I have an error like this, and i have done to insert variable radeon.runpm=1 (or 0 ) in /etc/default/grub and also DRI_PRIME=1 in /etc/environment but result keep get error like this :
[ 322.493763] [drm] PCIE gen 2 link speeds already enabled
[ 322.508218] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 322.508382] radeon 0000:03:00.0: WB enabled
[ 322.508387] radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
[ 322.508391] radeon 0000:03:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
[ 322.508395] radeon 0000:03:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
[ 322.508398] radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
[ 322.508400] radeon 0000:03:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
[ 322.509060] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[ 322.509067] debugfs: File 'radeon_ring_cp1' in directory '0' already present!
[ 322.509070] debugfs: File 'radeon_ring_cp2' in directory '0' already present!
[ 322.509074] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[ 322.509077] debugfs: File 'radeon_ring_dma2' in directory '0' already present!
[ 322.708874] [drm] ring test on 0 succeeded in 1 usecs
[ 322.708882] [drm] ring test on 1 succeeded in 1 usecs
[ 322.708888] [drm] ring test on 2 succeeded in 1 usecs
[ 322.708897] [drm] ring test on 3 succeeded in 4 usecs
[ 322.708905] [drm] ring test on 4 succeeded in 4 usecs
[ 323.711765] [drm:r600_ib_test [radeon]] *ERROR* radeon: fence wait timed out.
[ 323.711862] [drm:radeon_ib_ring_tests [radeon]] *ERROR* radeon: failed testing IB on GFX ring (-110).
[ 323.711941] [drm:radeon_resume_kms [radeon]] *ERROR* ib ring test failed (-110).
And i found the solution in this link address DRI_PRIME regression- radeon: Failed to allocate virtual address for buffer (#821) · Issues · drm / amd · GitLab but i can not use that patch in new kernel .
Please help
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text. Also, the link was wrong…
Hello @crashtitude
Since you mentioned ACPI, can you rule out that your BIOS/UEFI/FIRMWARE is not updated to the latest version?
inxi -Mazy
Hello Bro, thankyou for reply
Here :
Type: Laptop System: LENOVO product: 20369 v: Lenovo G40-70
serial: <superuser required> Chassis: type: 10 v: Lenovo G40-70
Mobo: LENOVO model: Lancer 4A2 v: NANANANANO DPK
serial: <superuser required> UEFI: LENOVO v: 9ACN32WW date: 07/20/2015
ok from what I see it is the latest firmware. Explain please when does this happen? I assume it happens when you suspend and wake up the laptop while it utilize with the radeon gpu?
Btw:
That is bad advice. Use xrandr instead or just add it per application.
This happen when im booting, and i see that in dmesg here link
(https://pastebin.com/3Mbi73A3)
$ DRI_PRIME=1 inxi -Ga ✔
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
class-ID: 0300
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 03:00.0
chip-ID: 1002:666f class-ID: 0380 temp: 55.0 C
Device-3: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:5 chip-ID: 5986:055d
class-ID: 0e02 serial: 200901010001
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display 0x05f0 built: 2014 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: OpenGL v: N/A renderer: N/A direct-render: N/A
$ DRI_PRIME=1 glxinfo -B ✔ 3s
name of display: :0
radeon: Failed to allocate virtual address for buffer:
radeon: size : 65536 bytes
radeon: alignment : 4096 bytes
radeon: domains : 4
radeon: va : 0x0000000100000000
radeon: Failed to deallocate virtual address for buffer:
radeon: va : 0x100000000
radeon: domains : 4
radeonsi: can't create border_color_buffer
radeonsi: Failed to create a context.
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 68
Current serial number in output stream: 69
hi loll im actually having the same problem for weeks i actually had to reinstall everything
Yea, this a trouble all of discrete graphic to old hardware . What your device ?
Ah I see. So on old machines it can take some time to initialize the dgpu, then you get a 110 timeout error.
A possible workaround would be adding the radeon driver to the kernel image. So add it to MODULES in /etc/mkinitcpio.conf, run mkinitcpio -P and reboot. That would load the driver early and reduce the wait time. So in your case:
MODULES=(i915 radeon)
and of course disable any option in BIOS/UEFI which will skip initialization steps for speed up like fastboot: full initialization needed.
No , im creating this post to fix radeon render . I have done to insert
Not fix any else solution ?? I want to use radeon for render application not mesa.
Both i915 and radeon use mesa, there is no “radeon renderer”. But that is not the problem. There is a timeout of the driver/UEFI/GPU problem as said.
And how about this ? Any idea ?
name of display: :0
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
radeon: domains : 4
That is the result of the timeout. I literally mean: can’t interact, and the kernel messages describe what is the problem: timeout. Try a different kernel, an older one, or maybe try amdgpu which has rather experimental support for your GCN1 card.
There is new kernel made by manjaro team, i will try and if get same error i will trying to recreate kernel. Thanks
