MANJARO/build modules
make[1]: Entering directory '/usr/lib/modules/5.13.12-1-MANJARO/build'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
make -f ./scripts/Makefile.build obj=/var/lib/dkms/evdi/1.9.1/build \
single-build= \
need-builtin=1 need-modorder=1
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_platform_drv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_platform_drv"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_platform_drv.o /var/lib/dkms/evdi/1.9.1/build/evdi_platform_drv.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_platform_dev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_platform_dev"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_platform_dev.o /var/lib/dkms/evdi/1.9.1/build/evdi_platform_dev.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_sysfs.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_sysfs"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_sysfs.o /var/lib/dkms/evdi/1.9.1/build/evdi_sysfs.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_modeset.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_modeset"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_modeset.o /var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_connector.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_connector"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_connector.o /var/lib/dkms/evdi/1.9.1/build/evdi_connector.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_encoder.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_encoder"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_encoder.o /var/lib/dkms/evdi/1.9.1/build/evdi_encoder.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_drm_drv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_drm_drv"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_drm_drv.o /var/lib/dkms/evdi/1.9.1/build/evdi_drm_drv.c
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_fb.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_fb"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_fb.o /var/lib/dkms/evdi/1.9.1/build/evdi_fb.c
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_sysfs.o
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_gem.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_gem"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_gem.o /var/lib/dkms/evdi/1.9.1/build/evdi_gem.c
/var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c:331:26: error: initialization of ‘void (*)(struct drm_plane *, struct drm_atomic_state *)’ from incompatible pointer type ‘void (*)(struct drm_plane *, struct drm_plane_state *)’ [-Werror=incompatible-pointer-types]
331 | .atomic_update = evdi_plane_atomic_update,
/var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c:331:26: note: (near initialization for ‘evdi_plane_helper_funcs.atomic_update’)
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_platform_drv.o
gcc -Wp,-MMD,/var/lib/dkms/evdi/1.9.1/build/.evdi_painter.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/compiler-version.h -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -fmacro-prefix-map=./= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -fcf-protection=none -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 -fno-allow-store-data-races -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-stack-clash-protection -g -gdwarf-4 -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-zero-length-bounds -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -fplugin=./scripts/gcc-plugins/structleak_plugin.so -fplugin-arg-structleak_plugin-byref-all -DSTRUCTLEAK_PLUGIN -Iinclude/drm -DMODULE -DKBUILD_BASENAME='"evdi_painter"' -DKBUILD_MODNAME='"evdi"' -D__KBUILD_MODNAME=kmod_evdi -c -o /var/lib/dkms/evdi/1.9.1/build/evdi_painter.o /var/lib/dkms/evdi/1.9.1/build/evdi_painter.c
/var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c:332:23: error: ‘drm_gem_fb_prepare_fb’ undeclared here (not in a function); did you mean ‘drm_gem_fb_create’?
332 | .prepare_fb = drm_gem_fb_prepare_fb
| drm_gem_fb_create
/var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c:336:26: error: initialization of ‘void (*)(struct drm_plane *, struct drm_atomic_state *)’ from incompatible pointer type ‘void (*)(struct drm_plane *, struct drm_plane_state *)’ [-Werror=incompatible-pointer-types]
336 | .atomic_update = evdi_cursor_atomic_update,
/var/lib/dkms/evdi/1.9.1/build/evdi_modeset.c:336:26: note: (near initialization for ‘evdi_cursor_helper_funcs.atomic_update’)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/evdi/1.9.1/build/evdi_modeset.o] Error 1
make[2]: *** Waiting for unfinished jobs....
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_drm_drv.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_platform_dev.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_connector.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_encoder.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_fb.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_gem.o
./tools/objtool/objtool orc generate --module --no-fp --retpoline --uaccess /var/lib/dkms/evdi/1.9.1/build/evdi_painter.o
make[1]: *** [Makefile:1862: /var/lib/dkms/evdi/1.9.1/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.13.12-1-MANJARO/build'
make: *** [Makefile:28: all] Error 2
