I can’t get this to update.
Don’t know where to find out what is wrong.
Don’t use Discover for updating your system, or even individual packages. Use pacman
or pamac
, or possibly yay
My system is updated with pacman and this package doesn’t come up in the list to be updated or I am doing something wrong.
We used to package it before Arch did and our version appears “newer” than the current version.
0.5-1 is the latest version, just reinstall it to update:
sudo pacman -Syu kirigami-addons
So I did that.
Is Discover wrong showing that there is an update?
Is reinstalling the normal to update this or other packages?
Technically no, because 1:0.1-1 is a higher version number than 0.5-1 since the former has an epoch. However, there never should have been one.
No, this is a rare, unique case.
I’m sorry so a couple of more questions.
Is there a way to stop Discover from showing these updates?
I have noticed that Discover shows some updates that pacman doesn’t . Is this normal?
I believe one of those was a package called paperwork.
Thanks
Yes there is a way to stop Discover from showing these updates, don’t use it. Use the distro’s recommended package mangers pamac and pacman
That’s actually good advice. Discover uses PackageKit:
Warning: PackageKit opens up system permissions by default, and is otherwise not recommended for general usage. See FS#50459 and FS#57943.
– pacman/Tips and tricks - ArchWiki
If you remove packagekit-qt5
, you can still use Discover for Flatpak and firmware updates, however.
It seems after removing packagekit-qt5
that kimi package no longer shows up to be updated with Discover.
Thanks for all of this information.
I will stop using discover .
Consider this solved.
