I have noticed that out of nowhere since yesterday my CPU temperatures were getting crazy even with 0% CPU load. Also, power consumption went crazy. CPU frequency was not that high though. So, I disabled intel_pstate by adding intel_pstate=disabled in /etc/default/grub file’s GRUB_CMDLINE_LINUX_DEFAULT line. This line looks like this in my system
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor resume=UU intel_pstate=disable>
Then updated grub and rebooted. This solved the issue I was facing. High CPU temps were gone. Power consumption was reasonable. But doing so broke Gnome Keyring. Gnome Keyring would not unlock. I tried rebooting multiple times. I tried to launch Password and Keys from the application menu and unlocking from there. But the unlock button does not work. At this point, I edited /etc/default/grub and removed intel_pstate=disable. Doing so fixed the Gnome Keyring issue. But it again made CPU temps and power consumption wild. What can I do in this situation?
Note: I have installed auto-cpufreq and howdy.
