Display resolution and display scale can not be changed in X11
Wayland is fine. Actually i might stay at wayland as it seems like kde had done a good job at making it much more stable.
But if you are on X11 and want to change resolution or scale, you are out of luck. Resolution change is an instant crash (unrecoverable). It goes back to the default resolution after a reboot. Display scale change doesn’t cause a crash but is not reflected on the actual monitor.
