Display lagging-Hybrid display with nouveau
Hi all,
since the update that deprecated nvidia drivers my display lags ie. I click or scroll in an application, nothing happens on screen and the item is clicked/screen is scrolled only after one to several seconds (the screen is like refreshed but several seconds late).
I’m on kde, kernel 5.4.105
inxi -G
Graphics:  Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
       Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: N/A
       Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
       Display: x11 server: X.Org 1.20.10 driver: loaded: intel resolution: 1920x1080~60Hz
       OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
My graphics drivers after the update :
My drivers before the update
mhwd -li
    mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-430xx-bumblebee            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
It happens only in some apps (I suspect those that make use of the gpu), like dolphin, firefox, spotify.
What are my options here to prevent this from happening ?
Also I have this in system logs :
systemd[1]: Started Bumblebee C Daemon.
bumblebeed[7928]: Module 'nvidia' is not found.
systemd[1]: bumblebeed.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: bumblebeed.service: Failed with result 'exit-code'.
It happens nearly every minute so I guess I should uninstall bumblebee, but I’m afraid I could delete something that shouldn’t be uninstalled in the process through dependencies so I prefer ask here first.
pactree -r bumblebee
bumblebee
├─lib32-primus
└─primus
  └─bumblebee
can you provide
sudo mhwd-kernel -li
sudo ls /etc/mkinitcpio.d/*.preset
Here it is :
Currently running: 5.4.105-1-MANJARO (linux54)
   * linux54
and :
/etc/mkinitcpio.d/linux54.preset
Actually I haven’t tried another kernel yet.
I tend to stay on LTS kernels and I think that 5.4 is the most recent one according to the settings page.
try in first step
open in TTY [CTRL +ALT + F2 to F7 ) or Terminal
sudo mhwd -a pci free 0300
sudo mhwd -a pci nonfree 0300
sudo mhwd-kernel -i linux510
sudo mwd -li
Ok, thanks !
Just to understand what we’re doing at the same time :
First command installs open source drivers,
Second one installs proprietary drivers,
And third one installs kernel 5.10,
Right ?
First and second command are not conflicting ?
I always thought we shouldn’t have both drivers installed at the same time.
driver nvidia & driver nouveau have to be blacklisted from choice nonfree or free
Ok, So first command :
skipping already installed config 'video-linux' for device 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation UHD graphics 630 (Mobile)
Second command installed a bunch of packages :
nvidia-utils, nvidia-prime, lib32-nvidia-utils,linux54-nvidia
Third command went fine.
And last one :
sudo mwd -li
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
Actually display is back to normal and usable now, so thank you !
I don’t know how hybrid display works, I guess Intel card is mostly used ?
Is there a way to tell an app to use Nvidia card, or is it automatic ?
Should I be careful during future manjaro upgrades (for example can the hybrid drivers be uninstalled again etc…) ?
I can see I have 3 files in /etc/modprobe :
ll /etc/modprobe.d
total 12K
-rw-r--r-- 1 root root 105  5 févr.  2019 mhwd-bbswitch.conf
-rw-r--r-- 1 root root 180 27 mars  17:01 mhwd-gpu.conf
-rw-r--r-- 1 root root 194  5 févr.  2019 mhwd-nvidia.conf
You said drivers had to blacklisted to avoid conflicts, is it in those files that it happens ?
Thank you again !
for use nvidia hybrid video see
https://wiki.archlinux.org/index.php/PRIME
