Hello,
(Apologies for reposting this, the original thread has been closed.)
After the February update, I am having problems with the display.
- Both
xfce4-display-settings
andxrandr
have trouble recognizing a dual monitor set up, not working properly neither automatically nor manually. - In some of those cases, one of the monitors remains black: it is on, you can see the cursor, but no windows nor wallpaper. The cursor can change, so the windows are probably there, but nothing else is rendered.
- After switching display settings, and even if going back to a single monitor, windows start to show problems, like visual artifacts, screen tearing from multiple windows, flickering, etc.
Results can be variable, it is rather inconsistent, so I am struggling to properly identify the problem. It seems to be sometimes triggered by switching between two different external monitors.
The solution provided here (i.e. related to xfce4-screensaver
), in the previous iteration of this thread, was not a solution after all. The same exact problems are still here.
Everything used to work well before the update. I’d be grateful for any suggestions. Thank you for your help.
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f4c906d3-10d5-4463-bf42-2c8deea9b257 rw
resume=UUID=f4c906d3-10d5-4463-bf42-2c8deea9b257 resume_offset=11909120
Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: XPS 13 9360 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 02PG84 v: A00 serial: <superuser required> part-nu: 082A
uuid: <superuser required> UEFI: Dell v: 2.14.2 date: 07/13/2020
ID-1: BAT0 charge: 42.3 Wh (100.0%) condition: 42.3/60.0 Wh (70.5%)
volts: 8.6 min: 7.6 model: SMP DELL TP1GT61 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 32012
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,eDP-1
empty: DP-2 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia Integrated Webcam HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:670c
class-ID: 0e02
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.2:4
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.15 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 509x572mm (20.04x22.52")
s-diag: 766mm (30.14")
Monitor-1: DP-1 pos: primary,top model: Dell P2422HE serial: <filter>
built: 2022 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: bottom model: Sharp 0x1449 built: 2015 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 7.49 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: N/A device-ID: 8086:5917
surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 53.0 C
IF: wlp58s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp57s0u1u3 state: down mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 0cf3:e300 class-ID: e001
Local Storage: total: 476.94 GiB used: 374.78 GiB (78.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: AADA4106 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 50.84 GiB (88.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 418.05 GiB size: 410.42 GiB (98.17%)
used: 323.95 GiB (78.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 63.0 C pch: 52.0 C mobo: 41.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.35 GiB used: 2.89 GiB (18.8%)
Processes: 273 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.13 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1953 libs: 493 tools: pamac,yay Compilers:
gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
