I’m using the vesktop-bin
package from the AUR, I didn’t used to have this issue on my old system which funny enough had an Nvidia GPU with wayland.
When I login to plasma, vesktop (discord) starts and I can see the icon in the task manager bar. When I click on it, it is no where to be found. I tried restarting it and it still doesn’t show.
The trick I found to get it to show up is to right click on the preview and hit maximize then restart the app and it finally shows up maximized.
any ideas on what the issue may be? maybe discord isn’t being drawn on a desktop?
I’m on KDE Plasma with a wayland session and an AMD GPU.
inxi -F paste:
Host: vanishing-pc Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.3.5 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B850M DS3H v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F3
date: 03/12/2025
Info: 8-core model: AMD Ryzen 7 9700X bits: 64 type: MT MCP cache: L2: 8 MiB
Speed (MHz): avg: 3200 min/max: 600/5581 cores: 1: 3200 2: 3200 3: 3200
4: 3200 5: 3200 6: 3200 7: 3200 8: 3200 9: 3200 10: 3200 11: 3200 12: 3200
13: 3200 14: 3200 15: 3200 16: 3200
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [RX 9070/9070 XT]
driver: amdgpu v: kernel
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
compositor: kwin_wayland driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
1: 2560x1440~165Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
renderer: AMD Radeon Graphics (radeonsi gfx1201 ACO DRM 3.61
6.12.28-1-MANJARO)
API: Vulkan v: 1.4.313 drivers: radv surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio driver: snd_hda_intel
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.4.2 status: active
Device-1: Realtek RTL8125 2.5GbE driver: r8125
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: 10:ff:e0:83:18:27
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 2.27 TiB used: 136.78 GiB (5.9%)
ID-1: /dev/nvme0n1 vendor: PNY model: CS2241 1TB SSD size: 931.51 GiB
ID-2: /dev/nvme1n1 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
ID-3: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
ID-1: / size: 922.42 GiB used: 136.68 GiB (14.8%) fs: btrfs dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 776 KiB (0.3%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 922.42 GiB used: 136.68 GiB (14.8%) fs: btrfs
dev: /dev/dm-0
ID-4: /var/log size: 922.42 GiB used: 136.68 GiB (14.8%) fs: btrfs
dev: /dev/dm-0
ID-1: swap-1 type: partition size: 8.8 GiB used: 101.2 MiB (1.1%)
dev: /dev/dm-1
System Temperatures: cpu: 41.5 C mobo: 27.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 36.0 C device: amdgpu temp: 42.0 C fan: 2
Memory: total: 32 GiB note: est. available: 30.47 GiB used: 6.08 GiB (20.0%)
Processes: 407 Uptime: 12m Shell: Zsh inxi: 3.3.38
