I am experiencing an issue where the display, except for the mouse cursor, often freezes and the system continues to run. Clicks and keyboard input are registered and I can save my work for example though the screen is frozen. To fix the issue at first I used to restart. After that I started restarting lightdm instead (ctrl + alt + f4, then $ systemctl restart lightdm). The gpu is an AMD R9 Fury. The CPU is a Pentium G3220. I am using the open AMD drivers. I tried both the 5.9.16-1 kernel and 5.12.1-2. Both suffered from the same issue. The system is up to date.
inxi output
Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=b4c267b4-2ca4-42d3-ad43-92f9b03c60f7 rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: Gigabyte model: Z97N-WIFI serial: <filter>
UEFI: American Megatrends v: F7 date: 09/18/2015
RAM: total: 15.51 GiB used: 2.21 GiB (14.2%)
Info: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB
bogomips: 12004
Speed: 2447 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2447 2: 1811
Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0402
class-ID: 0300
Device-2: AMD Fiji [Radeon R9 FURY / NANO Series] vendor: PC Partner Limited
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:7300 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: picom v: git-dac85 driver:
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-2 res: 2560x1440 hz: 60 dpi: 118
size: 553x311mm (21.8x12.2") diag: 634mm (25")
OpenGL: renderer: AMD Radeon R9 Fury Series (FIJI DRM 3.40.0
5.12.1-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 9 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-3: AMD Fiji HDMI/DP Audio [Radeon R9 Nano / FURY/FURY X]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aae8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-3: Intel Wireless 7260 driver: iwlwifi v: kernel port: d000
bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
bus-ID: 3-11:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 1.14 TiB used: 12.51 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 93.31 GiB size: 91.34 GiB (97.89%) used: 12.47 GiB (13.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b4c267b4-2ca4-42d3-ad43-92f9b03c60f7
used: 40.4 MiB (42.1%) fs: vfat dev: /dev/sdb2 maj-min: 8:18 label: SYSTEM
uuid: 8E65-59DD
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 838.19 GiB fs: ntfs label: NTFS Storage
uuid: 56BC1544BC152053
ID-3: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs label: Recovery
uuid: EE66116566113037
ID-4: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb4 maj-min: 8:20 size: 232.25 GiB fs: ntfs label: N/A
uuid: EE741336741300CF
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-7:2 info: Corsair M65 Gaming Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1b1c:1b05 class-ID: 0300
Device-2: 3-8:3 info: Corsair Vengeance K70RGB keyboard type: Keyboard,HID
power: 500mA chip-ID: 1b1c:1b13 class-ID: 0300 serial: <filter>
Device-3: 3-11:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1816
Processes: 190 Uptime: 1d 3h 39m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1116 lib: 319
Shell: Bash v: 5.1.4 running-in: kitty inxi: 3.3.04
journalctl output
-- Journal begins at Mon 2021-03-29 01:01:59 EEST, ends at Sun 2021-05-09 12:58:58 EEST. --
May 09 07:01:01 basil-z97nwifi CROND[10452]: (root) CMD (run-parts /etc/cron.hourly)
May 09 07:01:01 basil-z97nwifi CROND[10451]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 07:01:19 basil-z97nwifi NetworkManager[300]: <info> [1620532879.2086] device (wlp4s0): set-hw-addr: set MAC address to 9E:81:AA:86:31:06 (scanning)
May 09 07:08:09 basil-z97nwifi NetworkManager[300]: <info> [1620533289.1275] device (wlp4s0): set-hw-addr: set MAC address to 86:C1:B0:87:5D:90 (scanning)
May 09 07:14:59 basil-z97nwifi NetworkManager[300]: <info> [1620533699.1355] device (wlp4s0): set-hw-addr: set MAC address to 4A:40:86:F6:DA:22 (scanning)
May 09 07:21:48 basil-z97nwifi NetworkManager[300]: <info> [1620534108.1553] device (wlp4s0): set-hw-addr: set MAC address to 6A:8E:59:0A:05:97 (scanning)
May 09 07:28:38 basil-z97nwifi NetworkManager[300]: <info> [1620534518.1555] device (wlp4s0): set-hw-addr: set MAC address to 0A:31:06:ED:9E:F7 (scanning)
May 09 07:35:27 basil-z97nwifi NetworkManager[300]: <info> [1620534927.1553] device (wlp4s0): set-hw-addr: set MAC address to D2:6B:23:54:6F:7C (scanning)
May 09 07:42:15 basil-z97nwifi NetworkManager[300]: <info> [1620535335.1386] device (wlp4s0): set-hw-addr: set MAC address to 72:19:F4:D2:71:A3 (scanning)
May 09 07:49:06 basil-z97nwifi NetworkManager[300]: <info> [1620535746.1849] device (wlp4s0): set-hw-addr: set MAC address to E6:DF:40:9C:1D:70 (scanning)
May 09 07:55:55 basil-z97nwifi NetworkManager[300]: <info> [1620536155.1551] device (wlp4s0): set-hw-addr: set MAC address to 82:4B:71:7C:4C:C5 (scanning)
May 09 08:01:01 basil-z97nwifi CROND[10745]: (root) CMD (run-parts /etc/cron.hourly)
May 09 08:01:01 basil-z97nwifi CROND[10744]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 08:02:44 basil-z97nwifi NetworkManager[300]: <info> [1620536564.1498] device (wlp4s0): set-hw-addr: set MAC address to A2:82:15:D6:93:35 (scanning)
May 09 08:09:33 basil-z97nwifi NetworkManager[300]: <info> [1620536973.1966] device (wlp4s0): set-hw-addr: set MAC address to B2:FD:3F:4A:0F:3C (scanning)
May 09 08:16:22 basil-z97nwifi NetworkManager[300]: <info> [1620537382.1693] device (wlp4s0): set-hw-addr: set MAC address to 3E:F2:B6:A8:DE:13 (scanning)
May 09 08:23:12 basil-z97nwifi NetworkManager[300]: <info> [1620537792.1282] device (wlp4s0): set-hw-addr: set MAC address to 1A:52:31:63:BC:F9 (scanning)
May 09 08:30:06 basil-z97nwifi NetworkManager[300]: <info> [1620538206.1282] device (wlp4s0): set-hw-addr: set MAC address to C6:93:7E:A9:26:C2 (scanning)
May 09 08:37:00 basil-z97nwifi NetworkManager[300]: <info> [1620538620.2185] device (wlp4s0): set-hw-addr: set MAC address to 22:29:6F:5A:6A:41 (scanning)
May 09 08:43:50 basil-z97nwifi NetworkManager[300]: <info> [1620539030.1277] device (wlp4s0): set-hw-addr: set MAC address to AE:09:1A:79:4A:DB (scanning)
May 09 08:43:51 basil-z97nwifi polkitd[302]: Registered Authentication Agent for unix-process:10956:8456002 (system bus name :1.181 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 09 08:43:54 basil-z97nwifi audit[10962]: USER_AUTH pid=10962 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=basil-z97nwifi addr=? terminal=tty4 res=success'
May 09 08:43:54 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.183' (uid=0 pid=10962 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 08:43:54 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:54 basil-z97nwifi polkit-agent-helper-1[10962]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:54 basil-z97nwifi kernel: audit: type=1100 audit(1620539034.494:294): pid=10962 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=basil-z97nwifi addr=? terminal=tty4 res=success'
May 09 08:43:54 basil-z97nwifi kernel: audit: type=1101 audit(1620539034.494:295): pid=10962 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi audit[10962]: USER_ACCT pid=10962 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi polkitd[302]: Operator of unix-process:10956:8456002 successfully authenticated as unix-user:basilmari to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.182 [systemctl restart lightdm] (owned by unix-user:basilmari)
May 09 08:43:54 basil-z97nwifi systemd[1]: Stopping Light Display Manager...
May 09 08:43:54 basil-z97nwifi dunst[7079]: X connection to :0 broken (explicit kill or server shutdown).
May 09 08:43:54 basil-z97nwifi at-spi-bus-launcher[7069]: X connection to :0 broken (explicit kill or server shutdown).
May 09 08:43:54 basil-z97nwifi pulseaudio[6888]: X connection to :0 broken (explicit kill or server shutdown).
May 09 08:43:54 basil-z97nwifi audit[6963]: USER_LOGOUT pid=6963 uid=0 auid=1000 ses=8 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 08:43:54 basil-z97nwifi lightdm[6963]: pam_unix(lightdm:session): session closed for user basilmari
May 09 08:43:54 basil-z97nwifi kernel: audit: type=1113 audit(1620539034.527:296): pid=6963 uid=0 auid=1000 ses=8 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 08:43:54 basil-z97nwifi systemd[975]: dunst.service: Main process exited, code=exited, status=1/FAILURE
May 09 08:43:54 basil-z97nwifi systemd[975]: dunst.service: Failed with result 'exit-code'.
May 09 08:43:54 basil-z97nwifi polkitd[302]: Unregistered Authentication Agent for unix-session:8 (system bus name :1.162, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 09 08:43:54 basil-z97nwifi systemd[1]: Stopping Session 8 of user basilmari.
May 09 08:43:54 basil-z97nwifi bluetoothd[953]: Endpoint unregistered: sender=:1.150 path=/MediaEndpoint/A2DPSink/sbc
May 09 08:43:54 basil-z97nwifi bluetoothd[953]: Endpoint unregistered: sender=:1.150 path=/MediaEndpoint/A2DPSource/sbc
May 09 08:43:54 basil-z97nwifi systemd[1]: lightdm.service: Succeeded.
May 09 08:43:54 basil-z97nwifi systemd[1]: Stopped Light Display Manager.
May 09 08:43:54 basil-z97nwifi systemd[1]: Starting Light Display Manager...
May 09 08:43:54 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi kernel: audit: type=1131 audit(1620539034.554:297): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi systemd[975]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
May 09 08:43:54 basil-z97nwifi systemd[975]: pulseaudio.service: Killing process 6901 (gdbus) with signal SIGKILL.
May 09 08:43:54 basil-z97nwifi systemd[975]: pulseaudio.service: Failed with result 'exit-code'.
May 09 08:43:54 basil-z97nwifi systemd[1]: Started Light Display Manager.
May 09 08:43:54 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi polkitd[302]: Unregistered Authentication Agent for unix-process:10956:8456002 (system bus name :1.181, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 09 08:43:54 basil-z97nwifi kernel: audit: type=1130 audit(1620539034.571:298): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:54 basil-z97nwifi systemd[1]: session-8.scope: Succeeded.
May 09 08:43:54 basil-z97nwifi systemd[1]: Stopped Session 8 of user basilmari.
May 09 08:43:54 basil-z97nwifi systemd-logind[305]: Removed session 8.
May 09 08:43:54 basil-z97nwifi systemd[975]: pulseaudio.service: Scheduled restart job, restart counter is at 3.
May 09 08:43:54 basil-z97nwifi systemd[975]: Stopped Sound Service.
May 09 08:43:54 basil-z97nwifi systemd[975]: Starting Sound Service...
May 09 08:43:54 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 10986 of process 10986 owned by '1000' high priority at nice level -11.
May 09 08:43:54 basil-z97nwifi rtkit-daemon[1086]: Supervising 1 threads of 1 processes of 1 users.
May 09 08:43:54 basil-z97nwifi pulseaudio[10986]: Stale PID file, overwriting.
May 09 08:43:54 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 10992 of process 10986 owned by '1000' RT at priority 5.
May 09 08:43:54 basil-z97nwifi rtkit-daemon[1086]: Supervising 2 threads of 1 processes of 1 users.
May 09 08:43:54 basil-z97nwifi systemd[975]: Started Sound Service.
May 09 08:43:54 basil-z97nwifi bluetoothd[953]: Endpoint registered: sender=:1.188 path=/MediaEndpoint/A2DPSink/sbc
May 09 08:43:54 basil-z97nwifi bluetoothd[953]: Endpoint registered: sender=:1.188 path=/MediaEndpoint/A2DPSource/sbc
May 09 08:43:55 basil-z97nwifi audit[10996]: CRED_ACQ pid=10996 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:55 basil-z97nwifi lightdm[10996]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=971) by (uid=0)
May 09 08:43:55 basil-z97nwifi kernel: audit: type=1103 audit(1620539035.357:299): pid=10996 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:55 basil-z97nwifi systemd[1]: Created slice User Slice of UID 971.
May 09 08:43:55 basil-z97nwifi systemd[1]: Starting User Runtime Directory /run/user/971...
May 09 08:43:55 basil-z97nwifi systemd-logind[305]: New session c4 of user lightdm.
May 09 08:43:55 basil-z97nwifi systemd[1]: Finished User Runtime Directory /run/user/971.
May 09 08:43:55 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi systemd[1]: Starting User Manager for UID 971...
May 09 08:43:55 basil-z97nwifi kernel: audit: type=1130 audit(1620539035.374:300): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.193' (uid=0 pid=11000 comm="(systemd) ")
May 09 08:43:55 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:55 basil-z97nwifi systemd[11000]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:55 basil-z97nwifi audit[11000]: USER_ACCT pid=11000 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi systemd[11000]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
May 09 08:43:55 basil-z97nwifi audit[11000]: CRED_ACQ pid=11000 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 09 08:43:55 basil-z97nwifi audit[11000]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fffc79141f0 a2=3 a3=3cb items=0 ppid=1 pid=11000 auid=971 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=9 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
May 09 08:43:55 basil-z97nwifi audit: PROCTITLE proctitle="(systemd)"
May 09 08:43:55 basil-z97nwifi systemd[11000]: pam_unix(systemd-user:session): session opened for user lightdm(uid=971) by (uid=0)
May 09 08:43:55 basil-z97nwifi systemd[11000]: pam_env(systemd-user:session): deprecated reading of user environment enabled
May 09 08:43:55 basil-z97nwifi audit[11000]: USER_START pid=11000 uid=0 auid=971 ses=9 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi kernel: audit: type=1101 audit(1620539035.381:301): pid=11000 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi kernel: audit: type=1103 audit(1620539035.381:302): pid=11000 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 09 08:43:55 basil-z97nwifi kernel: audit: type=1006 audit(1620539035.381:303): pid=11000 uid=0 subj==unconfined old-auid=4294967295 auid=971 tty=(none) old-ses=4294967295 ses=9 res=1
May 09 08:43:55 basil-z97nwifi audit: BPF prog-id=27 op=LOAD
May 09 08:43:55 basil-z97nwifi audit[11000]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fff665ac4b0 a2=70 a3=7fff665ac4b0 items=0 ppid=1 pid=11000 auid=971 uid=971 gid=971 euid=971 suid=971 fsuid=971 egid=971 sgid=971 fsgid=971 tty=(none) ses=9 comm="systemd" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
May 09 08:43:55 basil-z97nwifi audit: BPF prog-id=27 op=UNLOAD
May 09 08:43:55 basil-z97nwifi systemd-xdg-autostart-generator[11005]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Queued start job for default target Main User Target.
May 09 08:43:55 basil-z97nwifi systemd[11000]: -.slice: Failed to migrate controller cgroups from /user.slice/user-971.slice/user@971.service, ignoring: Permission denied
May 09 08:43:55 basil-z97nwifi systemd[11000]: Created slice User Application Slice.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Reached target Paths.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Reached target Timers.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Starting D-Bus User Message Bus Socket.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on GnuPG network certificate management daemon.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on GnuPG cryptographic agent and passphrase cache.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on p11-kit server.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on Sound System.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Listening on D-Bus User Message Bus Socket.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Reached target Sockets.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Reached target Basic System.
May 09 08:43:55 basil-z97nwifi systemd[1]: Started User Manager for UID 971.
May 09 08:43:55 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:43:55 basil-z97nwifi systemd[1]: Started Session c4 of user lightdm.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Starting Update XDG user dir configuration...
May 09 08:43:55 basil-z97nwifi systemd[11000]: xdg-user-dirs-update.service: Succeeded.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Finished Update XDG user dir configuration.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Reached target Main User Target.
May 09 08:43:55 basil-z97nwifi systemd[11000]: Startup finished in 95ms.
May 09 08:43:55 basil-z97nwifi audit[10996]: USER_START pid=10996 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:55 basil-z97nwifi systemd[11000]: Started D-Bus User Message Bus.
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.1' (uid=971 pid=11008 comm="/usr/bin/slick-greeter ")
May 09 08:43:55 basil-z97nwifi systemd[11000]: Starting User preferences database...
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Successfully activated service 'ca.desrt.dconf'
May 09 08:43:55 basil-z97nwifi systemd[11000]: Started User preferences database.
May 09 08:43:55 basil-z97nwifi slick-greeter-check-hidpi[11011]: Window scale: 1
May 09 08:43:55 basil-z97nwifi slick-greeter-set-keyboard-layout[11024]: Current keyboard configuration: rules: evdev
model: pc105
layout: us,ara
options: grp:alt_shift_toggle
May 09 08:43:55 basil-z97nwifi slick-greeter-set-keyboard-layout[11024]: Applying keyboard configuration: ['setxkbmap', '-model', '', '-layout', 'us', '-variant', '', '-option', '', '-v']
May 09 08:43:55 basil-z97nwifi slick-greeter-set-keyboard-layout[11024]: Result: Warning! Multiple definitions of keyboard model
Using command line, ignoring X server
Warning! Multiple definitions of keyboard layout
Trying to build keymap using the following components:
keycodes: evdev+aliases(qwerty)
types: complete
compat: complete
symbols: pc+us+inet(evdev)
geometry: pc(pc104)
May 09 08:43:55 basil-z97nwifi slick-greeter-set-keyboard-layout[11024]: New keyboard configuration: rules: evdev
layout: us
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.3' (uid=971 pid=11008 comm="/usr/bin/slick-greeter ")
May 09 08:43:55 basil-z97nwifi systemd[11000]: Starting Accessibility services bus...
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Successfully activated service 'org.a11y.Bus'
May 09 08:43:55 basil-z97nwifi systemd[11000]: Started Accessibility services bus.
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=971 pid=11008 comm="/usr/bin/slick-greeter ")
May 09 08:43:55 basil-z97nwifi systemd[11000]: Starting Virtual filesystem service...
May 09 08:43:55 basil-z97nwifi dbus-daemon[11012]: [session uid=971 pid=11012] Successfully activated service 'org.gtk.vfs.Daemon'
May 09 08:43:55 basil-z97nwifi systemd[11000]: Started Virtual filesystem service.
May 09 08:43:55 basil-z97nwifi polkitd[302]: <no filename>:3: action=[Action id='org.freedesktop.login1.suspend-multiple-sessions']
May 09 08:43:55 basil-z97nwifi polkitd[302]: <no filename>:4: subject=[Subject pid=11008 user='lightdm' groups=lightdm seat='seat0' session='c4' local=true active=true]
May 09 08:43:55 basil-z97nwifi polkitd[302]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
May 09 08:43:55 basil-z97nwifi at-spi-bus-launcher[11035]: dbus-daemon[11035]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=971 pid=11008 comm="/usr/bin/slick-greeter ")
May 09 08:43:55 basil-z97nwifi at-spi-bus-launcher[11035]: dbus-daemon[11035]: Successfully activated service 'org.a11y.atspi.Registry'
May 09 08:43:55 basil-z97nwifi at-spi-bus-launcher[11056]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 09 08:43:58 basil-z97nwifi lightdm[11054]: gkr-pam: unable to locate daemon control file
May 09 08:43:58 basil-z97nwifi lightdm[11054]: gkr-pam: stashed password to try later in open session
May 09 08:43:58 basil-z97nwifi audit[11054]: USER_AUTH pid=11054 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.196' (uid=0 pid=11054 comm="lightdm --session-child 12 19 ")
May 09 08:43:58 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:58 basil-z97nwifi lightdm[11054]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 08:43:58 basil-z97nwifi audit[11054]: USER_ACCT pid=11054 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi systemd[1]: Stopping Session c4 of user lightdm.
May 09 08:43:58 basil-z97nwifi lightdm[10996]: pam_unix(lightdm-greeter:session): session closed for user lightdm
May 09 08:43:58 basil-z97nwifi audit[10996]: USER_END pid=10996 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi audit[10996]: CRED_DISP pid=10996 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi systemd[1]: session-c4.scope: Succeeded.
May 09 08:43:58 basil-z97nwifi systemd[1]: Stopped Session c4 of user lightdm.
May 09 08:43:58 basil-z97nwifi systemd-logind[305]: Removed session c4.
May 09 08:43:58 basil-z97nwifi audit[11054]: CRED_ACQ pid=11054 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi audit[11054]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7fff3f3ebd00 a2=4 a3=3e8 items=0 ppid=10967 pid=11054 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=10 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
May 09 08:43:58 basil-z97nwifi audit: PROCTITLE proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
May 09 08:43:58 basil-z97nwifi lightdm[11054]: pam_unix(lightdm:session): session opened for user basilmari(uid=1000) by (uid=0)
May 09 08:43:58 basil-z97nwifi systemd[1]: Started Session 10 of user basilmari.
May 09 08:43:58 basil-z97nwifi systemd-logind[305]: New session 10 of user basilmari.
May 09 08:43:58 basil-z97nwifi lightdm[11054]: pam_env(lightdm:session): deprecated reading of user environment enabled
May 09 08:43:58 basil-z97nwifi lightdm[11054]: gkr-pam: unlocked login keyring
May 09 08:43:58 basil-z97nwifi audit[11054]: USER_START pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 08:43:58 basil-z97nwifi audit[11054]: USER_LOGIN pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Supervising 2 threads of 1 processes of 1 users.
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 11117 of process 10986 owned by '1000' RT at priority 5.
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Supervising 3 threads of 1 processes of 1 users.
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 11121 of process 10986 owned by '1000' RT at priority 5.
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 08:43:59 basil-z97nwifi at-spi-bus-launcher[1108]: dbus-daemon[1108]: Activating service name='org.a11y.atspi.Registry' requested by ':1.22' (uid=1000 pid=11079 comm="pa-applet ")
May 09 08:43:59 basil-z97nwifi polkitd[302]: Registered Authentication Agent for unix-session:10 (system bus name :1.201 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 09 08:43:59 basil-z97nwifi at-spi-bus-launcher[1108]: dbus-daemon[1108]: Successfully activated service 'org.a11y.atspi.Registry'
May 09 08:43:59 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 11166 of process 10986 owned by '1000' RT at priority 5.
May 09 08:43:59 basil-z97nwifi at-spi-bus-launcher[11165]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 09 08:43:59 basil-z97nwifi dbus-daemon[995]: [session uid=1000 pid=995] Activating via systemd: service name='org.freedesktop.Notifications' unit='dunst.service' requested by ':1.165' (uid=1000 pid=11089 comm="xfce4-power-manager ")
May 09 08:43:59 basil-z97nwifi systemd[975]: Starting Dunst notification daemon...
May 09 08:43:59 basil-z97nwifi dbus-daemon[995]: [session uid=1000 pid=995] Successfully activated service 'org.freedesktop.Notifications'
May 09 08:43:59 basil-z97nwifi systemd[975]: Started Dunst notification daemon.
May 09 08:43:59 basil-z97nwifi NetworkManager[300]: <info> [1620539039.6873] agent-manager: agent[903fb2f687bd980a,:1.203/org.freedesktop.nm-applet/1000]: agent registered
May 09 08:43:59 basil-z97nwifi dunst[11173]: WARNING: No icon found in path: 'nm-device-wired'
May 09 08:44:01 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 08:44:01 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 11271 of process 11193 owned by '1000' RT at priority 10.
May 09 08:44:01 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 08:44:02 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 08:44:03 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 08:44:08 basil-z97nwifi systemd[1]: Stopping User Manager for UID 971...
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped target Main User Target.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopping Accessibility services bus...
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopping D-Bus User Message Bus...
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopping User preferences database...
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopping Virtual filesystem service...
May 09 08:44:08 basil-z97nwifi systemd[975]: run-user-971-gvfs.mount: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[1]: run-user-971-gvfs.mount: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: run-user-971-gvfs.mount: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: dbus.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped D-Bus User Message Bus.
May 09 08:44:08 basil-z97nwifi systemd[11000]: dconf.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped User preferences database.
May 09 08:44:08 basil-z97nwifi systemd[11000]: gvfs-daemon.service: Killing process 11045 (gvfsd-fuse) with signal SIGKILL.
May 09 08:44:08 basil-z97nwifi systemd[11000]: at-spi-dbus-bus.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped Accessibility services bus.
May 09 08:44:08 basil-z97nwifi systemd[11000]: gvfs-daemon.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped Virtual filesystem service.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped target Basic System.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped target Paths.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped target Sockets.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Stopped target Timers.
May 09 08:44:08 basil-z97nwifi systemd[11000]: dbus.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed D-Bus User Message Bus Socket.
May 09 08:44:08 basil-z97nwifi systemd[11000]: dirmngr.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed GnuPG network certificate management daemon.
May 09 08:44:08 basil-z97nwifi systemd[11000]: gpg-agent-browser.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 09 08:44:08 basil-z97nwifi systemd[11000]: gpg-agent-extra.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
May 09 08:44:08 basil-z97nwifi systemd[11000]: gpg-agent-ssh.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed GnuPG cryptographic agent (ssh-agent emulation).
May 09 08:44:08 basil-z97nwifi systemd[11000]: gpg-agent.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed GnuPG cryptographic agent and passphrase cache.
May 09 08:44:08 basil-z97nwifi systemd[11000]: p11-kit-server.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed p11-kit server.
May 09 08:44:08 basil-z97nwifi systemd[11000]: pulseaudio.socket: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Closed Sound System.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Removed slice User Application Slice.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Reached target Shutdown.
May 09 08:44:08 basil-z97nwifi systemd[11000]: systemd-exit.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Finished Exit the Session.
May 09 08:44:08 basil-z97nwifi systemd[11000]: Reached target Exit the Session.
May 09 08:44:08 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:44:08 basil-z97nwifi systemd[1]: user@971.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[1]: Stopped User Manager for UID 971.
May 09 08:44:08 basil-z97nwifi systemd[1]: Stopping User Runtime Directory /run/user/971...
May 09 08:44:08 basil-z97nwifi kernel: kauditd_printk_skb: 19 callbacks suppressed
May 09 08:44:08 basil-z97nwifi kernel: audit: type=1131 audit(1620539048.983:317): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:44:08 basil-z97nwifi systemd[975]: run-user-971.mount: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[1]: run-user-971.mount: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[1]: user-runtime-dir@971.service: Succeeded.
May 09 08:44:08 basil-z97nwifi systemd[1]: Stopped User Runtime Directory /run/user/971.
May 09 08:44:08 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:44:09 basil-z97nwifi kernel: audit: type=1131 audit(1620539048.993:318): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 08:44:09 basil-z97nwifi systemd[1]: Removed slice User Slice of UID 971.
May 09 08:44:11 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 08:44:11 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 11513 of process 11255 owned by '1000' RT at priority 10.
May 09 08:44:11 basil-z97nwifi rtkit-daemon[1086]: Supervising 6 threads of 3 processes of 1 users.
May 09 08:44:31 basil-z97nwifi dunst[11173]: WARNING: No icon found in path: 'system-software-install-symbolic'
May 09 08:50:40 basil-z97nwifi NetworkManager[300]: <info> [1620539440.1635] device (wlp4s0): set-hw-addr: set MAC address to 66:76:56:14:E4:5B (scanning)
May 09 08:57:34 basil-z97nwifi NetworkManager[300]: <info> [1620539854.1380] device (wlp4s0): set-hw-addr: set MAC address to 66:33:1B:94:0A:B5 (scanning)
May 09 08:57:34 basil-z97nwifi NetworkManager[300]: <info> [1620539854.1412] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
May 09 08:57:34 basil-z97nwifi NetworkManager[300]: <info> [1620539854.1412] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
May 09 08:57:34 basil-z97nwifi NetworkManager[300]: <info> [1620539854.1627] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
May 09 08:57:34 basil-z97nwifi NetworkManager[300]: <info> [1620539854.1627] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
May 09 08:57:34 basil-z97nwifi wpa_supplicant[683]: wlp4s0: Reject scan trigger since one is already pending
May 09 09:01:01 basil-z97nwifi CROND[11645]: (root) CMD (run-parts /etc/cron.hourly)
May 09 09:01:01 basil-z97nwifi CROND[11644]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 09:04:26 basil-z97nwifi NetworkManager[300]: <info> [1620540266.1483] device (wlp4s0): set-hw-addr: set MAC address to 76:47:3F:E3:E9:29 (scanning)
May 09 09:10:10 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 09:11:20 basil-z97nwifi NetworkManager[300]: <info> [1620540680.1742] device (wlp4s0): set-hw-addr: set MAC address to 22:14:23:30:0D:3D (scanning)
May 09 09:18:14 basil-z97nwifi NetworkManager[300]: <info> [1620541094.1316] device (wlp4s0): set-hw-addr: set MAC address to 8E:62:F0:C0:A3:90 (scanning)
May 09 09:25:08 basil-z97nwifi NetworkManager[300]: <info> [1620541508.1538] device (wlp4s0): set-hw-addr: set MAC address to EA:7C:56:8D:A2:D5 (scanning)
May 09 09:29:57 basil-z97nwifi systemd[1]: Starting Cleanup of Temporary Directories...
May 09 09:29:57 basil-z97nwifi systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
May 09 09:29:57 basil-z97nwifi systemd[1]: Finished Cleanup of Temporary Directories.
May 09 09:29:57 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 09:29:57 basil-z97nwifi kernel: audit: type=1130 audit(1620541797.471:319): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 09:29:57 basil-z97nwifi kernel: audit: type=1131 audit(1620541797.471:320): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 09:29:57 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 09:32:02 basil-z97nwifi NetworkManager[300]: <info> [1620541922.1864] device (wlp4s0): set-hw-addr: set MAC address to 5A:93:63:41:05:33 (scanning)
May 09 09:34:30 basil-z97nwifi kernel: [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:53:crtc-0] flip_done timed out
May 09 09:34:40 basil-z97nwifi kernel: [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:50:plane-5] flip_done timed out
May 09 09:34:40 basil-z97nwifi kernel: ------------[ cut here ]------------
May 09 09:34:40 basil-z97nwifi kernel: WARNING: CPU: 0 PID: 10974 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:7929 amdgpu_dm_atomic_commit_tail+0x25c9/0x2660 [amdgpu]
May 09 09:34:40 basil-z97nwifi kernel: Modules linked in: rfcomm cmac algif_hash ecb algif_skcipher af_alg bnep btusb btrtl btbcm btintel bluetooth ecdh_generic ecc mousedev joydev usbhid iwlmvm amdgpu mac80211 libarc4 intel_rapl_msr intel_rapl_common iwlwifi x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm cfg80211 squashfs loop iTCO_wdt at24 intel_pmc_bxt iTCO_vendor_support mei_hdcp gpu_sched irqbypass crct10dif_pclmul crc32_pclmul drm_ttm_helper i915 snd_soc_rt5640 ghash_clmulni_intel cryptd vfat rapl fat intel_cstate ttm intel_uncore snd_hda_codec_realtek snd_hda_codec_hdmi snd_hda_codec_generic ledtrig_audio snd_soc_rl6231 i2c_algo_bit snd_hda_intel snd_intel_dspcfg pcspkr snd_soc_core snd_intel_sdw_acpi i2c_i801 i2c_smbus drm_kms_helper snd_hda_codec r8169 lpc_ich cec intel_gtt snd_compress realtek snd_hda_core mei_me mdio_devres ac97_bus syscopyarea snd_pcm_dmaengine sysfillrect sysimgblt snd_hwdep rfkill e1000e libphy mei fb_sys_fops snd_pcm snd_timer snd video soundcore mac_hid acpi_pad drm
May 09 09:34:40 basil-z97nwifi kernel: crypto_user fuse agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci
May 09 09:34:40 basil-z97nwifi kernel: CPU: 0 PID: 10974 Comm: Xorg Tainted: G W 5.12.1-2-MANJARO #1
May 09 09:34:40 basil-z97nwifi kernel: Hardware name: Gigabyte Technology Co., Ltd. Z97N-WIFI/Z97N-WIFI, BIOS F7 09/18/2015
May 09 09:34:40 basil-z97nwifi kernel: RIP: 0010:amdgpu_dm_atomic_commit_tail+0x25c9/0x2660 [amdgpu]
May 09 09:34:40 basil-z97nwifi kernel: Code: 20 fd ff ff 01 c7 85 1c fd ff ff 37 00 00 00 c7 85 24 fd ff ff 20 00 00 00 e8 63 1f 13 00 e9 dd fa ff ff 0f 0b e9 2a f9 ff ff <0f> 0b e9 7a f9 ff ff 0f 0b 0f 0b e9 91 f9 ff ff 49 8b 06 41 0f b6
May 09 09:34:40 basil-z97nwifi kernel: RSP: 0018:ffffae528253b930 EFLAGS: 00010002
May 09 09:34:40 basil-z97nwifi kernel: RAX: 0000000000000002 RBX: 000000000002d1d0 RCX: ffff88e5d1544118
May 09 09:34:40 basil-z97nwifi kernel: RDX: 0000000000000001 RSI: 0000000000000297 RDI: ffff88e5d4b80178
May 09 09:34:40 basil-z97nwifi kernel: RBP: ffffae528253bcc8 R08: 0000000000000005 R09: ffffae528253b894
May 09 09:34:40 basil-z97nwifi kernel: R10: ffffae528253b898 R11: 0000000000000000 R12: 0000000000000286
May 09 09:34:40 basil-z97nwifi kernel: R13: ffff88e5d1544000 R14: ffff88e61441fa00 R15: ffff88e677077480
May 09 09:34:40 basil-z97nwifi kernel: FS: 00007f0e2bdca940(0000) GS:ffff88e8dfa00000(0000) knlGS:0000000000000000
May 09 09:34:40 basil-z97nwifi kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 09 09:34:40 basil-z97nwifi kernel: CR2: 00007f3257aa5010 CR3: 0000000197648005 CR4: 00000000000706f0
May 09 09:34:40 basil-z97nwifi kernel: Call Trace:
May 09 09:34:40 basil-z97nwifi kernel: commit_tail+0x94/0x130 [drm_kms_helper]
May 09 09:34:40 basil-z97nwifi kernel: drm_atomic_helper_commit+0x113/0x140 [drm_kms_helper]
May 09 09:34:40 basil-z97nwifi kernel: drm_mode_obj_set_property_ioctl+0x156/0x3d0 [drm]
May 09 09:34:40 basil-z97nwifi kernel: ? drm_mode_obj_find_prop_id+0x40/0x40 [drm]
May 09 09:34:40 basil-z97nwifi kernel: drm_ioctl_kernel+0xb2/0x100 [drm]
May 09 09:34:40 basil-z97nwifi kernel: drm_ioctl+0x215/0x390 [drm]
May 09 09:34:40 basil-z97nwifi kernel: amdgpu_drm_ioctl+0x49/0x80 [amdgpu]
May 09 09:34:40 basil-z97nwifi kernel: __x64_sys_ioctl+0x83/0xb0
May 09 09:34:40 basil-z97nwifi kernel: do_syscall_64+0x33/0x40
May 09 09:34:40 basil-z97nwifi kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
May 09 09:34:40 basil-z97nwifi kernel: RIP: 0033:0x7f0e2c7c9e6b
May 09 09:34:40 basil-z97nwifi kernel: Code: ff ff ff 85 c0 79 8b 49 c7 c4 ff ff ff ff 5b 5d 4c 89 e0 41 5c c3 66 0f 1f 84 00 00 00 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d d5 af 0c 00 f7 d8 64 89 01 48
May 09 09:34:40 basil-z97nwifi kernel: RSP: 002b:00007ffdb4a50d28 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
May 09 09:34:40 basil-z97nwifi kernel: RAX: ffffffffffffffda RBX: 00007ffdb4a50d60 RCX: 00007f0e2c7c9e6b
May 09 09:34:40 basil-z97nwifi kernel: RDX: 00007ffdb4a50d60 RSI: 00000000c01864ba RDI: 000000000000000d
May 09 09:34:40 basil-z97nwifi kernel: RBP: 00000000c01864ba R08: 000000000000006b R09: 00000000cccccccc
May 09 09:34:40 basil-z97nwifi kernel: R10: 0000000000000fff R11: 0000000000000246 R12: 000055e812eecd00
May 09 09:34:40 basil-z97nwifi kernel: R13: 000000000000000d R14: 0000000000000000 R15: 0000000000000003
May 09 09:34:40 basil-z97nwifi kernel: ---[ end trace 9040c2360498a70b ]---
May 09 09:34:40 basil-z97nwifi kernel: WARNING: CPU: 0 PID: 10974 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:7529 amdgpu_dm_atomic_commit_tail+0x25d2/0x2660 [amdgpu]
May 09 09:34:40 basil-z97nwifi kernel: RIP: 0010:amdgpu_dm_atomic_commit_tail+0x25d2/0x2660 [amdgpu]
May 09 09:34:40 basil-z97nwifi kernel: Code: ff ff 37 00 00 00 c7 85 24 fd ff ff 20 00 00 00 e8 63 1f 13 00 e9 dd fa ff ff 0f 0b e9 2a f9 ff ff 0f 0b e9 7a f9 ff ff 0f 0b <0f> 0b e9 91 f9 ff ff 49 8b 06 41 0f b6 8e 2d 01 00 00 48 c7 c6 80
May 09 09:34:40 basil-z97nwifi kernel: RSP: 0018:ffffae528253b930 EFLAGS: 00010086
May 09 09:34:40 basil-z97nwifi kernel: RAX: 0000000000000001 RBX: 000000000002d1d0 RCX: ffff88e5d1544118
May 09 09:34:40 basil-z97nwifi kernel: ---[ end trace 9040c2360498a70c ]---
May 09 09:38:56 basil-z97nwifi NetworkManager[300]: <info> [1620542336.1743] device (wlp4s0): set-hw-addr: set MAC address to B2:C1:E2:8D:8E:C5 (scanning)
May 09 09:45:50 basil-z97nwifi NetworkManager[300]: <info> [1620542750.1895] device (wlp4s0): set-hw-addr: set MAC address to DA:9F:48:6A:B3:44 (scanning)
May 09 09:52:44 basil-z97nwifi NetworkManager[300]: <info> [1620543164.1495] device (wlp4s0): set-hw-addr: set MAC address to 3E:82:CD:CF:08:27 (scanning)
May 09 09:59:38 basil-z97nwifi NetworkManager[300]: <info> [1620543578.1315] device (wlp4s0): set-hw-addr: set MAC address to D6:98:D3:25:5E:46 (scanning)
May 09 10:01:01 basil-z97nwifi CROND[11888]: (root) CMD (run-parts /etc/cron.hourly)
May 09 10:01:01 basil-z97nwifi CROND[11887]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 10:06:32 basil-z97nwifi NetworkManager[300]: <info> [1620543992.2184] device (wlp4s0): set-hw-addr: set MAC address to F2:B7:F8:2F:C7:4F (scanning)
May 09 10:13:26 basil-z97nwifi NetworkManager[300]: <info> [1620544406.1413] device (wlp4s0): set-hw-addr: set MAC address to 1A:A8:F6:C3:3E:B1 (scanning)
May 09 10:20:20 basil-z97nwifi NetworkManager[300]: <info> [1620544820.1647] device (wlp4s0): set-hw-addr: set MAC address to CA:F7:B3:08:48:2A (scanning)
May 09 10:27:14 basil-z97nwifi NetworkManager[300]: <info> [1620545234.1735] device (wlp4s0): set-hw-addr: set MAC address to 42:55:D9:4A:67:6F (scanning)
May 09 10:34:08 basil-z97nwifi NetworkManager[300]: <info> [1620545648.1278] device (wlp4s0): set-hw-addr: set MAC address to 06:D4:B0:7B:FB:40 (scanning)
May 09 10:41:02 basil-z97nwifi NetworkManager[300]: <info> [1620546062.1740] device (wlp4s0): set-hw-addr: set MAC address to 96:18:FD:D0:DB:39 (scanning)
May 09 10:47:56 basil-z97nwifi NetworkManager[300]: <info> [1620546476.1572] device (wlp4s0): set-hw-addr: set MAC address to FE:04:1D:95:70:99 (scanning)
May 09 10:54:50 basil-z97nwifi NetworkManager[300]: <info> [1620546890.1339] device (wlp4s0): set-hw-addr: set MAC address to BE:09:DF:1D:F8:C7 (scanning)
May 09 10:57:14 basil-z97nwifi polkitd[302]: Registered Authentication Agent for unix-process:12041:9256296 (system bus name :1.219 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 09 10:57:16 basil-z97nwifi audit[12047]: USER_AUTH pid=12047 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=basil-z97nwifi addr=? terminal=tty4 res=success'
May 09 10:57:16 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.221' (uid=0 pid=12047 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 10:57:16 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:16 basil-z97nwifi polkit-agent-helper-1[12047]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1100 audit(1620547036.746:321): pid=12047 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=basil-z97nwifi addr=? terminal=tty4 res=success'
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1101 audit(1620547036.746:322): pid=12047 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi audit[12047]: USER_ACCT pid=12047 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi polkitd[302]: Operator of unix-process:12041:9256296 successfully authenticated as unix-user:basilmari to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.220 [systemctl restart lightdm] (owned by unix-user:basilmari)
May 09 10:57:16 basil-z97nwifi systemd[1]: Stopping Light Display Manager...
May 09 10:57:16 basil-z97nwifi at-spi-bus-launcher[11165]: X connection to :0 broken (explicit kill or server shutdown).
May 09 10:57:16 basil-z97nwifi dunst[11173]: X connection to :0 broken (explicit kill or server shutdown).
May 09 10:57:16 basil-z97nwifi pulseaudio[10986]: X connection to :0 broken (explicit kill or server shutdown).
May 09 10:57:16 basil-z97nwifi polkitd[302]: Unregistered Authentication Agent for unix-session:10 (system bus name :1.201, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 09 10:57:16 basil-z97nwifi systemd[975]: dunst.service: Main process exited, code=exited, status=1/FAILURE
May 09 10:57:16 basil-z97nwifi systemd[975]: dunst.service: Failed with result 'exit-code'.
May 09 10:57:16 basil-z97nwifi systemd[1]: Stopping Session 10 of user basilmari.
May 09 10:57:16 basil-z97nwifi audit[11054]: USER_LOGOUT pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 10:57:16 basil-z97nwifi lightdm[11054]: pam_unix(lightdm:session): session closed for user basilmari
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1113 audit(1620547036.789:323): pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1106 audit(1620547036.789:324): pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1104 audit(1620547036.789:325): pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:16 basil-z97nwifi audit[11054]: USER_END pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:16 basil-z97nwifi audit[11054]: CRED_DISP pid=11054 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:16 basil-z97nwifi bluetoothd[953]: Endpoint unregistered: sender=:1.188 path=/MediaEndpoint/A2DPSink/sbc
May 09 10:57:16 basil-z97nwifi bluetoothd[953]: Endpoint unregistered: sender=:1.188 path=/MediaEndpoint/A2DPSource/sbc
May 09 10:57:16 basil-z97nwifi systemd[975]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
May 09 10:57:16 basil-z97nwifi systemd[975]: pulseaudio.service: Failed with result 'exit-code'.
May 09 10:57:16 basil-z97nwifi systemd[1]: lightdm.service: Succeeded.
May 09 10:57:16 basil-z97nwifi systemd[1]: Stopped Light Display Manager.
May 09 10:57:16 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1131 audit(1620547036.803:326): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi systemd[1]: Starting Light Display Manager...
May 09 10:57:16 basil-z97nwifi systemd[1]: Started Light Display Manager.
May 09 10:57:16 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi kernel: audit: type=1130 audit(1620547036.829:327): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:16 basil-z97nwifi polkitd[302]: Unregistered Authentication Agent for unix-process:12041:9256296 (system bus name :1.219, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 09 10:57:16 basil-z97nwifi systemd[1]: session-10.scope: Succeeded.
May 09 10:57:16 basil-z97nwifi systemd[1]: Stopped Session 10 of user basilmari.
May 09 10:57:16 basil-z97nwifi systemd-logind[305]: Removed session 10.
May 09 10:57:16 basil-z97nwifi systemd[975]: pulseaudio.service: Scheduled restart job, restart counter is at 4.
May 09 10:57:16 basil-z97nwifi systemd[975]: Stopped Sound Service.
May 09 10:57:16 basil-z97nwifi systemd[975]: Starting Sound Service...
May 09 10:57:16 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12073 of process 12073 owned by '1000' high priority at nice level -11.
May 09 10:57:16 basil-z97nwifi rtkit-daemon[1086]: Supervising 1 threads of 1 processes of 1 users.
May 09 10:57:16 basil-z97nwifi pulseaudio[12073]: Stale PID file, overwriting.
May 09 10:57:17 basil-z97nwifi rtkit-daemon[1086]: Supervising 1 threads of 1 processes of 1 users.
May 09 10:57:17 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12079 of process 12073 owned by '1000' RT at priority 5.
May 09 10:57:17 basil-z97nwifi rtkit-daemon[1086]: Supervising 2 threads of 1 processes of 1 users.
May 09 10:57:17 basil-z97nwifi systemd[975]: Started Sound Service.
May 09 10:57:17 basil-z97nwifi bluetoothd[953]: Endpoint registered: sender=:1.227 path=/MediaEndpoint/A2DPSink/sbc
May 09 10:57:17 basil-z97nwifi bluetoothd[953]: Endpoint registered: sender=:1.227 path=/MediaEndpoint/A2DPSource/sbc
May 09 10:57:17 basil-z97nwifi audit[12083]: CRED_ACQ pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:17 basil-z97nwifi lightdm[12083]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=971) by (uid=0)
May 09 10:57:17 basil-z97nwifi kernel: audit: type=1103 audit(1620547037.593:328): pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:17 basil-z97nwifi systemd[1]: Created slice User Slice of UID 971.
May 09 10:57:17 basil-z97nwifi systemd[1]: Starting User Runtime Directory /run/user/971...
May 09 10:57:17 basil-z97nwifi systemd-logind[305]: New session c5 of user lightdm.
May 09 10:57:17 basil-z97nwifi systemd[1]: Finished User Runtime Directory /run/user/971.
May 09 10:57:17 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi systemd[1]: Starting User Manager for UID 971...
May 09 10:57:17 basil-z97nwifi kernel: audit: type=1130 audit(1620547037.609:329): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.232' (uid=0 pid=12087 comm="(systemd) ")
May 09 10:57:17 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:17 basil-z97nwifi systemd[12087]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:17 basil-z97nwifi audit[12087]: USER_ACCT pid=12087 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi audit[12087]: CRED_ACQ pid=12087 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 09 10:57:17 basil-z97nwifi audit[12087]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fffc79141f0 a2=3 a3=3cb items=0 ppid=1 pid=12087 auid=971 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=11 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
May 09 10:57:17 basil-z97nwifi audit: PROCTITLE proctitle="(systemd)"
May 09 10:57:17 basil-z97nwifi systemd[12087]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
May 09 10:57:17 basil-z97nwifi systemd[12087]: pam_unix(systemd-user:session): session opened for user lightdm(uid=971) by (uid=0)
May 09 10:57:17 basil-z97nwifi systemd[12087]: pam_env(systemd-user:session): deprecated reading of user environment enabled
May 09 10:57:17 basil-z97nwifi audit[12087]: USER_START pid=12087 uid=0 auid=971 ses=11 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi kernel: audit: type=1101 audit(1620547037.616:330): pid=12087 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi audit: BPF prog-id=28 op=LOAD
May 09 10:57:17 basil-z97nwifi audit[12087]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffc836a1840 a2=70 a3=7ffc836a1840 items=0 ppid=1 pid=12087 auid=971 uid=971 gid=971 euid=971 suid=971 fsuid=971 egid=971 sgid=971 fsgid=971 tty=(none) ses=11 comm="systemd" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
May 09 10:57:17 basil-z97nwifi audit: BPF prog-id=28 op=UNLOAD
May 09 10:57:17 basil-z97nwifi systemd-xdg-autostart-generator[12092]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Queued start job for default target Main User Target.
May 09 10:57:17 basil-z97nwifi systemd[12087]: -.slice: Failed to migrate controller cgroups from /user.slice/user-971.slice/user@971.service, ignoring: Permission denied
May 09 10:57:17 basil-z97nwifi systemd[12087]: Created slice User Application Slice.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Reached target Paths.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Reached target Timers.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Starting D-Bus User Message Bus Socket.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on GnuPG network certificate management daemon.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on GnuPG cryptographic agent and passphrase cache.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on p11-kit server.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on Sound System.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Listening on D-Bus User Message Bus Socket.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Reached target Sockets.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Reached target Basic System.
May 09 10:57:17 basil-z97nwifi systemd[1]: Started User Manager for UID 971.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Starting Update XDG user dir configuration...
May 09 10:57:17 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:17 basil-z97nwifi systemd[12087]: xdg-user-dirs-update.service: Succeeded.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Finished Update XDG user dir configuration.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Reached target Main User Target.
May 09 10:57:17 basil-z97nwifi systemd[12087]: Startup finished in 92ms.
May 09 10:57:17 basil-z97nwifi systemd[1]: Started Session c5 of user lightdm.
May 09 10:57:17 basil-z97nwifi audit[12083]: USER_START pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:17 basil-z97nwifi systemd[12087]: Started D-Bus User Message Bus.
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.1' (uid=971 pid=12095 comm="/usr/bin/slick-greeter ")
May 09 10:57:17 basil-z97nwifi systemd[12087]: Starting User preferences database...
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Successfully activated service 'ca.desrt.dconf'
May 09 10:57:17 basil-z97nwifi systemd[12087]: Started User preferences database.
May 09 10:57:17 basil-z97nwifi slick-greeter-check-hidpi[12098]: Window scale: 1
May 09 10:57:17 basil-z97nwifi slick-greeter-set-keyboard-layout[12111]: Current keyboard configuration: rules: evdev
model: pc105
layout: us,ara
May 09 10:57:17 basil-z97nwifi slick-greeter-set-keyboard-layout[12111]: Applying keyboard configuration: ['setxkbmap', '-model', '', '-layout', 'us', '-variant', '', '-option', '', '-v']
May 09 10:57:17 basil-z97nwifi slick-greeter-set-keyboard-layout[12111]: Result: Warning! Multiple definitions of keyboard model
types: complete
compat: complete
geometry: pc(pc104)
May 09 10:57:17 basil-z97nwifi slick-greeter-set-keyboard-layout[12111]: New keyboard configuration: rules: evdev
layout: us
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.3' (uid=971 pid=12095 comm="/usr/bin/slick-greeter ")
May 09 10:57:17 basil-z97nwifi systemd[12087]: Starting Accessibility services bus...
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Successfully activated service 'org.a11y.Bus'
May 09 10:57:17 basil-z97nwifi systemd[12087]: Started Accessibility services bus.
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=971 pid=12095 comm="/usr/bin/slick-greeter ")
May 09 10:57:17 basil-z97nwifi systemd[12087]: Starting Virtual filesystem service...
May 09 10:57:17 basil-z97nwifi dbus-daemon[12099]: [session uid=971 pid=12099] Successfully activated service 'org.gtk.vfs.Daemon'
May 09 10:57:17 basil-z97nwifi systemd[12087]: Started Virtual filesystem service.
May 09 10:57:18 basil-z97nwifi polkitd[302]: <no filename>:3: action=[Action id='org.freedesktop.login1.suspend-multiple-sessions']
May 09 10:57:18 basil-z97nwifi polkitd[302]: <no filename>:4: subject=[Subject pid=12095 user='lightdm' groups=lightdm seat='seat0' session='c5' local=true active=true]
May 09 10:57:18 basil-z97nwifi polkitd[302]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
May 09 10:57:18 basil-z97nwifi at-spi-bus-launcher[12122]: dbus-daemon[12122]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=971 pid=12095 comm="/usr/bin/slick-greeter ")
May 09 10:57:18 basil-z97nwifi at-spi-bus-launcher[12122]: dbus-daemon[12122]: Successfully activated service 'org.a11y.atspi.Registry'
May 09 10:57:18 basil-z97nwifi at-spi-bus-launcher[12143]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 09 10:57:22 basil-z97nwifi lightdm[12141]: gkr-pam: unable to locate daemon control file
May 09 10:57:22 basil-z97nwifi lightdm[12141]: gkr-pam: stashed password to try later in open session
May 09 10:57:21 basil-z97nwifi audit[12141]: USER_AUTH pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.235' (uid=0 pid=12141 comm="lightdm --session-child 12 19 ")
May 09 10:57:22 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:22 basil-z97nwifi lightdm[12141]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 10:57:21 basil-z97nwifi audit[12141]: USER_ACCT pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: kauditd_printk_skb: 11 callbacks suppressed
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1100 audit(1620547041.999:338): pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1101 audit(1620547041.999:339): pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi systemd[1]: Stopping Session c5 of user lightdm.
May 09 10:57:22 basil-z97nwifi lightdm[12083]: pam_unix(lightdm-greeter:session): session closed for user lightdm
May 09 10:57:22 basil-z97nwifi audit[12083]: USER_END pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi audit[12083]: CRED_DISP pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1106 audit(1620547042.039:340): pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1104 audit(1620547042.039:341): pid=12083 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi systemd[1]: session-c5.scope: Succeeded.
May 09 10:57:22 basil-z97nwifi systemd[1]: Stopped Session c5 of user lightdm.
May 09 10:57:22 basil-z97nwifi systemd-logind[305]: Removed session c5.
May 09 10:57:22 basil-z97nwifi audit[12141]: CRED_ACQ pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi audit[12141]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7fffde26b8d0 a2=4 a3=3e8 items=0 ppid=12052 pid=12141 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=12 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
May 09 10:57:22 basil-z97nwifi audit: PROCTITLE proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
May 09 10:57:22 basil-z97nwifi lightdm[12141]: pam_unix(lightdm:session): session opened for user basilmari(uid=1000) by (uid=0)
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1103 audit(1620547042.049:342): pid=12141 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1006 audit(1620547042.049:343): pid=12141 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=12 res=1
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1300 audit(1620547042.049:343): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7fffde26b8d0 a2=4 a3=3e8 items=0 ppid=12052 pid=12141 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=12 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1327 audit(1620547042.049:343): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
May 09 10:57:22 basil-z97nwifi systemd[1]: Started Session 12 of user basilmari.
May 09 10:57:22 basil-z97nwifi systemd-logind[305]: New session 12 of user basilmari.
May 09 10:57:22 basil-z97nwifi lightdm[12141]: pam_env(lightdm:session): deprecated reading of user environment enabled
May 09 10:57:22 basil-z97nwifi lightdm[12141]: gkr-pam: unlocked login keyring
May 09 10:57:22 basil-z97nwifi audit[12141]: USER_START pid=12141 uid=0 auid=1000 ses=12 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1105 audit(1620547042.072:344): pid=12141 uid=0 auid=1000 ses=12 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 09 10:57:22 basil-z97nwifi audit[12141]: USER_LOGIN pid=12141 uid=0 auid=1000 ses=12 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 10:57:22 basil-z97nwifi kernel: audit: type=1112 audit(1620547042.076:345): pid=12141 uid=0 auid=1000 ses=12 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=basil-z97nwifi addr=? terminal=/dev/tty7 res=success'
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Supervising 2 threads of 1 processes of 1 users.
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12234 of process 12073 owned by '1000' RT at priority 5.
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Supervising 3 threads of 1 processes of 1 users.
May 09 10:57:22 basil-z97nwifi polkitd[302]: Registered Authentication Agent for unix-session:12 (system bus name :1.239 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 09 10:57:22 basil-z97nwifi at-spi-bus-launcher[1108]: dbus-daemon[1108]: Activating service name='org.a11y.atspi.Registry' requested by ':1.28' (uid=1000 pid=12169 comm="/usr/lib/polkit-gnome/polkit-gnome-authentication-")
May 09 10:57:22 basil-z97nwifi at-spi-bus-launcher[1108]: dbus-daemon[1108]: Successfully activated service 'org.a11y.atspi.Registry'
May 09 10:57:22 basil-z97nwifi at-spi-bus-launcher[12249]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 09 10:57:22 basil-z97nwifi dbus-daemon[995]: [session uid=1000 pid=995] Activating via systemd: service name='org.freedesktop.Notifications' unit='dunst.service' requested by ':1.195' (uid=1000 pid=12176 comm="xfce4-power-manager ")
May 09 10:57:22 basil-z97nwifi systemd[975]: Starting Dunst notification daemon...
May 09 10:57:22 basil-z97nwifi dbus-daemon[995]: [session uid=1000 pid=995] Successfully activated service 'org.freedesktop.Notifications'
May 09 10:57:22 basil-z97nwifi systemd[975]: Started Dunst notification daemon.
May 09 10:57:22 basil-z97nwifi NetworkManager[300]: <info> [1620547042.7939] agent-manager: agent[b9e599cbd8f5ff78,:1.240/org.freedesktop.nm-applet/1000]: agent registered
May 09 10:57:22 basil-z97nwifi dunst[12257]: WARNING: No icon found in path: 'nm-device-wired'
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12272 of process 12073 owned by '1000' RT at priority 5.
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12273 of process 12073 owned by '1000' RT at priority 5.
May 09 10:57:22 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 10:57:32 basil-z97nwifi systemd[1]: Stopping User Manager for UID 971...
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped target Main User Target.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopping Accessibility services bus...
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopping D-Bus User Message Bus...
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopping User preferences database...
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopping Virtual filesystem service...
May 09 10:57:32 basil-z97nwifi systemd[12087]: dconf.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped User preferences database.
May 09 10:57:32 basil-z97nwifi systemd[12087]: dbus.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped D-Bus User Message Bus.
May 09 10:57:32 basil-z97nwifi systemd[12087]: run-user-971-gvfs.mount: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[975]: run-user-971-gvfs.mount: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[1]: run-user-971-gvfs.mount: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: at-spi-dbus-bus.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped Accessibility services bus.
May 09 10:57:32 basil-z97nwifi systemd[12087]: gvfs-daemon.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped Virtual filesystem service.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped target Basic System.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped target Paths.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped target Sockets.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Stopped target Timers.
May 09 10:57:32 basil-z97nwifi systemd[12087]: dbus.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed D-Bus User Message Bus Socket.
May 09 10:57:32 basil-z97nwifi systemd[12087]: dirmngr.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed GnuPG network certificate management daemon.
May 09 10:57:32 basil-z97nwifi systemd[12087]: gpg-agent-browser.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 09 10:57:32 basil-z97nwifi systemd[12087]: gpg-agent-extra.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
May 09 10:57:32 basil-z97nwifi systemd[12087]: gpg-agent-ssh.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed GnuPG cryptographic agent (ssh-agent emulation).
May 09 10:57:32 basil-z97nwifi systemd[12087]: gpg-agent.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed GnuPG cryptographic agent and passphrase cache.
May 09 10:57:32 basil-z97nwifi systemd[12087]: p11-kit-server.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed p11-kit server.
May 09 10:57:32 basil-z97nwifi systemd[12087]: pulseaudio.socket: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Closed Sound System.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Removed slice User Application Slice.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Reached target Shutdown.
May 09 10:57:32 basil-z97nwifi systemd[12087]: systemd-exit.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Finished Exit the Session.
May 09 10:57:32 basil-z97nwifi systemd[12087]: Reached target Exit the Session.
May 09 10:57:32 basil-z97nwifi systemd[12088]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
May 09 10:57:32 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:32 basil-z97nwifi systemd[1]: user@971.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[1]: Stopped User Manager for UID 971.
May 09 10:57:32 basil-z97nwifi systemd[1]: Stopping User Runtime Directory /run/user/971...
May 09 10:57:32 basil-z97nwifi kernel: audit: type=1131 audit(1620547052.225:346): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:32 basil-z97nwifi systemd[1]: run-user-971.mount: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[975]: run-user-971.mount: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[1]: user-runtime-dir@971.service: Succeeded.
May 09 10:57:32 basil-z97nwifi systemd[1]: Stopped User Runtime Directory /run/user/971.
May 09 10:57:32 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:32 basil-z97nwifi systemd[1]: Removed slice User Slice of UID 971.
May 09 10:57:32 basil-z97nwifi kernel: audit: type=1131 audit(1620547052.235:347): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:57:33 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 10:57:34 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 10:57:34 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 12368 of process 12288 owned by '1000' RT at priority 10.
May 09 10:57:34 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 10:57:35 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 10:57:36 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 10:57:54 basil-z97nwifi dunst[12257]: WARNING: No icon found in path: 'system-software-install-symbolic'
May 09 10:58:21 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.253' (uid=1000 pid=12617 comm="pamac-manager --updates ")
May 09 10:58:21 basil-z97nwifi systemd[1]: Starting Pamac Daemon...
May 09 10:58:21 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
May 09 10:58:21 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:58:21 basil-z97nwifi systemd[1]: Started Pamac Daemon.
May 09 10:58:21 basil-z97nwifi kernel: audit: type=1130 audit(1620547101.734:348): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 10:58:29 basil-z97nwifi polkit-agent-helper-1[12647]: pam_unix(polkit-1:auth): authentication failure; logname= uid=1000 euid=0 tty= ruser=basilmari rhost= user=basilmari
May 09 10:58:29 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.255' (uid=0 pid=12647 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 10:58:29 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 10:58:29 basil-z97nwifi polkit-agent-helper-1[12647]: pam_systemd_home(polkit-1:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 10:58:29 basil-z97nwifi audit[12647]: USER_AUTH pid=12647 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=? acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=failed'
May 09 10:58:29 basil-z97nwifi kernel: audit: type=1100 audit(1620547109.331:349): pid=12647 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=? acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=failed'
May 09 10:58:34 basil-z97nwifi audit[12651]: USER_AUTH pid=12651 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:58:34 basil-z97nwifi kernel: audit: type=1100 audit(1620547114.690:350): pid=12651 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:58:34 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.256' (uid=0 pid=12651 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 10:58:34 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 10:58:34 basil-z97nwifi polkit-agent-helper-1[12651]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 10:58:34 basil-z97nwifi audit[12651]: USER_ACCT pid=12651 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:58:34 basil-z97nwifi kernel: audit: type=1101 audit(1620547114.694:351): pid=12651 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 10:58:34 basil-z97nwifi polkitd[302]: Operator of unix-session:12 successfully authenticated as unix-user:basilmari to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.253 [pamac-manager --updates] (owned by unix-user:basilmari)
May 09 10:59:21 basil-z97nwifi dunst[12257]: WARNING: No icon found in path: 'dialog-information'
May 09 11:01:01 basil-z97nwifi CROND[12745]: (root) CMD (run-parts /etc/cron.hourly)
May 09 11:01:01 basil-z97nwifi CROND[12744]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 11:01:44 basil-z97nwifi NetworkManager[300]: <info> [1620547304.2241] device (wlp4s0): set-hw-addr: set MAC address to CE:AA:8E:6C:CD:0A (scanning)
May 09 11:08:38 basil-z97nwifi NetworkManager[300]: <info> [1620547718.1572] device (wlp4s0): set-hw-addr: set MAC address to 66:0F:E5:3B:80:EB (scanning)
May 09 11:15:32 basil-z97nwifi NetworkManager[300]: <info> [1620548132.1407] device (wlp4s0): set-hw-addr: set MAC address to 12:03:05:FC:80:16 (scanning)
May 09 11:22:26 basil-z97nwifi NetworkManager[300]: <info> [1620548546.1317] device (wlp4s0): set-hw-addr: set MAC address to 4E:9A:C0:1D:C9:85 (scanning)
May 09 11:24:01 basil-z97nwifi systemd[1]: pamac-daemon.service: Succeeded.
May 09 11:24:01 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:24:01 basil-z97nwifi kernel: audit: type=1131 audit(1620548641.753:352): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:24:07 basil-z97nwifi systemd[1]: Starting Snap Daemon...
May 09 11:24:07 basil-z97nwifi snapd[12974]: AppArmor status: apparmor is enabled but some kernel features are missing: dbus, network
May 09 11:24:07 basil-z97nwifi snapd[12974]: daemon.go:347: started snapd/2.50-1 (series 16; classic; devmode) manjaro/ (amd64) linux/5.12.1-2-MANJARO.
May 09 11:24:07 basil-z97nwifi kernel: loop0: detected capacity change from 0 to 8
May 09 11:24:07 basil-z97nwifi systemd[975]: tmp-sanity\x2dmountpoint\x2d981482347.mount: Succeeded.
May 09 11:24:07 basil-z97nwifi systemd[1]: tmp-sanity\x2dmountpoint\x2d981482347.mount: Succeeded.
May 09 11:24:07 basil-z97nwifi snapd[12974]: daemon.go:440: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
May 09 11:24:07 basil-z97nwifi systemd[1]: Started Snap Daemon.
May 09 11:24:07 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:24:07 basil-z97nwifi kernel: audit: type=1130 audit(1620548647.740:353): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:24:12 basil-z97nwifi snapd[12974]: daemon.go:589: gracefully waiting for running hooks
May 09 11:24:12 basil-z97nwifi snapd[12974]: daemon.go:591: done waiting for running hooks
May 09 11:24:12 basil-z97nwifi snapd[12974]: daemon stop requested to wait for socket activation
May 09 11:24:12 basil-z97nwifi systemd[1]: snapd.service: Succeeded.
May 09 11:24:12 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:24:12 basil-z97nwifi kernel: audit: type=1131 audit(1620548652.753:354): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 11:29:20 basil-z97nwifi NetworkManager[300]: <info> [1620548960.1543] device (wlp4s0): set-hw-addr: set MAC address to 32:8D:81:79:9B:D5 (scanning)
May 09 11:31:18 basil-z97nwifi rtkit-daemon[1086]: Supervising 4 threads of 1 processes of 1 users.
May 09 11:31:18 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 13304 of process 13223 owned by '1000' RT at priority 10.
May 09 11:31:18 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:31:19 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:31:20 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:36:14 basil-z97nwifi NetworkManager[300]: <info> [1620549374.1698] device (wlp4s0): set-hw-addr: set MAC address to 9A:26:0C:A2:DD:41 (scanning)
May 09 11:43:08 basil-z97nwifi NetworkManager[300]: <info> [1620549788.1269] device (wlp4s0): set-hw-addr: set MAC address to 46:3A:0E:89:81:EB (scanning)
May 09 11:43:10 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:46:12 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:46:17 basil-z97nwifi rtkit-daemon[1086]: Supervising 5 threads of 2 processes of 1 users.
May 09 11:46:17 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 13713 of process 13621 owned by '1000' RT at priority 10.
May 09 11:46:17 basil-z97nwifi rtkit-daemon[1086]: Supervising 6 threads of 3 processes of 1 users.
May 09 11:50:02 basil-z97nwifi NetworkManager[300]: <info> [1620550202.1412] device (wlp4s0): set-hw-addr: set MAC address to 32:87:46:D7:0B:7B (scanning)
May 09 11:56:56 basil-z97nwifi NetworkManager[300]: <info> [1620550616.2273] device (wlp4s0): set-hw-addr: set MAC address to 7E:76:2D:31:C3:6E (scanning)
May 09 12:01:01 basil-z97nwifi CROND[13946]: (root) CMD (run-parts /etc/cron.hourly)
May 09 12:01:01 basil-z97nwifi CROND[13945]: (root) CMDEND (run-parts /etc/cron.hourly)
May 09 12:03:50 basil-z97nwifi NetworkManager[300]: <info> [1620551030.1674] device (wlp4s0): set-hw-addr: set MAC address to BE:A2:6E:A0:06:17 (scanning)
May 09 12:10:24 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.274' (uid=1000 pid=13987 comm="manjaro-settings-manager ")
May 09 12:10:24 basil-z97nwifi audit: BPF prog-id=29 op=LOAD
May 09 12:10:24 basil-z97nwifi kernel: audit: type=1334 audit(1620551424.651:355): prog-id=29 op=LOAD
May 09 12:10:24 basil-z97nwifi kernel: audit: type=1334 audit(1620551424.651:356): prog-id=30 op=LOAD
May 09 12:10:24 basil-z97nwifi audit: BPF prog-id=30 op=LOAD
May 09 12:10:24 basil-z97nwifi systemd[1]: Starting Time & Date Service...
May 09 12:10:24 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.freedesktop.timedate1'
May 09 12:10:24 basil-z97nwifi systemd[1]: Started Time & Date Service.
May 09 12:10:24 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:10:24 basil-z97nwifi kernel: audit: type=1130 audit(1620551424.701:357): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:10:44 basil-z97nwifi NetworkManager[300]: <info> [1620551444.1403] device (wlp4s0): set-hw-addr: set MAC address to B2:C7:78:A4:BA:EA (scanning)
May 09 12:10:54 basil-z97nwifi systemd[1]: systemd-timedated.service: Succeeded.
May 09 12:10:54 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:10:54 basil-z97nwifi kernel: audit: type=1131 audit(1620551454.730:358): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:10:54 basil-z97nwifi audit: BPF prog-id=30 op=UNLOAD
May 09 12:10:54 basil-z97nwifi audit: BPF prog-id=29 op=UNLOAD
May 09 12:10:54 basil-z97nwifi kernel: audit: type=1334 audit(1620551454.746:359): prog-id=30 op=UNLOAD
May 09 12:10:54 basil-z97nwifi kernel: audit: type=1334 audit(1620551454.746:360): prog-id=29 op=UNLOAD
May 09 12:12:35 basil-z97nwifi manjaro-settings-manager[13987]: Shutting down Manjaro Settings Manager...
May 09 12:14:55 basil-z97nwifi rtkit-daemon[1086]: Supervising 6 threads of 3 processes of 1 users.
May 09 12:15:06 basil-z97nwifi rtkit-daemon[1086]: Supervising 6 threads of 3 processes of 1 users.
May 09 12:15:09 basil-z97nwifi rtkit-daemon[1086]: Supervising 6 threads of 3 processes of 1 users.
May 09 12:15:09 basil-z97nwifi rtkit-daemon[1086]: Successfully made thread 14158 of process 14076 owned by '1000' RT at priority 10.
May 09 12:15:09 basil-z97nwifi rtkit-daemon[1086]: Supervising 7 threads of 4 processes of 1 users.
May 09 12:17:38 basil-z97nwifi NetworkManager[300]: <info> [1620551858.1401] device (wlp4s0): set-hw-addr: set MAC address to 2A:F6:8F:32:22:85 (scanning)
May 09 12:17:38 basil-z97nwifi NetworkManager[300]: <info> [1620551858.1425] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
May 09 12:17:38 basil-z97nwifi NetworkManager[300]: <info> [1620551858.1425] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
May 09 12:17:38 basil-z97nwifi NetworkManager[300]: <info> [1620551858.2091] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
May 09 12:17:38 basil-z97nwifi NetworkManager[300]: <info> [1620551858.2091] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
May 09 12:17:38 basil-z97nwifi wpa_supplicant[683]: wlp4s0: Reject scan trigger since one is already pending
May 09 12:21:18 basil-z97nwifi sudo[14274]: basilmari : a password is required ; TTY=pts/1 ; PWD=/home/basilmari ; USER=root ; COMMAND=/sbin/file -s /dev/sda1
May 09 12:21:18 basil-z97nwifi sudo[14276]: basilmari : a password is required ; TTY=pts/1 ; PWD=/home/basilmari ; USER=root ; COMMAND=/sbin/file -s /dev/sdb3
May 09 12:24:30 basil-z97nwifi NetworkManager[300]: <info> [1620552270.2070] device (wlp4s0): set-hw-addr: set MAC address to A2:CB:6D:A1:53:30 (scanning)
May 09 12:26:37 basil-z97nwifi rtkit-daemon[1086]: Supervising 7 threads of 4 processes of 1 users.
May 09 12:31:24 basil-z97nwifi NetworkManager[300]: <info> [1620552684.1344] device (wlp4s0): set-hw-addr: set MAC address to 26:D9:68:2E:94:2D (scanning)
May 09 12:38:18 basil-z97nwifi NetworkManager[300]: <info> [1620553098.1336] device (wlp4s0): set-hw-addr: set MAC address to 66:5B:78:09:6D:D1 (scanning)
May 09 12:45:12 basil-z97nwifi NetworkManager[300]: <info> [1620553512.1579] device (wlp4s0): set-hw-addr: set MAC address to B2:73:35:61:53:23 (scanning)
May 09 12:45:12 basil-z97nwifi NetworkManager[300]: <info> [1620553512.1608] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
May 09 12:45:12 basil-z97nwifi NetworkManager[300]: <info> [1620553512.1608] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
May 09 12:45:12 basil-z97nwifi NetworkManager[300]: <info> [1620553512.1913] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
May 09 12:45:12 basil-z97nwifi NetworkManager[300]: <info> [1620553512.1913] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
May 09 12:45:12 basil-z97nwifi wpa_supplicant[683]: wlp4s0: Reject scan trigger since one is already pending
May 09 12:46:29 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.282' (uid=1000 pid=14490 comm="pamac-manager ")
May 09 12:46:29 basil-z97nwifi systemd[1]: Starting Pamac Daemon...
May 09 12:46:29 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
May 09 12:46:29 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:46:29 basil-z97nwifi systemd[1]: Started Pamac Daemon.
May 09 12:46:29 basil-z97nwifi kernel: audit: type=1130 audit(1620553589.133:361): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:47:50 basil-z97nwifi rtkit-daemon[1086]: Supervising 7 threads of 4 processes of 1 users.
May 09 12:49:04 basil-z97nwifi polkit-agent-helper-1[14573]: pam_unix(polkit-1:auth): authentication failure; logname= uid=1000 euid=0 tty= ruser=basilmari rhost= user=basilmari
May 09 12:49:04 basil-z97nwifi kernel: audit: type=1100 audit(1620553744.584:362): pid=14573 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=? acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=failed'
May 09 12:49:04 basil-z97nwifi audit[14573]: USER_AUTH pid=14573 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=? acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=failed'
May 09 12:49:04 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.285' (uid=0 pid=14573 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 12:49:04 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 12:49:04 basil-z97nwifi polkit-agent-helper-1[14573]: pam_systemd_home(polkit-1:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 12:49:11 basil-z97nwifi audit[14574]: USER_AUTH pid=14574 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:49:11 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.286' (uid=0 pid=14574 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 12:49:11 basil-z97nwifi kernel: audit: type=1100 audit(1620553751.184:363): pid=14574 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:49:11 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 12:49:11 basil-z97nwifi polkit-agent-helper-1[14574]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 12:49:11 basil-z97nwifi audit[14574]: USER_ACCT pid=14574 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:49:11 basil-z97nwifi kernel: audit: type=1101 audit(1620553751.187:364): pid=14574 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:49:11 basil-z97nwifi polkitd[302]: Operator of unix-session:12 successfully authenticated as unix-user:basilmari to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.282 [pamac-manager] (owned by unix-user:basilmari)
May 09 12:49:11 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.282' (uid=1000 pid=14490 comm="pamac-manager ")
May 09 12:49:11 basil-z97nwifi systemd[1]: Starting Hostname Service...
May 09 12:49:11 basil-z97nwifi audit: BPF prog-id=31 op=LOAD
May 09 12:49:11 basil-z97nwifi audit: BPF prog-id=32 op=LOAD
May 09 12:49:11 basil-z97nwifi kernel: audit: type=1334 audit(1620553751.344:365): prog-id=31 op=LOAD
May 09 12:49:11 basil-z97nwifi kernel: audit: type=1334 audit(1620553751.344:366): prog-id=32 op=LOAD
May 09 12:49:11 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.freedesktop.hostname1'
May 09 12:49:11 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:11 basil-z97nwifi systemd[1]: Started Hostname Service.
May 09 12:49:11 basil-z97nwifi kernel: audit: type=1130 audit(1620553751.401:367): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:41 basil-z97nwifi systemd[1]: systemd-hostnamed.service: Succeeded.
May 09 12:49:41 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:41 basil-z97nwifi kernel: audit: type=1131 audit(1620553781.443:368): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:41 basil-z97nwifi audit: BPF prog-id=32 op=UNLOAD
May 09 12:49:41 basil-z97nwifi audit: BPF prog-id=31 op=UNLOAD
May 09 12:49:41 basil-z97nwifi kernel: audit: type=1334 audit(1620553781.543:369): prog-id=32 op=UNLOAD
May 09 12:49:41 basil-z97nwifi kernel: audit: type=1334 audit(1620553781.543:370): prog-id=31 op=UNLOAD
May 09 12:49:49 basil-z97nwifi systemd[1]: pamac-daemon.service: Succeeded.
May 09 12:49:49 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:49 basil-z97nwifi kernel: audit: type=1131 audit(1620553789.506:371): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:51 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.291' (uid=1000 pid=14613 comm="pamac-manager ")
May 09 12:49:51 basil-z97nwifi systemd[1]: Starting Pamac Daemon...
May 09 12:49:51 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
May 09 12:49:51 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:49:51 basil-z97nwifi systemd[1]: Started Pamac Daemon.
May 09 12:49:51 basil-z97nwifi kernel: audit: type=1130 audit(1620553791.846:372): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi audit[14636]: USER_AUTH pid=14636 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi kernel: audit: type=1100 audit(1620553804.752:373): pid=14636 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.295' (uid=0 pid=14636 comm="/usr/lib/polkit-1/polkit-agent-helper-1 basilmari ")
May 09 12:50:04 basil-z97nwifi dbus-daemon[298]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 12:50:04 basil-z97nwifi polkit-agent-helper-1[14636]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 12:50:04 basil-z97nwifi audit[14636]: USER_ACCT pid=14636 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi kernel: audit: type=1101 audit(1620553804.755:374): pid=14636 uid=1000 auid=1000 ses=12 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi polkitd[302]: Operator of unix-session:12 successfully authenticated as unix-user:basilmari to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.291 [pamac-manager] (owned by unix-user:basilmari)
May 09 12:50:04 basil-z97nwifi dbus-daemon[298]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.291' (uid=1000 pid=14613 comm="pamac-manager ")
May 09 12:50:04 basil-z97nwifi systemd[1]: Starting Hostname Service...
May 09 12:50:04 basil-z97nwifi kernel: audit: type=1334 audit(1620553804.895:375): prog-id=33 op=LOAD
May 09 12:50:04 basil-z97nwifi kernel: audit: type=1334 audit(1620553804.895:376): prog-id=34 op=LOAD
May 09 12:50:04 basil-z97nwifi audit: BPF prog-id=33 op=LOAD
May 09 12:50:04 basil-z97nwifi audit: BPF prog-id=34 op=LOAD
May 09 12:50:04 basil-z97nwifi dbus-daemon[298]: [system] Successfully activated service 'org.freedesktop.hostname1'
May 09 12:50:04 basil-z97nwifi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:04 basil-z97nwifi systemd[1]: Started Hostname Service.
May 09 12:50:04 basil-z97nwifi kernel: audit: type=1130 audit(1620553804.979:377): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:20 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:20 basil-z97nwifi kernel: audit: type=1131 audit(1620553820.955:378): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:20 basil-z97nwifi systemd[1]: pamac-daemon.service: Succeeded.
May 09 12:50:35 basil-z97nwifi systemd[1]: systemd-hostnamed.service: Succeeded.
May 09 12:50:35 basil-z97nwifi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:35 basil-z97nwifi kernel: audit: type=1131 audit(1620553835.041:379): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 09 12:50:35 basil-z97nwifi audit: BPF prog-id=34 op=UNLOAD
May 09 12:50:35 basil-z97nwifi audit: BPF prog-id=33 op=UNLOAD
May 09 12:50:35 basil-z97nwifi kernel: audit: type=1334 audit(1620553835.131:380): prog-id=34 op=UNLOAD
May 09 12:50:35 basil-z97nwifi kernel: audit: type=1334 audit(1620553835.131:381): prog-id=33 op=UNLOAD
May 09 12:52:04 basil-z97nwifi NetworkManager[300]: <info> [1620553924.2036] device (wlp4s0): set-hw-addr: set MAC address to F2:79:F6:AC:1A:F1 (scanning)
May 09 12:53:48 basil-z97nwifi sudo[14760]: basilmari : a password is required ; TTY=pts/1 ; PWD=/home/basilmari ; USER=root ; COMMAND=/sbin/file -s /dev/sda1
May 09 12:53:48 basil-z97nwifi sudo[14762]: basilmari : a password is required ; TTY=pts/1 ; PWD=/home/basilmari ; USER=root ; COMMAND=/sbin/file -s /dev/sdb3
May 09 12:54:24 basil-z97nwifi rtkit-daemon[1086]: Supervising 7 threads of 4 processes of 1 users.
May 09 12:58:58 basil-z97nwifi NetworkManager[300]: <info> [1620554338.1766] device (wlp4s0): set-hw-addr: set MAC address to 86:4E:DD:4B:3F:D5 (scanning)
More information: after the freeze occurs, and I navigate to the tty through ctrl+alt+f4, if I try to return to the desktop with ctrl+alt+f7, the screen/system freezes and I am forced to hard shut down the computer. when the computer is running normally, going to tty4 and then tty7 is no issue. It brings me back to the desktop.
Does anyone have a clue as to how I can fix this issue?
