Discord scales incorrectly on secondary display
When Discord is moved to my second display, it seems to shrink by about 25% and will shrink again and again if I click anywhere within or outside that application while within that second display. The mouse pointer also seems to be offset when trying to interact with any elements within that application. Discord also no longer remembers its window position when minimized/closed to system tray.
My assumption is these new behaviors are tied to a Discord update but thought I’d post here just in case.
inxi -SMGxxaz
  Kernel: 7.1.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
    root=UUID=9bfcfd19-2a1b-4d1a-8a0e-3a0716206131 rw
    cryptdevice=UUID=d4fb0d68-6837-441f-bcbd-9d3a6e2946ee:cryptroot:allow-discards
    root=/dev/mapper/cryptroot rd.luks.options=discard quiet splash
    udev.log_priority=3 nomodeset nvidia-drm.modeset=1 nvidia_drm.fbdev=1
    nvidia.NVreg_EnableGpuFirmware=0
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.28.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: AX370-Gaming K7 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AX370-Gaming K7 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: F51i date: 02/10/2023
  Device-1: Blackmagic Design DeckLink Mini Monitor 4K driver: blackmagic-io
    v: 16.1a3 alternate: blackmagic_io pcie: gen: 2 speed: 5 GT/s lanes: 4
    bus-ID: 07:00.0 chip-ID: bdbd:a144 class-ID: 0400
  Device-2: NVIDIA AD102 [GeForce RTX 4070 Ti SUPER] vendor: Micro-Star MSI
    driver: nvidia v: 610.57.04 alternate: nouveau,nvidia_drm
    non-free: 550-6xx.xx+ status: current (as of 2026-07) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-1,HDMI-A-1
    empty: DP-2,HDMI-A-2 bus-ID: 08:00.0 chip-ID: 10de:2689 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch d-rect: 5760x2160 display-ID: 0
  Monitor-1: DP-1 pos: primary,left model: Dell P2415Q serial: <filter>
    built: 2017 res: mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440
    dpi: 185 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
    ratio: 16:9 modes: max: 3840x2160 min: 640x480
  Monitor-2: HDMI-A-1 pos: right model: VSEVEN serial: <filter> built: 2021
    res: mode: 1920x1080 hz: 60 scale: 75% (0.75) to: 2560x1440 dpi: 93
    gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.57.04
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti
    SUPER/PCIe/SSE2 memory: 15.62 GiB display-ID: :0.0
  API: Vulkan v: 1.4.357 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 Ti SUPER driver: nvidia v: 610.57.04 device-ID: 10de:2689
    surfaces: N/A
    wl: wayland-info,wlr-randr x11: xdriinfo, xdpyinfo, xprop, xrandr
I believe this is known to happen when extending the desktop to monitors of different DPI.
If I recall correct - it has been a while since the issue was last mentioned - you can adjust the behaviour in System Settings → Display & Monitor
Change the setting regarding Legacy applications for the monitor in question.
I did try this to no avail unfortunately. The application window behavior is the same regardless of which option I use. Appreciate the suggestion nonetheless.
