Thanks for your reply. Sorry that I did not include sufficient information.
Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=5bd51f81-b413-442e-ae9a-d19ee74aaec5 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Mini-pc Mobo: AZW model: SER v: V01 serial: <superuser required>
part-nu: SER uuid: <superuser required> UEFI: American Megatrends LLC.
v: 1.15_P4C7M43_Blink date: 09/17/2022
System RAM: total: 32 GiB available: 28.29 GiB used: 3.21 GiB (11.3%)
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT16G4SFS832A.M8FF serial: <filter>
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500012
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1108 min/max: 400/4280 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1108 2: 1108 3: 1108
4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108 12: 1108
bogomips: 79081
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-2
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 38.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-2 model: AOC 24B2W1 serial: <filter> built: 2020
res: 1920x1080 dpi: 93 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
x: 0.306 y: 0.627 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: X11-0 res: mode: 1024x768 hz: 60 scale: 100% (1) size: N/A
modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.6-arch1.1
renoir ACO DRM 3.61 6.12.39-1-MANJARO) device-ID: 1002:1638
memory: 2.93 GiB unified: no display-ID: :2.0
API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.1.6-arch1.1
device-ID: 1002:1638 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Realtek driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-1:2 chip-ID: 045e:0745 class-ID: 0300
Device-2: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 0e8d:0608
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 5.91 TiB used: 2.73 TiB (46.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S8H40104 temp: 30.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20NMVW-11EDZS6 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5200 serial: <filter> fw-rev: 1014 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40NDZW-11MR8S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1023 scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 20.48 GiB (35.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: root
uuid: 5bd51f81-b413-442e-ae9a-d19ee74aaec5
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
uuid: FA83-0B46
ID-3: /external-2tb raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
used: 1.45 TiB (81.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: WD2GB
uuid: 8bc1a602-df98-408d-ad8e-7de53c330dd9
ID-4: /external-4tb raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 1.12 TiB (31.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: WD-4TB
uuid: b3369545-2e6b-4888-ab11-3488c95d8cc9
ID-5: /home raw-size: 371.72 GiB size: 364.82 GiB (98.14%)
used: 121.55 GiB (33.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: home uuid: 63e182e8-02de-4b45-ac5e-9f4a1b7141de
ID-6: /synology/movie-library raw-size: N/A size: 13.95 TiB
used: 7.89 TiB (56.6%) fs: nfs
remote: 192.168.50.200:/volume1/media-library/nas-video
ID-7: /synology/music-library raw-size: N/A size: 13.95 TiB
remote: 192.168.50.200:/volume1/media-library/nas-music
ID-8: /var raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
used: 19.26 GiB (67.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: var uuid: dd1ae218-94be-4034-89ae-cde9745d984f
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 5.86 GiB fs: ext4 label: swap
uuid: ddc2f913-60dd-4f3f-8ee9-d7d303d57d3f
Hub-2: 1-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 1-2.3:3 info: TG3 Deck 108 Hassium type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0a34:0212 class-ID: 0300
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 2-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
Device-1: 2-2.1:3 info: Western Digital Elements SE 2622
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 1058:2622 class-ID: 0806 serial: <filter>
Device-2: 2-2.4:4 info: Western Digital Elements 25A2 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:25a2 class-ID: 0806
serial: <filter>
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
Device-2: 3-3:4 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 46.9 C mobo: 44.0 C gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): N/A
Packages: 1866 pm: pacman pkgs: 1850 libs: 391 tools: pamac,yay pm: flatpak
pkgs: 16
Active pacman repo servers in: /etc/pacman.conf
1: https://mega.nz/linux/repo/Arch_Extra/$arch
1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 325
1: cpu: 12.8% command: vivaldi-bin pid: 18602 mem: 536.9 MiB (1.8%)
2: cpu: 10.1% command: vivaldi-bin pid: 18903 mem: 183.7 MiB (0.6%)
3: cpu: 10.0% command: vivaldi-bin pid: 18785 mem: 280.6 MiB (0.9%)
4: cpu: 6.6% command: kitty pid: 19365 mem: 204.8 MiB (0.7%)
5: cpu: 5.3% command: vivaldi-bin pid: 18759 mem: 231.9 MiB (0.8%)
Memory top: 5 of 325
1: mem: 536.9 MiB (1.8%) command: vivaldi-bin pid: 18602 cpu: 12.8%
2: mem: 489.5 MiB (1.6%) command: plasmashell pid: 3268 cpu: 1.1%
3: mem: 288.9 MiB (0.9%) command: dropbox pid: 3368 cpu: 0.2%
4: mem: 280.6 MiB (0.9%) command: vivaldi-bin pid: 18785 cpu: 10.0%
5: mem: 263.6 MiB (0.9%) command: vivaldi-bin pid: 18655 cpu: 4.2%
Processes: 325 Power: uptime: 3h 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 11.29 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.0
running-in: kitty inxi: 3.3.38
