Display fails to return after monitor turns off
Continuing the discussion from Display returning irregular (or not at all) after screen turns off:
@Aragorn After applying the 2025-05-14 update for Plasma 6.3.5, I am still having the same issue specified in the OP: using Wayland, when my monitor turns off for any reason, whether on lock screen or on my desktop, the display will fail to come back up: monitor does not detect a connection and screen remains blank, monitor will go back to auto-sleep. I have to restart [the VM] for it to come back up.
Any thoughts on next steps or what I can check? I’m not really sure where to start if the Plasma update didn’t address it…
inxi -zv8         ✔
  Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: kvm-clock avail: tsc,acpi_pm
    root=UUID=ce478906-506f-42a0-a2cd-cac663566ee9 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
    wm: kwin_wayland vt: 3 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Kvm System: QEMU product: Standard PC (i440FX + PIIX, 1996)
    v: pc-i440fx-9.1 serial: <superuser required> Chassis: type: 1
  Mobo: N/A model: N/A serial: N/A uuid: <superuser required> UEFI: EDK II
    v: N/A date: 02/02/2022
  System RAM: total: 32 GiB available: 31.34 GiB used: 11.37 GiB (36.3%)
  Array-1: capacity: 32 GiB slots: 1 modules: 1 EC: Multi-bit ECC
  Device-1: DIMM 0 type: RAM detail: N/A size: 32 GiB speed: N/A volts: N/A
    width: N/A manufacturer: Qemu part-no: N/A serial: N/A
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3400 min/max: N/A cores: 1: 3400 2: 3400 3: 3400 4: 3400
    5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400 13: 3400
    14: 3400 15: 3400 16: 3400 bogomips: 108837
  Flags: 3dnowprefetch abm adx aes apic arat arch_capabilities avx avx2
    bmi1 bmi2 clflush clflushopt clwb clzero cmov cmp_legacy cpuid cr8_legacy
    cx16 cx8 de erms extd_apicid f16c fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hypervisor ibpb ibrs invpcid lahf_lm lbrv lm mca mce misalignsse mmx
    mmxext movbe msr mtrr nopl npt nrip_save nx ospke osvw overflow_recov pae
    pat pausefilter pclmulqdq pdpe1gb perfctr_core pfthreshold pge pku pni
    popcnt pse pse36 rdpid rdrand rdseed rdtscp rep_good sep sha_ni smap smep
    ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm syscall topoext
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_scale umip
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: ASUSTeK driver: nvidia
    v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:06.0 chip-ID: 10de:2208
    class-ID: 0300
  Device-2: Microsoft Modern Webcam driver: hid-generic,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.2:4
    chip-ID: 045e:0840 class-ID: 0300 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-3 model: Samsung LS49AG95 serial: <filter> built: 2021 res:
    mode: 5120x1440 hz: 120 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red:
    x: 0.694 y: 0.294 green: x: 0.275 y: 0.659 blue: x: 0.149 y: 0.055 white:
    x: 0.314 y: 0.329 size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8")
    modes: 3840x1080, 3840x2160, 5120x1440, 3440x1440, 2560x1440, 1920x1080,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
    unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
    memory: 11.72 GiB display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3080 Ti driver: nvidia v: 570.144 device-ID: 10de:2208
    surfaces: xcb,xlib,wayland
  Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 00:08.0 chip-ID: 10de:1aef
    class-ID: 0403
  Device-2: SteelSeries ApS Arctis Pro Wireless
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4.3:8 chip-ID: 1038:1294 class-ID: 0300
  API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: Red Hat Qemu virtual
    machine type: network bridge driver: piix4_smbus v: N/A modules: i2c_piix4
    port: N/A bus-ID: 00:01.3 chip-ID: 8086:7113 class-ID: 0680
  Device-2: Red Hat Virtio network driver: virtio-pci v: 1 port: c220
    bus-ID: 00:02.0 chip-ID: 1af4:1000 class-ID: 0200
  IF: ens2 state: up speed: -1 duplex: unknown mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 650 GiB used: 65.46 GiB (10.1%)
  ID-1: /dev/vda maj-min: 254:0 model: N/A size: 150 GiB block-size:
    physical: 512 B logical: 512 B speed: <unknown> tech: N/A serial: N/A
    scheme: GPT
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/vdb maj-min: 254:16 model: N/A size: 500 GiB block-size:
    physical: 512 B logical: 512 B tech: N/A serial: N/A scheme: GPT
  ID-1: / raw-size: 149.71 GiB size: 149.71 GiB (100.00%)
    used: 65.46 GiB (43.7%) fs: btrfs dev: /dev/vda2 maj-min: 254:2 label: N/A
    uuid: ce478906-506f-42a0-a2cd-cac663566ee9
    used: 616 KiB (0.2%) fs: vfat dev: /dev/vda1 maj-min: 254:1 label: N/A
    uuid: B200-E4C1
  ID-3: /home raw-size: 149.71 GiB size: 149.71 GiB (100.00%)
  ID-4: /var/cache raw-size: 149.71 GiB size: 149.71 GiB (100.00%)
  ID-5: /var/log raw-size: 149.71 GiB size: 149.71 GiB (100.00%)
  ID-1: /dev/vdb1 maj-min: 254:17 size: 300 MiB fs: vfat label: NO_LABEL
    uuid: B409-9655
  ID-2: /dev/vdb2 maj-min: 254:18 size: 499.7 GiB fs: ext4 label: N/A
    uuid: 0f89fd6c-3f3d-4740-b209-1967055453cf
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Device-1: 2-1:2 info: Genesys Logic SD Card Reader and Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: <unknown rev+speed>
    power: 224mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
  Device-2: 2-2:3 info: Anker USB-C Hub Device type: billboard driver: N/A
    power: 100mA chip-ID: 291a:8346 class-ID: 1100 serial: <filter>
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 5-3.2:4 info: Microsoft Modern Webcam type: video,HID
    driver: hid-generic,usbhid,uvcvideo interfaces: 3 rev: 2.0
  Device-2: 5-3.3:12 info: SteelSeries ApS Rival 3 type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:184c class-ID: 0300
  Device-3: 5-3.4:11 info: SteelSeries ApS Apex Pro TKL type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:1614 class-ID: 0300
  Hub-7: 5-4:3 info: Texas Instruments TUSB2036 Hub ports: 3 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0451:2036
  Device-1: 5-4.2:7 info: SteelSeries ApS Arctis Pro Wireless type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:1290 class-ID: 0300
  Device-2: 5-4.3:8 info: SteelSeries ApS Arctis Pro Wireless
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 6
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 6-3:2 info: Realtek Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
    or lm-sensors.
  Packages: 1543 pm: pacman pkgs: 1533 libs: 425 tools: pamac pm: flatpak
    pkgs: 10
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    3: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    4: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    5: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    6: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    7: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 452
  1: cpu: 99.3% command: baloo_file_extractor pid: 1248 mem: 34.1 MiB (0.1%)
  2: cpu: 4.0% command: zsh pid: 328260 mem: 9.78 MiB (0.0%)
  3: cpu: 3.7% command: @lymouthd pid: 299 mem: 34.8 MiB (0.1%)
  4: cpu: 2.8% command: chrome pid: 2345 mem: 460.2 MiB (1.4%)
  5: cpu: 2.6% command: chrome pid: 2298 mem: 734.0 MiB (2.2%)
  Memory top: 5 of 452
  1: mem: 1211.1 MiB (3.7%) command: firefox pid: 1851 cpu: 2.4%
  2: mem: 878.8 MiB (2.7%) command: plasmashell pid: 933 cpu: 0.1%
  3: mem: 752.3 MiB (2.3%) command: electron pid: 11775 cpu: 0.1%
  4: mem: 734.0 MiB (2.2%) command: chrome pid: 2298 cpu: 2.6%
  5: mem: 503.1 MiB (1.5%) command: node pid: 7305 cpu: 0.0%
  Processes: 452 Power: uptime: 2d 41m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.51 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.38
I had a similar issue. Downgrading the drivers fixed it, although I realize that’s not ideal.
@jmac - thank you so much for hitting me up on this thread. It has been very hard to search for for this topic around the interwebs. :slight_smile:
So… Downgrading the nvidia drivers is the present answer? Yuck, but c’est la vie! I’ll give it a go probably this weekend.
downgraded the Nvidia drivers by installing ‘nvidia-470xx-dkms’ and ‘nvidia-470xx-utils’
OK, So downgrading to nvidia-470xx did not work for me. In fact, neither the open source nor 470 drivers would even turn on the display on reboot. I had to go with the proprietary latest ones. Why… Who knows.
But I finally had someone jog my brain! I never thought to try switching TTY. Lo-and-behold! Ctr+Alt+F3 brought back my screen! F1, F2, F4 didn’t do it, but F3 was it. But note, I have to switch to one of the other TTYs and then switch back to F3 for it to bring back the display.
Upgrading to the 580 driver (nvidia-dkms, nvidia-settings, nvidia-utils) appears to have fixed this issue for me.
My response to this, if it’s worth posting: Display fails to return after monitor turns off - #5 by jmac
No, did not fix for me. I believe I am on 590 driver and I still need to the Ctr+Alt+F3 TTY switching to get the display back.
Mod edit:- Please present inxi output as pre-formatted text according to forum guidelines. Images of textual content are generally unacceptable – image removed.
inxi -zv8 :point_down:
[MiniHowTo] Present code or command output
What is a Quark?
Please post more information about GPU drivers
mhwd -l; mhwd -li
response should be posted as preformatted text using </> button in reply box or Ctrl + E on keyboard
And do not post screenshots of text! Copy paste is invented long time ago! Next time the picture of text will disappear without warning.
Try changing your monitor refresh rate back to 60Hz and see if the problem continues.
We found a similar issue here: Monitor issues when monitor has been off and turns on again - Help - KDE Discuss
