Discord crashes: Failed fetching module discord_krisp
Yesterday I ran full system upgrade (which did upgrade some stuff) then closed discord, suspended the machine and today Discord crashes when starting.
Crash output
DiscordPtb 0.0.22
Starting app.
Starting updater.
[Modules] Modules initializing
[Modules] Distribution: remote
[Modules] Host updates: enabled
[Modules] Module updates: enabled
[Modules] Module install path: /home/tomas/.config/discordptb/0.0.22/modules
[Modules] Module installed file path: /home/tomas/.config/discordptb/0.0.22/modules/installed.json
[Modules] Module download path: /home/tomas/.config/discordptb/0.0.22/modules/pending
[Modules] No updates to install
[Modules] Checking for host updates.
[Modules] Host is up to date.
[Modules] Checking for module updates at https://discord.com/api/modules/ptb/versions.json
[Modules] No module updates available.
[Modules] Starting to install discord_krisp...
[Modules] Fetching discord_krisp@0 from https://discord.com/api/modules/ptb/discord_krisp/0
[Modules] Streaming discord_krisp@0 to /home/tomas/.config/discordptb/0.0.22/modules/pending/discord_krisp-0.zip
Error downloading with electron net: HTTP Error: Status Code 403
Falling back to node net library..
Failed to get crash dump id.
Report Id:
[Modules] Failed fetching module discord_krisp@0: Error: HTTP Error: Status Code 403
[Modules] Finished module downloads. [success: 0] [failure: 1]
[WebContents] crashed... reloading
[WebContents] double crashed... RIP =(
Happens for both discord from manjaro repository and AUR’s preview discord discord-ptb.
Have found this thread on reddit, two months old but someone made comments yesterday too, with one user pointing to arch forum thread [SOLVED] Discord crashes inmediately after start / Applications & Desktop Environments / Arch Linux Forums
where it seems that downgrading opera-ffmpeg-codecs to 85.0.4183.102-1 does the trick.
I got the same HTTP Error: Status Code 403, I uninstalled current version from Manjaro repo, and installed Discord from Flathub (you may need to activate it in pamac settings). That did the trick for me. Your mileage may wary.
https:// bugs. archlinux. org/task/68364 (it won’t let me post a link) indicates that this was fixed with discord 0.0.12-2 so manjaro just needs to upgrade their package.
