Hi all,
Since about a month ago I’ve noticed my screen has a bit of lag when changing the display suddenly. When I move windows around, pop one on top of the other or scroll through a file too quickly this happens. Interestingly, playing videos does not prompt this pixelation. These pixels only last briefly but it’s mildly irritating. I’ve included a picture below of the screen when this happens.
Is anybody able to shed any light on this?
System details:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4727d3b5-3d75-4873-a543-c1d16f5710b3 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.7.0
date: 05/11/2020
ID-1: BAT0 charge: 29.9 Wh (91.2%) condition: 32.8/56.0 Wh (58.5%)
volts: 10.4 min: 11.4 model: BYD DELL CP6DF99 type: Li-poly serial: <filter>
status: Discharging
RAM: total: 7.41 GiB used: 5.33 GiB (71.9%)
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 3260 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3260 2: 2984
3: 3135 4: 3054 5: 3055 6: 3203 7: 3043 8: 3208 9: 3236 10: 3212 11: 3257
12: 2980
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Local Storage: total: 238.47 GiB used: 57.6 GiB (24.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON
model: CL1-3D256-Q11 NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 22301111 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 62.87 GiB (98.24%) used: 57.51 GiB (91.5%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 4727d3b5-3d75-4873-a543-c1d16f5710b3
ID-2: /boot/efi raw-size: 680 MiB size: 676 MiB (99.41%)
used: 91.7 MiB (13.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: DE0D-CC70
ID-1: swap-1 type: file size: 5 GiB used: 2.3 GiB (45.9%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 155.08 GiB fs: bitlocker
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 406AD2376AD22984
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 16.36 GiB fs: ntfs label: Image
uuid: C6B2D273B2D26787
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 1.28 GiB fs: ntfs
label: DELLSUPPORT uuid: A660AEC460AE9B17
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2403 fan-2: 2413
Processes: 397 Uptime: 2h 52m wakeups: 5871 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1533 pacman: 1507 lib: 372
flatpak: 13 snap: 13 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
