The version in the package manager is 0.0.13-0 yet I’m prompted when starting discord to install 0.0.14.
Discord won’t let you run the application until you’ve updated. Very annoying. When will the update be pushed through Manjaro? I need to use discord for work.
I don’t know why is not being updated still,but in the meantime you can download the update from the arch respositories,it will be the same version as Manjaros.
https://archlinux.org/packages/community/x86_64/discord/download/
Thanks, how do I install this?
Double click on the file,or if you prefered in the terminal
sudo pacman -U discord-0.0.14-1-x86_64.pkg.tar.zst
Thank you. You’ve been very helpful.
flatpaked discord has already updated
Discord v 0.0.14-1 was updated in Arch repository earlier today
Last Updated: 2021-03-24 01:13 UTC
Also available in Manjaro unstable branch - Branch Compare
It’s available in all branches now.
I believe discord has just been bought by microsoft…
It has been rumored to be in a deal. But I don’t think anything has been confirmed by any of the parties involved.
I stand corrected, I should have checked.
My point was that rumours of those talks might have dampened the enthusiasm of the package maintainers a little, at least temporarily.
I think it is more of a classic problem with how discord handles updates.
Thanks for the idea dude.
