Hello!
I have recently installed manjaro to work laptop. So far the experience has been awesome despite the fact that the laptop is with nvidia gpu). I have weird issue the laptop display cuts in half horizontally when I set the refresh rate to 60Hz. In 144Hr everything is okay. Here is info about the laptop:
Kernel: 6.9.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=d71aa18b-2f04-4c9b-8075-442f2b5190f3 rw quiet splash
resume=UUID=975da855-e7bc-448d-8032-0f292ce9d486 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA507RE_FA507RE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FA507RE v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA507RE.315
date: 11/30/2022
ID-1: BAT1 charge: 48.3 Wh (95.8%) condition: 50.4/55.9 Wh (90.2%)
volts: 16.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: discharging
System RAM: total: 16 GiB available: 14.87 GiB used: 10.53 GiB (70.8%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: MTC4C10163S1SC48BA1
serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M425R1GB4BB0-CQKOL serial: <filter>
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 691 high: 1350 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1325 2: 1313 3: 400
4: 400 5: 400 6: 400 7: 1336 8: 400 9: 400 10: 400 11: 1343 12: 400 13: 400
14: 400 15: 1350 16: 400 bogomips: 102255
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate
ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx
mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 550.xx+ status: current (as of 2024-06;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: DP-9,HDMI-A-1,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: 05:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 55.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi,nouveau gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153c built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: nouveau device: 2 drv: swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 24.1.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.57 6.9.9-1-MANJARO) device-ID: 1002:1681 memory: 500 MiB
unified: no
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: ASUSTek C-Media Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 0b05:6208 class-ID: 0300
API: ALSA v: k6.9.9-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 34.23 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 43.9 C
scheme: GPT
ID-1: / raw-size: 460.28 GiB size: 451.99 GiB (98.20%) used: 30.67 GiB (6.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: d71aa18b-2f04-4c9b-8075-442f2b5190f3
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 034F-3C58
ID-1: swap-1 type: partition size: 16.36 GiB used: 3.56 GiB (21.7%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 975da855-e7bc-448d-8032-0f292ce9d486
Device-1: 1-4:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: fe01 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-2:5 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-3:3 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: ASUSTek C-Media Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 57.0 C mobo: 46.0 C gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): cpu: 0
Packages: pm: pacman pkgs: 1259 libs: 333 tools: pamac pm: flatpak pkgs: 0
1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.init7.net/manjaro/stable/$repo/$arch
4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
8: https://mirrors2.manjaro.org/stable/$repo/$arch
9: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
12: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
13: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
14: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
15: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
16: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
17: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
18: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
19: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
20: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
22: http://mirror.fcix.net/manjaro/stable/$repo/$arch
23: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
24: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
25: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://mirror.funami.tech/manjaro/stable/$repo/$arch
27: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
30: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
31: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
32: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
33: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
34: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
35: https://mirror.easyname.at/manjaro/stable/$repo/$arch
36: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
38: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
41: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
43: https://mirrors.manjaro.org/repo/stable/$repo/$arch
44: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 363
1: cpu: 300% command: ps pid: 116463 mem: 3.34 MiB (0.0%)
2: cpu: 14.9% command: java pid: 108185 mem: 1111.2 MiB (7.2%)
3: cpu: 8.3% command: firefox pid: 115025 mem: 240.0 MiB (1.5%)
4: cpu: 4.9% command: java pid: 59350 mem: 2375.2 MiB (15.5%)
5: cpu: 4.2% command: Xorg pid: 57968 mem: 249.8 MiB (1.6%)
Memory top: 5 of 363
1: mem: 2375.2 MiB (15.5%) command: java pid: 59350 cpu: 4.9%
2: mem: 1111.2 MiB (7.2%) command: java pid: 108185 cpu: 14.9%
3: mem: 707.4 MiB (4.6%) command: telegram-desktop pid: 114924 cpu: 1.6%
4: mem: 626.3 MiB (4.1%) command: firefox pid: 58691 cpu: 1.7%
5: mem: 402.6 MiB (2.6%) command: firefox pid: 89229 cpu: 1.4%
Processes: 363 Power: uptime: 1d 49m states: freeze,mem,disk suspend: s2idle
wakeups: 10 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 5.91 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
Worth to mention that this is X11 specific issue. There is no problem with Wayland but Wayland is not stable for me for now. I have decided to go with X11.
