Display bug, no signal
I had it happen with Display Port & HDMI. Maybe for a few weeks, but hardly at all. My monitor displays no signal when it happens. Some one said it happens to them in Wayland. I am not sure what I am using. What ever is used when Manjaro install.
Can you post some more information ?
Oh sorry, I am using X11 & No GPU driver. It rarely happens, it has happened when using DisplayPort & HDNI. Someone in another topic said they had it also under Wayland. It was posted by geckofish52 that read I recently started using Plasma Wayland on a fresh install and can confirm this has happened to me. A reboot seemed to fix it for the time being.
Ok sorry again for the wait, have a Xorg.og now.
[    52.402]
X.Org X Server 1.21.1.6
[    52.402] Current Operating System: Linux nicholas 5.15.91-1-MANJARO #1 SMP PREEMPT Wed Feb 1 12:03:19 UTC 2023 x86_64
[    52.402] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=37c124d3-4218-4e44-9637-25b2aa80cc95 rw quiet apparmor=1 security=apparmor resume=UUID=c325ee10-e031-4249-8b4b-fb2e5586abcb udev.log_priority=3
[    52.403]
[    52.403] Current version of pixman: 0.42.2
[    52.403] 	Before reporting problems, check http://wiki.x.org
[    52.403] Markers: (--) probed, (**) from config file, (==) default setting,
[    52.403] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb  9 10:39:08 2023
[    52.499] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    52.499] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    52.814] (==) No Layout section.  Using the first Screen section.
[    52.814] (==) No screen section available. Using defaults.
[    52.814] (**) |-->Screen "Default Screen Section" (0)
[    52.814] (**) |   |-->Monitor "<default monitor>"
[    52.815] (==) No monitor specified for screen "Default Screen Section".
[    52.815] (==) Automatically adding devices
[    52.815] (==) Automatically enabling devices
[    52.815] (==) Automatically adding GPU devices
[    52.815] (==) Automatically binding GPU devices
[    52.815] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    52.887] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[    52.887] 	Entry deleted from font path.
[    52.887] 	(Run 'mkfontdir' on "/usr/share/fonts/misc").
[    52.989] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    52.989] 	Entry deleted from font path.
[    52.989] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    52.989] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    52.989] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    52.989] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    52.989] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    52.989] (==) FontPath set to:
[    52.989] (==) ModulePath set to "/usr/lib/xorg/modules"
[    52.989] (II) The server relies on udev to provide the list of input devices.
[    52.989] (II) Module ABI versions:
[    52.989] 	X.Org ANSI C Emulation: 0.4
[    52.989] 	X.Org Video Driver: 25.2
[    52.989] 	X.Org XInput driver : 24.4
[    52.989] 	X.Org Server Extension : 10.0
[    52.990] (++) using VT number 7
[    52.990] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    52.991] (II) xfree86: Adding drm device (/dev/dri/card0)
[    52.991] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:29:00.0/drm/card0
[    53.001] (--) PCI:*(41@0:0:0) 10de:2489:3842:4663 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    53.001] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    53.001] (II) LoadModule: "glx"
[    53.107] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    53.461] (II) Module glx: vendor="X.Org Foundation"
[    53.461] 	compiled for 1.21.1.6, module version = 1.0.0
[    53.462] 	ABI class: X.Org Server Extension, version 10.0
[    53.463] (==) Matched modesetting as autoconfigured driver 0
[    53.463] (==) Matched fbdev as autoconfigured driver 1
[    53.463] (==) Matched vesa as autoconfigured driver 2
[    53.463] (==) Assigned the driver to the xf86ConfigLayout
[    53.463] (II) LoadModule: "modesetting"
[    53.465] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    53.522] (II) Module modesetting: vendor="X.Org Foundation"
[    53.522] 	compiled for 1.21.1.6, module version = 1.21.1
[    53.522] 	Module class: X.Org Video Driver
[    53.522] 	ABI class: X.Org Video Driver, version 25.2
[    53.522] (II) LoadModule: "fbdev"
[    53.526] (WW) Warning, couldn't open module fbdev
[    53.526] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    53.526] (II) LoadModule: "vesa"
[    53.526] (WW) Warning, couldn't open module vesa
[    53.526] (EE) Failed to load module "vesa" (module does not exist, 0)
[    53.526] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    53.540] (II) modeset(0): using drv /dev/dri/card0
[    53.540] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    53.540] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    53.540] (==) modeset(0): RGB weight 888
[    53.540] (==) modeset(0): Default visual is TrueColor
[    53.540] (II) Loading sub module "glamoregl"
[    53.540] (II) LoadModule: "glamoregl"
[    53.540] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    53.592] (II) Module glamoregl: vendor="X.Org Foundation"
[    53.592] 	compiled for 1.21.1.6, module version = 1.0.1
[    53.593] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    55.944] (II) modeset(0): Refusing to try glamor on llvmpipe
[    55.945] (II) modeset(0): glamor initialization failed
[    55.945] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[    55.945] (II) modeset(0): Double-buffered shadow updates: off
[    56.016] (II) modeset(0): Output DP-1 has no monitor section
[    56.086] (II) modeset(0): Output DP-2 has no monitor section
[    56.129] (II) modeset(0): Output DP-3 has no monitor section
[    56.131] (II) modeset(0): Output HDMI-1 has no monitor section
[    56.203] (II) modeset(0): EDID for output DP-1
[    56.273] (II) modeset(0): EDID for output DP-2
[    56.316] (II) modeset(0): EDID for output DP-3
[    56.316] (II) modeset(0): Manufacturer: AUS  Model: 3201  Serial#: 16843009
[    56.316] (II) modeset(0): Year: 2021  Week: 41
[    56.316] (II) modeset(0): EDID Version: 1.4
[    56.316] (II) modeset(0): Digital Display Input
[    56.316] (II) modeset(0): 10 bits per channel
[    56.316] (II) modeset(0): Digital interface is DisplayPort
[    56.316] (II) modeset(0): Max Image Size [cm]: horiz.: 70  vert.: 40
[    56.316] (II) modeset(0): Gamma: 2.20
[    56.316] (II) modeset(0): No DPMS capabilities specified
[    56.316] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[    56.316] (II) modeset(0): First detailed timing is preferred mode
[    56.316] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[    56.316] (II) modeset(0): Display is continuous-frequency
[    56.316] (II) modeset(0): redX: 0.679 redY: 0.316   greenX: 0.269 greenY: 0.643
[    56.316] (II) modeset(0): blueX: 0.144 blueY: 0.056   whiteX: 0.313 whiteY: 0.329
[    56.316] (II) modeset(0): Supported established timings:
[    56.316] (II) modeset(0): 720x400@70Hz
[    56.316] (II) modeset(0): 640x480@60Hz
[    56.316] (II) modeset(0): 640x480@67Hz
[    56.316] (II) modeset(0): 640x480@72Hz
[    56.316] (II) modeset(0): 640x480@75Hz
[    56.316] (II) modeset(0): 800x600@56Hz
[    56.316] (II) modeset(0): 800x600@60Hz
[    56.316] (II) modeset(0): 800x600@72Hz
[    56.316] (II) modeset(0): 800x600@75Hz
[    56.316] (II) modeset(0): 832x624@75Hz
[    56.316] (II) modeset(0): 1024x768@60Hz
[    56.316] (II) modeset(0): 1024x768@70Hz
[    56.316] (II) modeset(0): 1024x768@75Hz
[    56.316] (II) modeset(0): 1280x1024@75Hz
[    56.316] (II) modeset(0): Manufacturer's mask: 0
[    56.316] (II) modeset(0): Supported standard timings:
[    56.316] (II) modeset(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    56.316] (II) modeset(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    56.316] (II) modeset(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    56.316] (II) modeset(0): #3: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[    56.316] (II) modeset(0): Supported detailed timing:
[    56.316] (II) modeset(0): clock: 593.7 MHz   Image Size:  698 x 393 mm
[    56.316] (II) modeset(0): h_active: 2560  h_sync: 2568  h_sync_end 2600 h_blank_end 2672 h_border: 0
[    56.316] (II) modeset(0): v_active: 1440  v_sync: 1465  v_sync_end 1473 v_blanking: 1543 v_border: 0
[    56.316] (II) modeset(0): Ranges: V min: 48 V max: 144 Hz, H min: 223 H max: 223 kHz, PixClock max 595 MHz
[    56.316] (II) modeset(0): Monitor name: VG32AQL1A
[    56.316] (II) modeset(0): Serial No: MALMQS060204
[    56.316] (II) modeset(0): clock: 241.5 MHz   Image Size:  698 x 393 mm
[    56.316] (II) modeset(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[    56.316] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[    56.316] (II) modeset(0): clock: 497.8 MHz   Image Size:  698 x 393 mm
[    56.316] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1525 v_border: 0
[    56.316] (II) modeset(0): Number of EDID sections to follow: 1
[    56.316] (II) modeset(0): EDID (in hex):
[    56.316] (II) modeset(0): 	00ffffffffffff0006b3013201010101
[    56.316] (II) modeset(0): 	291f0104b54628781bced5ad5144a424
[    56.316] (II) modeset(0): 	0e5054bfef00714f81809500d1c00101
[    56.316] (II) modeset(0): 	010101010101eae70070a0a067500820
[    56.316] (II) modeset(0): 	9804ba892100001a000000fd003090df
[    56.316] (II) modeset(0): 	df3b010a202020202020000000fc0056
[    56.316] (II) modeset(0): 	47333241514c31410a202020000000ff
[    56.316] (II) modeset(0): 	004d414c4d51533036303230340a0163
[    56.316] (II) modeset(0): 	020335f14c10111213040e0f1d1e1f40
[    56.316] (II) modeset(0): 	3f2309070783010000e305e001e60607
[    56.316] (II) modeset(0): 	01737300e2006a6d1a00000201309000
[    56.316] (II) modeset(0): 	0000000000565e00a0a0a02950302035
[    56.316] (II) modeset(0): 	00ba892100001a6fc200a0a0a0555030
[    56.316] (II) modeset(0): 	203500ba892100001a00000000000000
[    56.316] (II) modeset(0): 	00000000000000000000000000000000
[    56.316] (II) modeset(0): 	00000000000000000000000000000089
[    56.316] (II) modeset(0): Not using default mode "2560x1440" (bad mode clock/interlace/doublescan)
[    56.316] (II) modeset(0): Printing probed modes for output DP-3
[    56.316] (II) modeset(0): Modeline "2560x1440"x120.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[    56.316] (II) modeset(0): Modeline "2560x1440"x60.0  469.12  2560 2584 2600 2640  1440 1441 1444 1481 doublescan +hsync -vsync (177.7 kHz d)
[    56.316] (II) modeset(0): Modeline "2560x1440"x60.0  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync (89.5 kHz d)
[    56.316] (II) modeset(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1440"x85.0  341.35  1920 2072 2288 2656  1440 1441 1444 1512 -hsync +vsync (128.5 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1440"x75.0  297.00  1920 2064 2288 2640  1440 1441 1444 1500 -hsync +vsync (112.5 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1440"x60.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1856x1392"x75.0  288.00  1856 1984 2208 2560  1392 1393 1396 1500 -hsync +vsync (112.5 kHz d)
[    56.316] (II) modeset(0): Modeline "1856x1392"x60.0  218.30  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[    56.316] (II) modeset(0): Modeline "1792x1344"x75.0  261.00  1792 1888 2104 2456  1344 1345 1348 1417 -hsync +vsync (106.3 kHz d)
[    56.316] (II) modeset(0): Modeline "1792x1344"x60.0  204.80  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[    56.316] (II) modeset(0): Modeline "2048x1152"x60.0  406.50  2048 2220 2444 2840  1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[    56.316] (II) modeset(0): Modeline "2048x1152"x60.0  302.50  2048 2072 2088 2128  1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[    56.316] (II) modeset(0): Modeline "2048x1152"x59.9  197.00  2048 2184 2400 2752  1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[    56.316] (II) modeset(0): Modeline "2048x1152"x59.9  156.75  2048 2096 2128 2208  1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1200"x59.9  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1200"x60.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1080"x60.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1080"x120.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x100.0  297.00  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (112.5 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x119.9  296.70  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (134.9 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x60.0  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    56.316] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    56.316] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x1200"x85.0  229.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (106.2 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x1200"x75.0  202.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (93.8 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x1200"x70.0  189.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (87.5 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x1200"x65.0  175.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    56.316] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    56.316] (II) modeset(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[    56.316] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x900"x60.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x900"x59.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    56.316] (II) modeset(0): Modeline "1280x1024"x85.0  157.50  1280 1344 1504 1728  1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[    56.316] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    56.316] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    56.316] (II) modeset(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    56.316] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    56.316] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x960"x85.0  148.50  1280 1344 1504 1728  960 961 964 1011 +hsync +vsync (85.9 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    56.317] (II) modeset(0): Modeline "1440x810"x60.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    56.317] (II) modeset(0): Modeline "1440x810"x60.0  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    56.317] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    56.317] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x800"x60.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x800"x60.0  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    56.317] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    56.317] (II) modeset(0): Modeline "1280x720"x60.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x720"x60.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    56.317] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    56.317] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    56.317] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    56.317] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    56.317] (II) modeset(0): Modeline "1440x576"x50.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    56.317] (II) modeset(0): Modeline "1024x768"x85.0  194.02  1024 1108 1220 1416  768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x768"x75.0  170.24  1024 1108 1220 1416  768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x768"x60.0  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x768"x85.0   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync (68.7 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    56.317] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    56.317] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    56.317] (II) modeset(0): Modeline "1024x768i"x87.0   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[    56.317] (II) modeset(0): Modeline "960x720"x85.0  170.68  960 1036 1144 1328  720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[    56.317] (II) modeset(0): Modeline "960x720"x75.0  148.50  960 1032 1144 1320  720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[    56.317] (II) modeset(0): Modeline "960x720"x60.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    56.317] (II) modeset(0): Modeline "1440x480"x60.0   54.05  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    56.317] (II) modeset(0): Modeline "1440x480"x59.9   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    56.317] (II) modeset(0): Modeline "928x696"x75.0  144.00  928 992 1104 1280  696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[    56.317] (II) modeset(0): Modeline "928x696"x60.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    56.317] (II) modeset(0): Modeline "896x672"x75.0  130.50  896 944 1052 1228  672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[    56.317] (II) modeset(0): Modeline "896x672"x60.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x576"x60.0   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x576"x60.0   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    56.317] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    56.317] (II) modeset(0): Modeline "960x600"x59.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    56.317] (II) modeset(0): Modeline "960x600"x60.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    56.317] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    56.317] (II) modeset(0): Modeline "960x540"x60.0   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    56.317] (II) modeset(0): Modeline "960x540"x60.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    56.317] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    56.317] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x85.0  114.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x75.0  101.25  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x70.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x65.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x60.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x85.1   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync (53.7 kHz d)
[    56.317] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    56.317] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    56.317] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    56.317] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    56.317] (II) modeset(0): Modeline "840x525"x60.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    56.317] (II) modeset(0): Modeline "840x525"x59.9   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    56.317] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    56.317] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    56.317] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    56.317] (II) modeset(0): Modeline "700x525"x74.8   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[    56.317] (II) modeset(0): Modeline "700x525"x60.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    56.317] (II) modeset(0): Modeline "800x450"x59.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    56.317] (II) modeset(0): Modeline "800x450"x59.8   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    56.317] (II) modeset(0): Modeline "640x512"x85.0   78.75  640 672 752 864  512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[    56.317] (II) modeset(0): Modeline "640x512"x75.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[    56.317] (II) modeset(0): Modeline "640x512"x60.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    56.317] (II) modeset(0): Modeline "700x450"x60.0   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    56.317] (II) modeset(0): Modeline "700x450"x59.9   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    56.317] (II) modeset(0): Modeline "640x480"x85.1   74.25  640 672 752 864  480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[    56.317] (II) modeset(0): Modeline "640x480"x60.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    56.317] (II) modeset(0): Modeline "640x480"x85.0   36.00  640 696 752 832  480 481 484 509 -hsync -vsync (43.3 kHz d)
[    56.317] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    56.317] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    56.317] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz d)
[    56.317] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    56.317] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    56.317] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    56.317] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    56.317] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    56.317] (II) modeset(0): Modeline "720x400"x85.0   35.50  720 756 828 936  400 401 404 446 -hsync +vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    56.317] (II) modeset(0): Modeline "684x384"x59.9   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    56.317] (II) modeset(0): Modeline "684x384"x59.9   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    56.317] (II) modeset(0): Modeline "640x400"x59.9   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    56.317] (II) modeset(0): Modeline "640x400"x60.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    56.317] (II) modeset(0): Modeline "640x400"x85.1   31.50  640 672 736 832  400 401 404 445 -hsync +vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "576x432"x75.0   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[    56.317] (II) modeset(0): Modeline "640x360"x59.9   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    56.317] (II) modeset(0): Modeline "640x360"x59.8   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    56.317] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    56.317] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    56.317] (II) modeset(0): Modeline "640x350"x85.1   31.50  640 672 736 832  350 382 385 445 +hsync -vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "512x384"x85.0   47.25  512 536 584 688  384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[    56.317] (II) modeset(0): Modeline "512x384"x75.0   39.38  512 520 568 656  384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[    56.317] (II) modeset(0): Modeline "512x384"x70.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[    56.317] (II) modeset(0): Modeline "512x384"x60.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    56.317] (II) modeset(0): Modeline "512x384i"x87.1   22.45  512 516 604 632  384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[    56.317] (II) modeset(0): Modeline "512x288"x60.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    56.317] (II) modeset(0): Modeline "512x288"x59.9   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    56.317] (II) modeset(0): Modeline "416x312"x74.7   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[    56.317] (II) modeset(0): Modeline "480x270"x59.6   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    56.317] (II) modeset(0): Modeline "480x270"x59.8   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    56.317] (II) modeset(0): Modeline "400x300"x85.3   28.15  400 416 448 524  300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[    56.317] (II) modeset(0): Modeline "400x300"x72.2   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[    56.317] (II) modeset(0): Modeline "400x300"x75.1   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[    56.317] (II) modeset(0): Modeline "400x300"x60.3   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "400x300"x56.3   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    56.317] (II) modeset(0): Modeline "432x243"x59.9   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    56.317] (II) modeset(0): Modeline "432x243"x59.6   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    56.317] (II) modeset(0): Modeline "320x240"x85.2   18.00  320 348 376 416  240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[    56.317] (II) modeset(0): Modeline "320x240"x72.8   15.75  320 332 352 416  240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "320x240"x75.0   15.75  320 328 360 420  240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[    56.317] (II) modeset(0): Modeline "320x240"x60.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    56.317] (II) modeset(0): Modeline "360x202"x59.5   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    56.317] (II) modeset(0): Modeline "360x202"x59.1   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    56.317] (II) modeset(0): Modeline "360x200"x85.0   17.75  360 378 414 468  200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "320x200"x85.3   15.75  320 336 368 416  200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[    56.317] (II) modeset(0): Modeline "320x180"x59.8    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    56.317] (II) modeset(0): Modeline "320x180"x59.3    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    56.317] (II) modeset(0): Modeline "320x175"x85.3   15.75  320 336 368 416  175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[    56.318] (II) modeset(0): EDID for output HDMI-1
[    56.318] (II) modeset(0): Output DP-1 disconnected
[    56.318] (II) modeset(0): Output DP-2 disconnected
[    56.318] (II) modeset(0): Output DP-3 connected
[    56.318] (II) modeset(0): Output HDMI-1 disconnected
[    56.318] (II) modeset(0): Using exact sizes for initial modes
[    56.318] (II) modeset(0): Output DP-3 using initial mode 2560x1440 +0+0
[    56.318] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    56.318] (==) modeset(0): DPI set to (96, 96)
[    56.318] (II) Loading sub module "fb"
[    56.318] (II) LoadModule: "fb"
[    56.318] (II) Module "fb" already built-in
[    56.318] (II) Loading sub module "shadow"
[    56.318] (II) LoadModule: "shadow"
[    56.318] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    56.331] (II) Module shadow: vendor="X.Org Foundation"
[    56.331] 	compiled for 1.21.1.6, module version = 1.1.0
[    56.331] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    56.337] (==) modeset(0): Backing store enabled
[    56.338] (==) modeset(0): Silken mouse enabled
[    56.348] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    56.348] (==) modeset(0): DPMS enabled
[    56.348] (II) Initializing extension Generic Event Extension
[    56.348] (II) Initializing extension SHAPE
[    56.348] (II) Initializing extension MIT-SHM
[    56.348] (II) Initializing extension XInputExtension
[    56.355] (II) Initializing extension XTEST
[    56.355] (II) Initializing extension BIG-REQUESTS
[    56.355] (II) Initializing extension SYNC
[    56.355] (II) Initializing extension XKEYBOARD
[    56.355] (II) Initializing extension XC-MISC
[    56.355] (II) Initializing extension SECURITY
[    56.356] (II) Initializing extension XFIXES
[    56.356] (II) Initializing extension RENDER
[    56.356] (II) Initializing extension RANDR
[    56.356] (II) Initializing extension COMPOSITE
[    56.356] (II) Initializing extension DAMAGE
[    56.356] (II) Initializing extension MIT-SCREEN-SAVER
[    56.356] (II) Initializing extension DOUBLE-BUFFER
[    56.356] (II) Initializing extension RECORD
[    56.356] (II) Initializing extension DPMS
[    56.356] (II) Initializing extension Present
[    56.357] (II) Initializing extension DRI3
[    56.357] (II) Initializing extension X-Resource
[    56.357] (II) Initializing extension XVideo
[    56.357] (II) Initializing extension XVideo-MotionCompensation
[    56.357] (II) Initializing extension GLX
[    56.357] (II) AIGLX: Screen 0 is not DRI2 capable
[    56.361] (II) IGLX: Loaded and initialized swrast
[    56.361] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    56.361] (II) Initializing extension XFree86-VidModeExtension
[    56.362] (II) Initializing extension XFree86-DGA
[    56.362] (II) Initializing extension XFree86-DRI
[    56.362] (II) Initializing extension DRI2
[    56.362] (II) modeset(0): Damage tracking initialized
[    56.362] (II) modeset(0): Setting screen physical size to 677 x 381
[    56.672] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    56.672] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    56.672] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    56.672] (**) Power Button: Applying InputClass "system-keyboard"
[    56.672] (II) LoadModule: "libinput"
[    56.673] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    56.903] (II) Module libinput: vendor="X.Org Foundation"
[    56.903] 	compiled for 1.21.1.3, module version = 1.2.1
[    56.903] 	Module class: X.Org XInput Driver
[    56.903] 	ABI class: X.Org XInput driver, version 24.4
[    56.903] (II) Using input driver 'libinput' for 'Power Button'
[    56.903] (**) Power Button: always reports core events
[    56.903] (**) Option "Device" "/dev/input/event1"
[    57.181] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    57.181] (II) event1  - Power Button: device is a keyboard
[    57.182] (II) event1  - Power Button: device removed
[    57.210] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    57.210] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    57.210] (**) Option "xkb_layout" "us"
[    57.211] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    57.212] (II) event1  - Power Button: device is a keyboard
[    57.213] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    57.213] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    57.213] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    57.213] (**) Power Button: Applying InputClass "system-keyboard"
[    57.213] (II) Using input driver 'libinput' for 'Power Button'
[    57.213] (**) Power Button: always reports core events
[    57.213] (**) Option "Device" "/dev/input/event0"
[    57.214] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    57.214] (II) event0  - Power Button: device is a keyboard
[    57.214] (II) event0  - Power Button: device removed
[    57.263] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    57.263] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    57.263] (**) Option "xkb_layout" "us"
[    57.264] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    57.265] (II) event0  - Power Button: device is a keyboard
[    57.266] (II) config/udev: Adding input device Logitech Gamepad F310 (/dev/input/event20)
[    57.266] (II) No input driver specified, ignoring this device.
[    57.266] (II) This device may have been added with another device file.
[    57.267] (II) config/udev: Adding input device Logitech Gamepad F310 (/dev/input/js0)
[    57.267] (II) No input driver specified, ignoring this device.
[    57.267] (II) This device may have been added with another device file.
[    57.268] (II) config/udev: Adding input device SEMICO USB Keyboard (/dev/input/event2)
[    57.269] (**) SEMICO USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    57.269] (**) SEMICO USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    57.269] (**) SEMICO USB Keyboard: Applying InputClass "system-keyboard"
[    57.269] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard'
[    57.269] (**) SEMICO USB Keyboard: always reports core events
[    57.269] (**) Option "Device" "/dev/input/event2"
[    57.271] (II) event2  - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[    57.271] (II) event2  - SEMICO USB Keyboard: device is a keyboard
[    57.271] (II) event2  - SEMICO USB Keyboard: device removed
[    57.303] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.0/0003:1A2C:4B61.0001/input/input2/event2"
[    57.303] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard" (type: KEYBOARD, id 8)
[    57.303] (**) Option "xkb_layout" "us"
[    57.306] (II) event2  - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[    57.306] (II) event2  - SEMICO USB Keyboard: device is a keyboard
[    57.308] (II) config/udev: Adding input device SEMICO USB Keyboard Consumer Control (/dev/input/event3)
[    57.308] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    57.308] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    57.308] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    57.308] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard Consumer Control'
[    57.308] (**) SEMICO USB Keyboard Consumer Control: always reports core events
[    57.308] (**) Option "Device" "/dev/input/event3"
[    57.311] (II) event3  - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    57.311] (II) event3  - SEMICO USB Keyboard Consumer Control: device is a keyboard
[    57.311] (II) event3  - SEMICO USB Keyboard Consumer Control: device removed
[    57.343] (II) libinput: SEMICO USB Keyboard Consumer Control: needs a virtual subdevice
[    57.343] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input3/event3"
[    57.343] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard Consumer Control" (type: MOUSE, id 9)
[    57.343] (**) Option "AccelerationScheme" "none"
[    57.343] (**) SEMICO USB Keyboard Consumer Control: (accel) selected scheme none/0
[    57.343] (**) SEMICO USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[    57.343] (**) SEMICO USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[    57.346] (II) event3  - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    57.346] (II) event3  - SEMICO USB Keyboard Consumer Control: device is a keyboard
[    57.348] (II) config/udev: Adding input device SEMICO USB Keyboard System Control (/dev/input/event4)
[    57.348] (**) SEMICO USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    57.348] (**) SEMICO USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    57.348] (**) SEMICO USB Keyboard System Control: Applying InputClass "system-keyboard"
[    57.348] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard System Control'
[    57.348] (**) SEMICO USB Keyboard System Control: always reports core events
[    57.348] (**) Option "Device" "/dev/input/event4"
[    57.350] (II) event4  - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[    57.350] (II) event4  - SEMICO USB Keyboard System Control: device is a keyboard
[    57.351] (II) event4  - SEMICO USB Keyboard System Control: device removed
[    57.383] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input4/event4"
[    57.383] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard System Control" (type: KEYBOARD, id 10)
[    57.383] (**) Option "xkb_layout" "us"
[    57.386] (II) event4  - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[    57.386] (II) event4  - SEMICO USB Keyboard System Control: device is a keyboard
[    57.388] (II) config/udev: Adding input device SEMICO USB Keyboard (/dev/input/event5)
[    57.388] (**) SEMICO USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    57.388] (**) SEMICO USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    57.388] (**) SEMICO USB Keyboard: Applying InputClass "system-keyboard"
[    57.388] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard'
[    57.388] (**) SEMICO USB Keyboard: always reports core events
[    57.388] (**) Option "Device" "/dev/input/event5"
[    57.390] (II) event5  - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[    57.390] (II) event5  - SEMICO USB Keyboard: device is a keyboard
[    57.390] (II) event5  - SEMICO USB Keyboard: device removed
[    57.423] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input6/event5"
[    57.423] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard" (type: KEYBOARD, id 11)
[    57.423] (**) Option "xkb_layout" "us"
[    57.426] (II) event5  - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[    57.426] (II) event5  - SEMICO USB Keyboard: device is a keyboard
[    57.428] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/event6)
[    57.428] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Applying InputClass "evdev pointer catchall"
[    57.428] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Applying InputClass "libinput pointer catchall"
[    57.428] (II) Using input driver 'libinput' for 'Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)'
[    57.428] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): always reports core events
[    57.428] (**) Option "Device" "/dev/input/event6"
[    57.485] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): is tagged by udev as: Mouse
[    57.485] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): device is a pointer
[    57.486] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): device removed
[    57.543] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6:1.0/0003:045E:0039.0003/input/input7/event6"
[    57.543] (II) XINPUT: Adding extended input device "Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)" (type: MOUSE, id 12)
[    57.543] (**) Option "AccelerationScheme" "none"
[    57.543] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) selected scheme none/0
[    57.543] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration factor: 2.000
[    57.543] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration threshold: 4
[    57.602] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): is tagged by udev as: Mouse
[    57.602] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): device is a pointer
[    57.604] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/mouse0)
[    57.604] (II) No input driver specified, ignoring this device.
[    57.604] (II) This device may have been added with another device file.
[    57.605] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[    57.605] (II) No input driver specified, ignoring this device.
[    57.605] (II) This device may have been added with another device file.
[    57.606] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[    57.606] (II) No input driver specified, ignoring this device.
[    57.606] (II) This device may have been added with another device file.
[    57.606] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[    57.607] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[    57.607] (II) No input driver specified, ignoring this device.
[    57.607] (II) This device may have been added with another device file.
[    57.608] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[    57.608] (II) No input driver specified, ignoring this device.
[    57.608] (II) This device may have been added with another device file.
[    57.608] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event14)
[    57.609] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[    57.609] (II) No input driver specified, ignoring this device.
[    57.609] (II) This device may have been added with another device file.
[    57.610] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event15)
[    57.610] (II) No input driver specified, ignoring this device.
[    57.610] (II) This device may have been added with another device file.
[    57.610] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event16)
[    57.611] (II) No input driver specified, ignoring this device.
[    57.611] (II) This device may have been added with another device file.
[    57.611] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[    57.612] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event18)
[    57.612] (II) No input driver specified, ignoring this device.
[    57.612] (II) This device may have been added with another device file.
[    57.613] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event19)
[    57.613] (II) No input driver specified, ignoring this device.
[    57.613] (II) This device may have been added with another device file.
[    57.613] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    57.624] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    57.625] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    57.625] (**) SEMICO USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    57.625] (II) Using input driver 'libinput' for 'SEMICO USB Keyboard Consumer Control'
[    57.625] (**) SEMICO USB Keyboard Consumer Control: always reports core events
[    57.625] (**) Option "Device" "/dev/input/event3"
[    57.625] (II) libinput: SEMICO USB Keyboard Consumer Control: is a virtual subdevice
[    57.625] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input3/event3"
[    57.625] (II) XINPUT: Adding extended input device "SEMICO USB Keyboard Consumer Control" (type: KEYBOARD, id 13)
[    57.625] (**) Option "xkb_layout" "us"
[    63.559] (II) modeset(0): Disabling kernel dirty updates, not required.
[    75.950] (EE) event2  - SEMICO USB Keyboard: client bug: event processing lagging behind by 22ms, your system is too slow
[    83.959] (II) modeset(0): EDID vendor "AUS", prod id 12801
[    83.959] (II) modeset(0): Using EDID range info for horizontal sync
[    83.959] (II) modeset(0): Using EDID range info for vertical refresh
[    83.959] (II) modeset(0): Printing DDC gathered Modelines:
[    83.959] (II) modeset(0): Modeline "2560x1440"x0.0  593.70  2560 2568 2600 2672  1440 1465 1473 1543 +hsync -vsync (222.2 kHz eP)
[    83.959] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[    83.959] (II) modeset(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[    83.959] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    83.959] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    83.959] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    83.959] (II) modeset(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    83.959] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    83.959] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2448 2492 2640  1080 1084 1094 1125 +hsync +vsync (112.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[    83.959] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    83.959] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    83.959] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    83.959] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    83.959] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    83.959] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    83.959] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    83.959] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    83.959] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    83.959] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    83.959] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    83.959] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    83.959] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    83.959] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    83.959] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    84.146] (II) modeset(0): EDID vendor "AUS", prod id 12801
[    84.146] (II) modeset(0): Using hsync ranges from config file
[    84.146] (II) modeset(0): Using vrefresh ranges from config file
[    84.146] (II) modeset(0): Printing DDC gathered Modelines:
[    84.146] (II) modeset(0): Modeline "2560x1440"x0.0  593.70  2560 2568 2600 2672  1440 1465 1473 1543 +hsync -vsync (222.2 kHz eP)
[    84.146] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[    84.146] (II) modeset(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[    84.146] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    84.146] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    84.146] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    84.146] (II) modeset(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    84.146] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    84.146] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2448 2492 2640  1080 1084 1094 1125 +hsync +vsync (112.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[    84.146] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    84.146] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    84.146] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    84.146] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    84.146] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    84.146] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    84.146] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    84.146] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    84.146] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    84.146] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    84.146] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    84.146] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    84.146] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    84.146] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    84.146] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    84.335] (II) modeset(0): EDID vendor "AUS", prod id 12801
[    84.336] (II) modeset(0): Using hsync ranges from config file
[    84.336] (II) modeset(0): Using vrefresh ranges from config file
[    84.336] (II) modeset(0): Printing DDC gathered Modelines:
[    84.336] (II) modeset(0): Modeline "2560x1440"x0.0  593.70  2560 2568 2600 2672  1440 1465 1473 1543 +hsync -vsync (222.2 kHz eP)
[    84.336] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[    84.336] (II) modeset(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[    84.336] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    84.336] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    84.336] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    84.336] (II) modeset(0): Modeline "1440x480"x0.0   54.00  1440 1472 1596 1716  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1440x576"x0.0   54.00  1440 1464 1592 1728  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    84.336] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    84.336] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2448 2492 2640  1080 1084 1094 1125 +hsync +vsync (112.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[    84.336] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    84.336] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    84.336] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    84.336] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    84.336] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    84.336] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    84.336] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    84.336] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    84.336] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    84.336] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    84.336] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    84.336] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    84.336] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    84.336] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    84.336] (II) modeset(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[  1098.735] (II) event6  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Enabling spurious button debouncing, see https://wayland.freedesktop.org/libinput/doc/1.22.1/button-debouncing.html for details
Sorry for the length.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
