no found display.
journalctl -b-1 -p4 --no-pager
lip 21 23:10:19 aero16ye5 kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
lip 21 23:10:19 aero16ye5 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
lip 21 23:10:19 aero16ye5 kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
lip 21 23:10:19 aero16ye5 kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
lip 21 23:10:19 aero16ye5 kernel: pnp 00:02: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
lip 21 23:10:19 aero16ye5 kernel: nvme nvme0: missing or invalid SUBNQN field.
lip 21 23:10:19 aero16ye5 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20200925/psargs-330)
lip 21 23:10:19 aero16ye5 kernel: ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
lip 21 23:10:20 aero16ye5 systemd[1]: logrotate.timer: Not using persistent file timestamp Thu 2022-07-21 23:37:17 CEST as it is in the future.
lip 21 23:10:20 aero16ye5 systemd[1]: man-db.timer: Not using persistent file timestamp Thu 2022-07-21 23:38:11 CEST as it is in the future.
lip 21 23:10:20 aero16ye5 systemd[1]: pkgfile-update.timer: Not using persistent file timestamp Thu 2022-07-21 23:37:17 CEST as it is in the future.
lip 21 23:10:20 aero16ye5 systemd[1]: shadow.timer: Not using persistent file timestamp Thu 2022-07-21 23:37:17 CEST as it is in the future.
lip 21 23:10:20 aero16ye5 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
lip 21 23:10:21 aero16ye5 kernel: thunderbolt 0000:00:0d.2: 0: drom uid crc8 mismatch (expected: 0x0, got: 0xdb), aborting
lip 21 23:10:21 aero16ye5 kernel: thunderbolt 0-0: reading DROM failed
lip 21 23:10:21 aero16ye5 kernel: thunderbolt: probe of 0000:00:0d.2 failed with error -5
lip 21 23:10:21 aero16ye5 kernel: iwlwifi 0000:58:00.0: api flags index 2 larger than supported by driver
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: Timeout waiting for PNVM load!
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: Failed to start RT ucode: -110
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: iwl_trans_send_cmd bad state = 0
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: Failed to run INIT ucode: -110
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: retry init count 0
lip 21 23:10:22 aero16ye5 kernel: iwlwifi 0000:58:00.0: retry init count 1
lip 21 23:10:23 aero16ye5 kernel: iwlwifi 0000:58:00.0: Timeout waiting for PNVM load!
lip 21 23:10:23 aero16ye5 kernel: iwlwifi 0000:58:00.0: Failed to start RT ucode: -110
lip 21 23:10:23 aero16ye5 kernel: iwlwifi 0000:58:00.0: iwl_trans_send_cmd bad state = 0
lip 21 23:10:23 aero16ye5 kernel: iwlwifi 0000:58:00.0: Failed to run INIT ucode: -110
lip 21 23:10:23 aero16ye5 kernel: iwlwifi 0000:58:00.0: retry init count 2
lip 21 23:10:26 aero16ye5 kernel: kauditd_printk_skb: 46 callbacks suppressed
lip 21 23:10:26 aero16ye5 kernel: Bluetooth: hci0: Unsupported Intel hardware variant (23)
lip 21 23:10:26 aero16ye5 kernel: asus_wmi: ASUS Management GUID not found
lip 21 23:10:31 aero16ye5 kernel: kauditd_printk_skb: 66 callbacks suppressed
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (--) Log file renamed from "/var/log/Xorg.pid-960.log" to "/var/log/Xorg.0.log"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X.Org X Server 1.21.1.3
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X Protocol Version 11, Revision 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Current version of pixman: 0.40.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: to make sure that you have the latest version.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:31 2022
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) No screen section available. Using defaults.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Using a default monitor configuration.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Automatically adding devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Automatically enabling devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Automatically adding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Automatically binding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Entry deleted from font path.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) FontPath set to:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: /usr/share/fonts/TTF
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) Module ABI versions:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X.Org Video Driver: 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X.Org XInput driver : 24.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: X.Org Server Extension : 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (++) using VT number 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) LoadModule: "glx"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) LoadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Module class: X.Org Video Driver
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) LoadModule: "fbdev"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) LoadModule: "vesa"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) Warning, couldn't open module vesa
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (II) UnloadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Fatal server error:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) no screens found(EE)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: Please consult the The X.Org Foundation support
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: at http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: for help.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[960]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[958]: Unable to run X server
lip 21 23:10:31 aero16ye5 gdm-launch-environment][944]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (--) Log file renamed from "/var/log/Xorg.pid-968.log" to "/var/log/Xorg.0.log"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X.Org X Server 1.21.1.3
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X Protocol Version 11, Revision 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Current version of pixman: 0.40.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: to make sure that you have the latest version.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:31 2022
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) No screen section available. Using defaults.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Using a default monitor configuration.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Automatically adding devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Automatically enabling devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Automatically adding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Automatically binding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Entry deleted from font path.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) FontPath set to:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: /usr/share/fonts/TTF
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) Module ABI versions:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X.Org Video Driver: 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X.Org XInput driver : 24.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: X.Org Server Extension : 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (++) using VT number 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) LoadModule: "glx"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) LoadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Module class: X.Org Video Driver
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) LoadModule: "fbdev"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) LoadModule: "vesa"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) Warning, couldn't open module vesa
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (II) UnloadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Fatal server error:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) no screens found(EE)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: Please consult the The X.Org Foundation support
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: at http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: for help.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[968]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[966]: Unable to run X server
lip 21 23:10:31 aero16ye5 gdm-launch-environment][963]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (--) Log file renamed from "/var/log/Xorg.pid-974.log" to "/var/log/Xorg.0.log"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X.Org X Server 1.21.1.3
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X Protocol Version 11, Revision 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Current version of pixman: 0.40.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: to make sure that you have the latest version.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:31 2022
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) No screen section available. Using defaults.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Using a default monitor configuration.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Automatically adding devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Automatically enabling devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Automatically adding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Automatically binding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Entry deleted from font path.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) FontPath set to:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: /usr/share/fonts/TTF
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) Module ABI versions:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X.Org Video Driver: 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X.Org XInput driver : 24.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: X.Org Server Extension : 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (++) using VT number 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) LoadModule: "glx"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) LoadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Module class: X.Org Video Driver
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) LoadModule: "fbdev"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) LoadModule: "vesa"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) Warning, couldn't open module vesa
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (II) UnloadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Fatal server error:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) no screens found(EE)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: Please consult the The X.Org Foundation support
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: at http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: for help.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[974]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[972]: Unable to run X server
lip 21 23:10:31 aero16ye5 gdm-launch-environment][969]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (--) Log file renamed from "/var/log/Xorg.pid-980.log" to "/var/log/Xorg.0.log"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X.Org X Server 1.21.1.3
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X Protocol Version 11, Revision 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Current version of pixman: 0.40.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: to make sure that you have the latest version.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:31 2022
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) No screen section available. Using defaults.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Using a default monitor configuration.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Automatically adding devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Automatically enabling devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Automatically adding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Automatically binding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Entry deleted from font path.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) FontPath set to:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: /usr/share/fonts/TTF
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) Module ABI versions:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X.Org Video Driver: 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X.Org XInput driver : 24.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: X.Org Server Extension : 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (++) using VT number 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) LoadModule: "glx"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) LoadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Module class: X.Org Video Driver
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) LoadModule: "fbdev"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) LoadModule: "vesa"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) Warning, couldn't open module vesa
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (II) UnloadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Fatal server error:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) no screens found(EE)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: Please consult the The X.Org Foundation support
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: at http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: for help.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[980]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[978]: Unable to run X server
lip 21 23:10:31 aero16ye5 gdm-launch-environment][975]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (--) Log file renamed from "/var/log/Xorg.pid-986.log" to "/var/log/Xorg.0.log"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X.Org X Server 1.21.1.3
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X Protocol Version 11, Revision 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Current version of pixman: 0.40.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: to make sure that you have the latest version.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:31 2022
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) No screen section available. Using defaults.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Using a default monitor configuration.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Automatically adding devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Automatically enabling devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Automatically adding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Automatically binding GPU devices
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Entry deleted from font path.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) FontPath set to:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: /usr/share/fonts/TTF
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) Module ABI versions:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X.Org Video Driver: 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X.Org XInput driver : 24.4
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: X.Org Server Extension : 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (++) using VT number 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_36
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) LoadModule: "glx"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) LoadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Module class: X.Org Video Driver
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) LoadModule: "fbdev"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) LoadModule: "vesa"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) Warning, couldn't open module vesa
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (II) UnloadModule: "modesetting"
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Fatal server error:
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) no screens found(EE)
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: Please consult the The X.Org Foundation support
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: at http://wiki.x.org
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: for help.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[986]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:31 aero16ye5 /usr/lib/gdm-x-session[984]: Unable to run X server
lip 21 23:10:31 aero16ye5 gdm-launch-environment][981]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (--) Log file renamed from "/var/log/Xorg.pid-992.log" to "/var/log/Xorg.0.log"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X.Org X Server 1.21.1.3
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X Protocol Version 11, Revision 0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Current version of pixman: 0.40.0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: to make sure that you have the latest version.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:32 2022
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) No screen section available. Using defaults.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Using a default monitor configuration.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Automatically adding devices
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Automatically enabling devices
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Automatically adding GPU devices
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Automatically binding GPU devices
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Entry deleted from font path.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) FontPath set to:
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: /usr/share/fonts/TTF
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) Module ABI versions:
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X.Org Video Driver: 25.2
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X.Org XInput driver : 24.4
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: X.Org Server Extension : 10.0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (++) using VT number 1
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_37
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) LoadModule: "glx"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) LoadModule: "modesetting"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Module class: X.Org Video Driver
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) LoadModule: "fbdev"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) LoadModule: "vesa"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) Warning, couldn't open module vesa
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (II) UnloadModule: "modesetting"
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Fatal server error:
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) no screens found(EE)
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: Please consult the The X.Org Foundation support
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: at http://wiki.x.org
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: for help.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[992]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:32 aero16ye5 /usr/lib/gdm-x-session[990]: Unable to run X server
lip 21 23:10:32 aero16ye5 gdm-launch-environment][987]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:42 aero16ye5 kernel: kauditd_printk_skb: 37 callbacks suppressed
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (--) Log file renamed from "/var/log/Xorg.pid-1019.log" to "/var/log/Xorg.0.log"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X.Org X Server 1.21.1.3
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X Protocol Version 11, Revision 0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Current version of pixman: 0.40.0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: to make sure that you have the latest version.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:51 2022
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) No screen section available. Using defaults.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Using a default monitor configuration.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Automatically adding devices
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Automatically enabling devices
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Automatically adding GPU devices
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Automatically binding GPU devices
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Entry deleted from font path.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) FontPath set to:
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: /usr/share/fonts/TTF
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) Module ABI versions:
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X.Org Video Driver: 25.2
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X.Org XInput driver : 24.4
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: X.Org Server Extension : 10.0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (++) using VT number 1
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_38
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) LoadModule: "glx"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) LoadModule: "modesetting"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Module class: X.Org Video Driver
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) LoadModule: "fbdev"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) LoadModule: "vesa"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) Warning, couldn't open module vesa
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (II) UnloadModule: "modesetting"
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Fatal server error:
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) no screens found(EE)
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: Please consult the The X.Org Foundation support
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: at http://wiki.x.org
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: for help.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1019]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:51 aero16ye5 /usr/lib/gdm-x-session[1017]: Unable to run X server
lip 21 23:10:51 aero16ye5 gdm-launch-environment][1003]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (--) Log file renamed from "/var/log/Xorg.pid-1029.log" to "/var/log/Xorg.0.log"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X.Org X Server 1.21.1.3
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X Protocol Version 11, Revision 0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Current version of pixman: 0.40.0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: to make sure that you have the latest version.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:52 2022
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) No screen section available. Using defaults.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Using a default monitor configuration.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Automatically adding devices
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Automatically enabling devices
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Automatically adding GPU devices
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Automatically binding GPU devices
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Entry deleted from font path.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) FontPath set to:
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: /usr/share/fonts/TTF
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) Module ABI versions:
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X.Org Video Driver: 25.2
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X.Org XInput driver : 24.4
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: X.Org Server Extension : 10.0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (++) using VT number 1
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_310
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) LoadModule: "glx"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) LoadModule: "modesetting"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Module class: X.Org Video Driver
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) LoadModule: "fbdev"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) LoadModule: "vesa"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) Warning, couldn't open module vesa
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (II) UnloadModule: "modesetting"
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Fatal server error:
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) no screens found(EE)
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: Please consult the The X.Org Foundation support
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: at http://wiki.x.org
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: for help.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1029]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:52 aero16ye5 /usr/lib/gdm-x-session[1027]: Unable to run X server
lip 21 23:10:52 aero16ye5 gdm-launch-environment][1024]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:10:55 aero16ye5 kernel: kauditd_printk_skb: 21 callbacks suppressed
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (--) Log file renamed from "/var/log/Xorg.pid-1037.log" to "/var/log/Xorg.0.log"
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X.Org X Server 1.21.1.3
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X Protocol Version 11, Revision 0
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Current version of pixman: 0.40.0
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Before reporting problems, check http://wiki.x.org
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: to make sure that you have the latest version.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:10:55 2022
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) No Layout section. Using the first Screen section.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) No screen section available. Using defaults.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (**) | |-->Monitor "<default monitor>"
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Using a default monitor configuration.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Automatically adding devices
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Automatically enabling devices
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Automatically adding GPU devices
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Automatically binding GPU devices
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: Entry deleted from font path.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) FontPath set to:
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: /usr/share/fonts/TTF
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) Module ABI versions:
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X.Org ANSI C Emulation: 0.4
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X.Org Video Driver: 25.2
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X.Org XInput driver : 24.4
lip 21 23:10:55 aero16ye5 /usr/lib/gdm-x-session[1037]: X.Org Server Extension : 10.0
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (++) using VT number 1
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_311
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) LoadModule: "glx"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) LoadModule: "modesetting"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: Module class: X.Org Video Driver
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) LoadModule: "fbdev"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) Warning, couldn't open module fbdev
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) LoadModule: "vesa"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) Warning, couldn't open module vesa
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (WW) Falling back to old probe method for modesetting
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (II) UnloadModule: "modesetting"
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: Fatal server error:
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) no screens found(EE)
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: Please consult the The X.Org Foundation support
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: at http://wiki.x.org
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: for help.
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1037]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:10:56 aero16ye5 /usr/lib/gdm-x-session[1035]: Unable to run X server
lip 21 23:10:56 aero16ye5 gdm-launch-environment][1032]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (--) Log file renamed from "/var/log/Xorg.pid-1046.log" to "/var/log/Xorg.0.log"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X.Org X Server 1.21.1.3
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X Protocol Version 11, Revision 0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Current version of pixman: 0.40.0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Before reporting problems, check http://wiki.x.org
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: to make sure that you have the latest version.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Markers: (--) probed, (**) from config file, (==) default setting,
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (++) from command line, (!!) notice, (II) informational,
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:11:00 2022
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) No Layout section. Using the first Screen section.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) No screen section available. Using defaults.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (**) |-->Screen "Default Screen Section" (0)
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (**) | |-->Monitor "<default monitor>"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) No monitor specified for screen "Default Screen Section".
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Using a default monitor configuration.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Automatically adding devices
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Automatically enabling devices
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Automatically adding GPU devices
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Automatically binding GPU devices
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Max clients allowed: 256, resource mask: 0x1fffff
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) The directory "/usr/share/fonts/misc" does not exist.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Entry deleted from font path.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) FontPath set to:
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: /usr/share/fonts/TTF
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) ModulePath set to "/usr/lib/xorg/modules"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) The server relies on udev to provide the list of input devices.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: If no devices become available, reconfigure udev or disable AutoAddDevices.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) Module ABI versions:
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X.Org ANSI C Emulation: 0.4
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X.Org Video Driver: 25.2
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X.Org XInput driver : 24.4
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: X.Org Server Extension : 10.0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (++) using VT number 1
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_312
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) LoadModule: "glx"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) Module glx: vendor="X.Org Foundation"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: compiled for 1.21.1.3, module version = 1.0.0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: ABI class: X.Org Server Extension, version 10.0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Matched modesetting as autoconfigured driver 0
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Matched fbdev as autoconfigured driver 1
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Matched vesa as autoconfigured driver 2
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (==) Assigned the driver to the xf86ConfigLayout
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) LoadModule: "modesetting"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) Module modesetting: vendor="X.Org Foundation"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: compiled for 1.21.1.3, module version = 1.21.1
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Module class: X.Org Video Driver
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: ABI class: X.Org Video Driver, version 25.2
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) LoadModule: "fbdev"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) Warning, couldn't open module fbdev
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Failed to load module "fbdev" (module does not exist, 0)
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) LoadModule: "vesa"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) Warning, couldn't open module vesa
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Failed to load module "vesa" (module does not exist, 0)
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) open /dev/dri/card0: No such file or directory
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (WW) Falling back to old probe method for modesetting
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Screen 0 deleted because of no matching config section.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (II) UnloadModule: "modesetting"
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Device(s) detected, but none match those in the config file.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Fatal server error:
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) no screens found(EE)
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: Please consult the The X.Org Foundation support
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: at http://wiki.x.org
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: for help.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1046]: (EE) Server terminated with error (1). Closing log file.
lip 21 23:11:00 aero16ye5 /usr/lib/gdm-x-session[1044]: Unable to run X server
lip 21 23:11:00 aero16ye5 gdm-launch-environment][1041]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
lip 21 23:11:06 aero16ye5 kernel: kauditd_printk_skb: 9 callbacks suppressed
lip 21 23:11:07 aero16ye5 systemd-xdg-autostart-generator[1054]: /home/pkacprzyk/.config/autostart/auto:1: Assignment outside of section. Ignoring.
lip 21 23:11:07 aero16ye5 systemd-xdg-autostart-generator[1054]: Configuration file /home/pkacprzyk/.config/autostart/jetbrains-toolbox.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
lip 21 23:11:07 aero16ye5 systemd-xdg-autostart-generator[1054]: /home/pkacprzyk/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, error parsing Exec= line: No such file or directory
lip 21 23:11:30 aero16ye5 kernel: kauditd_printk_skb: 6 callbacks suppressed
Xorg.0.log:
[ 53.624]
[ 53.624] Current Operating System: Linux aero16ye5 5.10.129-1-MANJARO #1 SMP PREEMPT Thu Jul 7 16:56:51 UTC 2022 x86_64
[ 53.624] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cd608078-1418-4a39-b5c9-3e7d310b5ab3 rw resume=UUID=a40ff7b0-a24e-469c-9fec-3337ceb79877 quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
[ 53.624]
[ 53.624] Current version of pixman: 0.40.0
[ 53.625] Before reporting problems, check http://wiki.x.org
[ 53.625] Markers: (--) probed, (**) from config file, (==) default setting,
[ 53.625] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 21 23:11:10 2022
[ 53.625] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 53.625] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 53.625] (==) No Layout section. Using the first Screen section.
[ 53.625] (==) No screen section available. Using defaults.
[ 53.625] (**) |-->Screen "Default Screen Section" (0)
[ 53.625] (**) | |-->Monitor "<default monitor>"
[ 53.625] (==) No monitor specified for screen "Default Screen Section".
[ 53.625] (==) Automatically adding devices
[ 53.625] (==) Automatically enabling devices
[ 53.625] (==) Automatically adding GPU devices
[ 53.625] (==) Automatically binding GPU devices
[ 53.625] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 53.625] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 53.625] Entry deleted from font path.
[ 53.625] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 53.625] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 53.625] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 53.625] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 53.625] (==) FontPath set to:
[ 53.625] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 53.625] (II) The server relies on udev to provide the list of input devices.
[ 53.625] (II) Module ABI versions:
[ 53.625] X.Org ANSI C Emulation: 0.4
[ 53.625] X.Org Video Driver: 25.2
[ 53.625] X.Org XInput driver : 24.4
[ 53.625] X.Org Server Extension : 10.0
[ 53.626] (++) using VT number 2
[ 53.629] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_313
[ 53.631] (--) PCI:*(0@0:2:0) 8086:46a6:1458:86e0 rev 12, Mem @ 0x644c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 53.631] (--) PCI: (1@0:0:0) 10de:2420:1458:86e0 rev 161, Mem @ 0x6d000000/16777216, 0x6000000000/17179869184, 0x6400000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 53.631] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 53.631] (II) LoadModule: "glx"
[ 53.631] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 53.632] (II) Module glx: vendor="X.Org Foundation"
[ 53.632] compiled for 1.21.1.3, module version = 1.0.0
[ 53.632] ABI class: X.Org Server Extension, version 10.0
[ 53.632] (==) Matched modesetting as autoconfigured driver 0
[ 53.632] (==) Matched fbdev as autoconfigured driver 1
[ 53.632] (==) Matched vesa as autoconfigured driver 2
[ 53.632] (==) Assigned the driver to the xf86ConfigLayout
[ 53.632] (II) LoadModule: "modesetting"
[ 53.632] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 53.633] (II) Module modesetting: vendor="X.Org Foundation"
[ 53.633] compiled for 1.21.1.3, module version = 1.21.1
[ 53.633] Module class: X.Org Video Driver
[ 53.633] ABI class: X.Org Video Driver, version 25.2
[ 53.633] (II) LoadModule: "fbdev"
[ 53.633] (WW) Warning, couldn't open module fbdev
[ 53.633] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 53.633] (II) LoadModule: "vesa"
[ 53.633] (WW) Warning, couldn't open module vesa
[ 53.633] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 53.633] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 53.633] (EE) open /dev/dri/card0: No such file or directory
[ 53.633] (WW) Falling back to old probe method for modesetting
[ 53.633] (EE) Screen 0 deleted because of no matching config section.
[ 53.633] (II) UnloadModule: "modesetting"
[ 53.633] (EE) Device(s) detected, but none match those in the config file.
[ 53.633] (EE)
Fatal server error:
[ 53.633] (EE) no screens found(EE)
[ 53.633] (EE)
for help.
[ 53.633] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 53.633] (EE)
[ 53.635] (EE) Server terminated with error (1). Closing log file.
