When I boot Manjaro XFCE, the display of the laptop shows dark screen. Screenshots work fine, it’s only that the screen is showing dark.
Note that another display is connected to the laptop, which works fine.
The solution for this is to turn off the display from the “display” settings, and then turn it back on. This issue only occurs on kernels after 5.4. On 5.4, it is totally fine.
Some system info below,
Host: aditya-pc Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0 Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <superuser required>
Mobo: HP model: 8136 v: 31.36 serial: <superuser required> UEFI: Insyde
v: F.1F date: 01/18/2016
Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L2: 3 MiB
bogomips: 19204
Speed: 501 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 501 2: 500
3: 500 4: 501
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel bus-ID: 01:00.0
Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo
bus-ID: 1-5:5
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,intel,radeon
unloaded: modesetting resolution: 1: 1920x1080~60Hz 2: 2560x1440~75Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.1
direct render: Yes
