Hello, every couple of months i have the same space issue after some large updates, so I always run
sudo pacman -Sc
and it always cleans up cache which gives some extra gb.
My question is, is there any other command to free up more space?
THanks!
Hanzel
2
If your log is to large, this is a option.
Remove some packages you don’t need?
Not on my Manjaro - but from memory - something like
sudo journalctl --vaccum 50M
cscs
4
Thanks i have deleted a lot in Journal, now I still have this two, I will keep reading it to free up even more.
Regards
