Continued issue from thread here. Starting a new topic as advised.
When trying to wake my computer from Standby, the display comes back on and the keyboard lights up as if it has woken up, but is completely unresponsive. The screen has a black background instead of my desktop image. The panel I have appears as gray and all the the task manager app icons and system tray icons are black. The mouse cursor does appear, but again, is unresponsive.
This is an improvement after upgrading and moving from x11 to wayland. Before the monitor would wake and then go back to sleep.
Hibernate works without issue.
My system is up to date and I just updated my BIOS to the latest version.Output from inxi -zv6:
Found a command to run to check the sleep/suspend logs:
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
And here is the output:
Jan 06 19:18:09 rem49x systemd[1]: Starting System Suspend...
Jan 06 19:18:09 rem49x wpa_supplicant[675]: p2p-dev-wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 06 19:18:09 rem49x wpa_supplicant[675]: nl80211: deinit ifname=p2p-dev-wlp3s0 disabled_11b_rates=0
Jan 06 19:18:09 rem49x systemd[1]: user.slice: Unit now frozen.
Jan 06 19:18:09 rem49x systemd[1]: user-1000.slice: Unit now frozen-by-parent.
Jan 06 19:18:09 rem49x systemd-sleep[8809]: Successfully froze unit 'user.slice'.
Jan 06 19:18:09 rem49x systemd[1]: session-1.scope: Unit now frozen-by-parent.
Jan 06 19:18:09 rem49x systemd[1]: user@1000.service: Unit now frozen-by-parent.
Jan 06 19:18:09 rem49x systemd-sleep[8809]: Performing sleep operation 'suspend'...
Jan 06 19:18:09 rem49x kernel: PM: suspend entry (deep)
Jan 06 19:18:09 rem49x kernel: Filesystems sync: 0.013 seconds
Jan 06 19:18:09 rem49x wpa_supplicant[675]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 06 19:18:09 rem49x wpa_supplicant[675]: nl80211: deinit ifname=wlp3s0 disabled_11b_rates=0
Jan 06 19:18:21 rem49x kernel: Freezing user space processes
Jan 06 19:18:21 rem49x kernel: Freezing user space processes completed (elapsed 0.000 seconds)
Jan 06 19:18:21 rem49x kernel: OOM killer disabled.
Jan 06 19:18:21 rem49x kernel: Freezing remaining freezable tasks
Jan 06 19:18:21 rem49x systemd-sleep[8809]: System returned from sleep operation 'suspend'.
Jan 06 19:18:21 rem49x kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jan 06 19:18:21 rem49x kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jan 06 19:18:21 rem49x kernel: e1000e: EEE TX LPI TIMER: 00000011
Jan 06 19:18:21 rem49x kernel: sd 2:0:0:0: [sda] Synchronizing SCSI cache
Jan 06 19:18:21 rem49x kernel: ata3.00: Entering standby power mode
Jan 06 19:18:21 rem49x kernel: ACPI: PM: Preparing to enter system sleep state S3
Jan 06 19:18:21 rem49x kernel: ACPI: PM: Saving platform NVS memory
Jan 06 19:18:21 rem49x kernel: Disabling non-boot CPUs ...
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 11 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 10 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 9 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 8 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 7 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 6 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 5 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 4 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 3 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 2 is now offline
Jan 06 19:18:21 rem49x kernel: smpboot: CPU 1 is now offline
Jan 06 19:18:21 rem49x kernel: ACPI: PM: Low-level resume complete
Jan 06 19:18:21 rem49x kernel: ACPI: PM: Restoring platform NVS memory
Jan 06 19:18:21 rem49x kernel: Enabling non-boot CPUs ...
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Jan 06 19:18:21 rem49x kernel: CPU1 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Jan 06 19:18:21 rem49x kernel: CPU2 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Jan 06 19:18:21 rem49x kernel: CPU3 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
Jan 06 19:18:21 rem49x kernel: CPU4 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
Jan 06 19:18:21 rem49x kernel: CPU5 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 6 APIC 0x1
Jan 06 19:18:21 rem49x kernel: CPU6 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 7 APIC 0x3
Jan 06 19:18:21 rem49x kernel: CPU7 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 8 APIC 0x5
Jan 06 19:18:21 rem49x kernel: CPU8 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 9 APIC 0x7
Jan 06 19:18:21 rem49x kernel: CPU9 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 10 APIC 0x9
Jan 06 19:18:21 rem49x kernel: CPU10 is up
Jan 06 19:18:21 rem49x kernel: smpboot: Booting Node 0 Processor 11 APIC 0xb
Jan 06 19:18:21 rem49x kernel: CPU11 is up
Jan 06 19:18:21 rem49x kernel: ACPI: PM: Waking up from system sleep state S3
Jan 06 19:18:21 rem49x kernel: nvme nvme0: 12/0/0 default/read/poll queues
Jan 06 19:18:21 rem49x kernel: nvme nvme1: 12/0/0 default/read/poll queues
Jan 06 19:18:21 rem49x kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jan 06 19:18:21 rem49x kernel: sd 2:0:0:0: [sda] Starting disk
Jan 06 19:18:21 rem49x kernel: ata6: SATA link down (SStatus 4 SControl 300)
Jan 06 19:18:21 rem49x kernel: ata5: SATA link down (SStatus 4 SControl 300)
Jan 06 19:18:21 rem49x kernel: ata3.00: configured for UDMA/133
Jan 06 19:18:21 rem49x kernel: ata4: SATA link down (SStatus 4 SControl 300)
Jan 06 19:18:21 rem49x kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Jan 06 19:18:21 rem49x kernel: OOM killer enabled.
Jan 06 19:18:21 rem49x kernel: Restarting tasks ...
Jan 06 19:18:21 rem49x kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Jan 06 19:18:21 rem49x kernel: done.
Jan 06 19:18:21 rem49x kernel: random: crng reseeded on system resumption
Jan 06 19:18:21 rem49x kernel: PM: suspend exit
Jan 06 19:18:21 rem49x systemd[1]: user@1000.service: Unit now thawed.
Jan 06 19:18:21 rem49x systemd[1]: session-1.scope: Unit now thawed.
Jan 06 19:18:21 rem49x systemd[1]: user-1000.slice: Unit now thawed.
Jan 06 19:18:21 rem49x systemd[1]: user.slice: Unit now thawed.
Jan 06 19:18:21 rem49x systemd-sleep[8809]: Successfully thawed unit 'user.slice'.
Jan 06 19:18:21 rem49x systemd[1]: systemd-suspend.service: Deactivated successfully.
Jan 06 19:18:21 rem49x systemd[1]: Finished System Suspend.
This time my display did not even wake up. Keyboard came back on. Was able to turn num lock on and off, so it seems like it may be waking up and not outputting anything to the display.
Just another update as I discover things. Accidentally left the Sleep settings on while I was listening to playback on a recording and the computer when to sleep. After waking up, the music started back up and kept playing. My monitor was active, but there was nothing but a black screen, not lit up at all. I was able to adjust the volume from my keyboard.
I’m thinking this is a display output issue as the computer appears to be fully awake with my session restored.
Wayland has been giving too many bugs these days… and yet the recent version has aggressively taken down X11 leaving Wayland being the only option. Crazy as it seems, but I just want games running smoothly, screen doesn’t go black when waking from sleep, and no tears and flickers (TearFree is with X11 which now no longer becomes an option). Who knows how long until there is a fix… Oh and the Adaptive Refresh Rate (or VRR) with KWin is always buggy, especially with my Samsung 57". It’s a disaster.
Anyone else having these issues altogether? Churn.
