With KDE 6, the display IDs are no longer respected … to be more precise, the simple display numbers changes after a reboot. Display 0 becomes Display 1 and vice versa.
But the output of xrandr and kscreen-doctor always remains the same
HDMI-A-3 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
HDMI-A-1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 530mm x 300mm
HDMI-A-3 is my boot screen and set as primary in KDE 6, however, this no longer works for some applications e.g. after a reboot, cairo-dock and yakuake starts on the secondary display HDMI-A-1, the app configuration is using display numbers e.g. 0 or 1 and after a reboot these display numbers are changed in the config files …
$ inxi -Fxxxz
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland
with: cairo-dock vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0HD5W2 v: A00 serial: <superuser required> part-nu: 06B9
uuid: <superuser required> UEFI-[Legacy]: Dell v: 1.11.1 date: 10/10/2018
Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP smt: enabled
arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3400 min/max: 800/3400 cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 bogomips: 54417
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 ports: active: HDMI-A-1,HDMI-A-3 empty: DP-1, DP-2, DP-3,
HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: intel dri: i965 gpu: i915
d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 display-ID: :0.0
API: Vulkan v: 1.3.279 layers: N/A surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:1912
Device-1: Focusrite-Novation Focusrite Scarlett 2i2 driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 1235:8016
class-ID: fe01
Device-2: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 bus-ID: 1-7:5 chip-ID: fc02:0101 class-ID: 0103
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: active with: 1: a2jmidid status: active
2: nsmd status: off
Server-3: PipeWire v: 1.0.5 status: off with: wireplumber status: off
Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wireguard1 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.39 TiB used: 257.84 GiB (18.2%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk
size: 953.87 GiB speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 916a
scheme: GPT
ID-1: / size: 57.37 GiB used: 31.93 GiB (55.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 511 MiB used: 171.3 MiB (33.5%) fs: vfat dev: /dev/sda1
ID-3: /home size: 152.74 GiB used: 62.11 GiB (40.7%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 31.0 C pch: 47.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.11 GiB used: 3.47 GiB (11.1%)
Processes: 284 Power: uptime: 1h 14m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1671 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
