I’m trying to install Displaylink 5.3.1.34.run driver (to be able to use a second monitor).
Terminal message indicates a message that there is a missing component, “libdrm”, but I looked in pacman software manger and libdrm is installed. What can I do next?
Thanks for your help
Please post your system information as outlined here:
Also please post the output of the following while the monitor is attached:
lspci | grep VGA
That’s available in the AUR as displaylink:
pamac build displaylink
Hello Yochanan,
thanks so much for your feedback. Your recommendation fixed my issue!
Regards
