Display freezes after screen locked and idle
so, I’m sorta new to using Linux, so i’m not sure where to start in fixing this.
I’ve just got a new monitor that is 1440p, but now if I’m using it when i lock the screens or leave it idle to power off/standby the displays when I wake it, im greeted with a frozen screen.
I’ve tried different kernel versions, 4.19, 5.4, and 5.7.
I’ve also just upgraded my gpu from a gtx 1060 to an RX 5600xt, but is was working fine with two 2080p monitors prior to upgrading to the 1440p display.
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:innocent:
Also it’s a bit unclear what did work in the past and what exactly doesn’t work right now… Are you running an AMD RX5600xt with three monitors now? (two 2080p and one 1440p?) Please press the pencil to edit and clarify your original post and then provide the above requested information below as a response.
Please note that when providing code/output, please copy-paste it in-between 3 backticks at the beginning and end of the code/text ``` so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
(as that makes our life much easier so you get helped more quickly and efficiently)
:innocent:
Hi!
Besides posting the inxi output, as Fabby asked, after the freeze and reboot, post the output of
journalctl -xe -p3 -b-1
and
cat /var/log/xorg.0.log.old | grep EE
ok.
result of inxi --admin --verbosity=7 --filter --no-host
  Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=0e8469ff-9fe2-4fd8-bc3d-f6e6cfdd0109 rw quiet apparmor=1
  security=apparmor resume=UUID=dd0412e3-f4e6-431e-a1ae-1d976a01fe7e
  udev.log_priority=3
  Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 3805 date: 05/16/2018
  RAM: total: 15.58 GiB used: 2.82 GiB (18.1%)
  RAM Report:
  Topology: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
  L2 cache: 6144 KiB bogomips: 28009
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
  art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
  flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
  lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
  pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
  pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  xsaves xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
  vendor: XFX Pine driver: amdgpu v: kernel bus ID: 03:00.0
  chip ID: 1002:731f
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
  FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
  s-diag: 1245mm (49")
  Monitor-1: DisplayPort-0 res: 2560x1440 hz: 144 dpi: 109
  size: 597x336mm (23.5x13.2") diag: 685mm (27")
  Monitor-2: DisplayPort-1 res: 1920x1080 dpi: 82
  size: 598x336mm (23.5x13.2") diag: 686mm (27")
  OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.37.0
  5.7.17-2-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.6 direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
  bus ID: 03:00.1 chip ID: 1002:ab38
  Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-4:3 chip ID: 1038:12ad
  Sound Server: ALSA v: k5.7.17-2-MANJARO
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
  port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 5.23 TiB used: 3.33 TiB (63.6%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG60ZNV512G NVMe 512GB
  size: 476.94 GiB block size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 10604106 scheme: GPT
  ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb vendor: Kingston model: SUV400S37240G size: 223.57 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 96R9 scheme: GPT
  ID-4: /dev/sdc vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
  rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-5: /dev/sdd vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
  rotation: 7200 rpm serial: <filter> rev: CC26 scheme: GPT
  Optical-1: /dev/sr0 vendor: Optiarc model: DVD+-RW AD-7200S rev: 102A
  dev-links: cdrom
  ID-1: / raw size: 459.50 GiB size: 451.27 GiB (98.21%)
  used: 111.79 GiB (24.8%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
  uuid: 0e8469ff-9fe2-4fd8-bc3d-f6e6cfdd0109
  ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A
  uuid: A8BE-802E
  ID-3: /media/bulk raw size: 1.82 TiB size: 1.79 TiB (98.38%)
  used: 1.53 TiB (85.2%) fs: ext4 dev: /dev/sdc1 label: Bulk
  uuid: 5e87fc70-4b02-4a73-86a7-83a388489f8e
  ID-4: /media/games raw size: 1.82 TiB size: 1.79 TiB (98.38%)
  used: 1.54 TiB (86.2%) fs: ext4 dev: /dev/sdd1 label: GamesHDD
  uuid: bcc8cff2-3030-4157-95bb-4a0b10b4b7db
  ID-5: /media/ssd raw size: 931.51 GiB size: 915.89 GiB (98.32%)
  used: 153.11 GiB (16.7%) fs: ext4 dev: /dev/sda1 label: GamesSSD
  uuid: 6b2498fa-a093-4531-81f6-86367e46650b
  ID-1: swap-1 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p3 label: N/A
  uuid: dd0412e3-f4e6-431e-a1ae-1d976a01fe7e
  ID-1: /dev/sdb1 size: 204.46 GiB fs: ext4 label: N/A
  uuid: 5ed7132c-f3b9-4a9b-865a-dc6ddec4ae8a
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Hub: 1-3:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
  chip ID: 05e3:0610
  Device-1: 1-4:3 info: SteelSeries ApS SteelSeries Arctis 7
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 6
  rev: 1.1 speed: 12 Mb/s chip ID: 1038:12ad
  Device-2: 1-5:4 info: Kingsis ZOWIE Gaming mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  chip ID: 3057:0002
  Device-3: 1-6:5 info: Ducky Ducky One2 Mini RGB type: Keyboard,Mouse,HID
  driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
  chip ID: 3233:6301 serial: <filter>
  Device-4: 1-13:6 info: Corsair STRAFE RGB Gaming Keyboard
  type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
  chip ID: 1b1c:1b20 serial: <filter>
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0
  speed: 5 Gb/s chip ID: 1d6b:0003
  Hub: 2-3:2 info: Genesys Logic hub ports: 2 rev: 3.0 speed: 5 Gb/s
  chip ID: 05e3:0616
  Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
  speed: 10 Gb/s chip ID: 1d6b:0003
  System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 29 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 779
  Processes: 245 Uptime: 3m Init: systemd v: 246 Compilers: gcc: 10.2.0
  Packages: pacman: 1257 lib: 347 flatpak: 0 Shell: Zsh v: 5.8
  running in: konsole inxi: 3.1.05
and result of journalctl -xe -p3 -b-1
Sep 06 09:44:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:45:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:46:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:47:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:48:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:49:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:50:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:51:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:52:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:53:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:54:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:55:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:56:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:57:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:58:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 09:59:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:00:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:01:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:02:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:03:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:04:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:05:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:06:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:07:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:08:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:09:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:10:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:11:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:12:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:13:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:14:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:15:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:16:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:17:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:18:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:19:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:20:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:21:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:22:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:23:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:24:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:36 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:46 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:25:56 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:26:06 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:26:16 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
Sep 06 10:26:26 box kscreenlocker_greet[10626]: Could not create AF_NETLINK socket (Operation not permitted)
from my search this kscreenlocker_greet may be the symptom of the problem, but i was unable to find a cause.
and result of cat /var/log/Xorg.0.log.old | grep EE
[     4.067] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     4.068] (EE) Failed to load module "vesa" (module does not exist, 0)
[     4.217] (II) Initializing extension MIT-SCREEN-SAVER
[     4.483] (EE) Failed to open authorization file "/var/run/sddm/{abfa8fe6-c5bc-47d0-8144-235ccb50dfbd}": No such file or directory
Binary file (standard input) matches```
looking in the "/var/run/sddm/" i have a file there with a different name
Please post the output of journalctl -b | grep sddm-helper
Sep 06 10:26:59 box audit[751]: USER_AUTH pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box audit[751]: USER_ACCT pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box sddm-helper[751]: [PAM] Authenticating...
Sep 06 10:26:59 box sddm-helper[751]: [PAM] returning.
Sep 06 10:26:59 box audit[751]: CRED_ACQ pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box sddm-helper[751]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=967) by (uid=0)
Sep 06 10:26:59 box kernel: audit: type=1100 audit(1599402419.297:44): pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box kernel: audit: type=1101 audit(1599402419.297:45): pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box kernel: audit: type=1103 audit(1599402419.297:46): pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:26:59 box audit[751]: USER_START pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Sep 06 10:27:09 box sddm-helper[1039]: [PAM] Starting...
Sep 06 10:27:09 box sddm-helper[1039]: [PAM] Authenticating...
Sep 06 10:27:09 box sddm-helper[1039]: [PAM] Preparing to converse...
Sep 06 10:27:09 box sddm-helper[1039]: [PAM] Conversation with 1 messages
Sep 06 10:27:09 box sddm-helper[1039]: pam_kwallet5(sddm:auth): (null): pam_sm_authenticate
Sep 06 10:27:09 box audit[1039]: USER_AUTH pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box sddm-helper[1039]: [PAM] returning.
Sep 06 10:27:09 box dbus-daemon[530]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.25' (uid=0 pid=1039 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth0" label="unconfined")
Sep 06 10:27:09 box sddm-helper[1039]: pam_systemd_home(sddm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Sep 06 10:27:09 box kernel: audit: type=1100 audit(1599402429.747:64): pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box audit[1039]: USER_ACCT pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box sddm-helper[1039]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Sep 06 10:27:09 box audit[1039]: CRED_ACQ pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box kernel: audit: type=1101 audit(1599402429.751:65): pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box kernel: audit: type=1103 audit(1599402429.751:66): pid=1039 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 06 10:27:09 box sddm-helper[1039]: pam_unix(sddm:session): session opened for user still(uid=1000) by (uid=0)
Sep 06 10:27:09 box sddm-helper[751]: [PAM] Closing session
Sep 06 10:27:09 box sddm-helper[751]: pam_unix(sddm-greeter:session): session closed for user sddm
Sep 06 10:27:09 box audit[751]: USER_END pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Sep 06 10:27:09 box audit[751]: CRED_DISP pid=751 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Sep 06 10:27:09 box sddm-helper[751]: [PAM] Ended.
Sep 06 10:27:09 box sddm[596]: Auth: sddm-helper exited successfully
Sep 06 10:27:09 box sddm-helper[1039]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Sep 06 10:27:09 box sddm-helper[1054]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
Sep 06 10:27:09 box audit[1039]: USER_START pid=1039 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="still" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Sep 06 10:27:09 box sddm-helper[1039]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Sep 06 10:27:09 box sddm-helper[1056]: Adding cookie to "/home/still/.Xauthority"
If you lock the screen after booting, before launching any application, it still freezes?
the only time it doesn’t freeze is if i turn it on then leave it on the login screen and not log into any user accounts.
I’ve done a bit more testing and it appears to only happen if i have two displays with differing native resolutions attached, ie two 1080p displays works, one 1440p display works, but one 1440p and one 1080p doesn’t.
edit: upon even further testing, if the 1080p display is in portrait it works.
There’s a bug report about a similar problem (not quite the same but similar enough). Try to boot with the kernel parameter amdgpu.dpm=0 and test the screen locker. This will disable power management, just to test.
Another test, without the kernel parameter, is to lower the resolution of the 1440p monitor and then try the screen locker. If this works we can find a workaround.
That hasn’t fixed my problem, I’ve started getting other artifacting in games and such, i think my gpu is just dying now. i’m still in warranty so i’m just gonna send it back.
With or without the kernel parameter?
Both. I’ve swapped to another gpu and now there are no problems. i’m still within my return period as i got the gpu a week ago.
I marked your last answer as solution so the topic doesn’t stay unresolved.
