Hello everyone,
I’ve installed a fresh copy of Manjaro with KDE Plasma and while everything worked perfectly out of the box, the display - not quite.
I have a ViewSonic XG2402 1080p 144Hz monitor and GTX 1060 GPU (with proprietary drivers) connected via DisplayPort. After trying to change the refresh rate to 144Hz, the smoothness seems fine, but I can visibly see some weird grayish lines (sometimes looks like a grid of big grey pixels). And the screen itself seems to get a bit lighter. I only see these lines in darker colors with only one exception - I don’t see any of the lines in black color. The lighter the colors are - the harder it is to spot them.
I see this issue with anything above 60 Hz. The higher the refresh rate the more visible it gets.
I’ve tried taking a screenshot and looked at it via another computer/phone - didn’t see those lines.
Since I have windows on another SSD, I’ve booted that up and couldn’t see any lines there either.
I thought maybe I messed up my installation so I’ve booted via live USB twice, one time with open source and the other time with proprietary drivers:
- With the open source drivers the higher I went with the refresh rate the more it started to flicker (observed the same results in normal installation)
- With the proprietary drivers - those same greyish lines appeared.
I don’t know if you’ll be able to see it, but I’ve tried capturing that with my phone. Here are those pics:
System info:
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=bc99d9c0-347c-4ecf-ab31-b05c53f49b14 rw quiet splash
resume=UUID=4044f173-77a2-4af8-a470-da22e7723ed9 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370P D3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z370P D3-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F4 date: 04/03/2018
RAM: total: 15.58 GiB used: 4.34 GiB (27.8%)
Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 912 high: 1370 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 1370 3: 800 4: 800
5: 907 6: 800 bogomips: 43212
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 dpi: 92 size: 531x299mm (20.91x11.77")
diag: 609mm (23.99") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.14 TiB used: 12.94 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 223.79 GiB size: 219.22 GiB (97.96%) used: 12.94 GiB (5.9%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7 label: N/A
uuid: bc99d9c0-347c-4ecf-ab31-b05c53f49b14
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
uuid: 9937-56DA
dev: /dev/nvme1n1p3 maj-min: 259:8 label: swap
uuid: 4044f173-77a2-4af8-a470-da22e7723ed9
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: D07C-4CF7
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs label: N/A
uuid: 0AA47CE1A47CD125
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 8236736636735A5D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 1-7:4 info: SteelSeries ApS Rival 110 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:1729 class-ID: 0301
Device-3: 1-8:5 info: SteelSeries ApS Apex 3 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 1038:161a class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 224 Uptime: 51m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1122 libs: 314 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Any help would be greatly appreciated.
