Display Settings reset upon reboot - Phosh Beta 23
I am currently using Phosh 23 Beta on PinePhone. I change my display on the phone to 150% but on reboot it goes back to 200%. This doesn’t happen on Plasma 10 Beta but it also happens on Mobian. If anyone has any Ideas I would love to hear them.
Thanks.
Regardless the scale you set it will get back to 200% upon reboot. Was always like that on Phosh if i recall correctly.
If you set to 175% and you close and open Settings again, it will show 100% value yet is not that, then if reboot, all back to 200%.
Not related. Settings are different and also different compositor between Phosh and PlaMo.
You can open up an issue here
