Display flickers after several suspends
Hi everyone.
I used arch before on this laptop and everything was fine. But then I installed a new ssd and decided to try Manjaro.
I have 2 issues with display flickering:
  1. Display flickers one time in several minutes repeatedly
  2. Display starts flickering as crazy so I can’t see anything after a couple waking ups from suspend
I have no idea how to fix it.
Tried mhwd but it only shows
[m0000:00:02.0 (0300:8086:22b1) Display controller Intel Corporation:
           video-linux            2018.05.04                true            PCI
provide full system info:
inxi -zav7
and output from:
mhwd -li
inxi output is here
mhwd output is
Installed PCI configs:
im seeing you are running i3, which has o lot of similar issues reported here on the forum…
try older kernels, the 5.10, and also the 5.15, and see if it helps…
