Hi guys, I’m having this issue when opened by error the gnome-terminal
(I use terminator)
Got this message before fastfetch loaded:
Summary
Thing is, how could I fix the message issue?
(I use terminator)
Looks like it might be something to do with gnome-keyring-daemon
7.5 Terminal gives the message “discover_other_daemon: 1” - GNOME/Keyring - ArchWiki
This is caused by gnome-keyring-daemon being started for the second time. Since a systemd service is delivered together with the daemon, you do not need to start it another way. So make sure to remove the start command from your
.zshenv
,.bash_profile
,.xinitrc
,config.fish
or similar. Alternatively you can disable thegnome-keyring-daemon.service
andgnome-keyring-daemon.socket
user units.
Thanks! Found the line in ~/.zshrc
and commented it:
# eval $(/usr/bin/gnome-keyring-daemon --start --components=pkcs11,secret,ssh)
