Although I am using my USB mouse much less using i3, my touchpad on the laptop is too sensitive and acts up when my fingers are typing on the keyboard. I like to disable it completely and use USB mouse. Is there a simple command that will do this with libinput?, I would prefer not to install synaptic if possible. Editing 30-touchpad.conf to MatchIsTouchpad “off” does not seem to work.
[/code]
Section “InputClass”
Identifier “touchpad”
Driver “libinput”
MatchIsTouchpad “on”
Option “Tapping” “on”
EndSection
[code]
check if you can disable in UEFI/BIOS
Hi @gychang ,
Although I don’t use, or even have a laptop and thus no touchpad, I have found this post online that seem to describe the steps pretty well:
xinput
If you do not want or cannot use synclient, you could also use xinput
. The procedure is somewhat similar.
list all xinput devices: xinput
Part of the ouput could look like this:
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech USB-PS/2 Optical Mouse id=13 [slave pointer (2)]
⎜ ↳ ETPS/2 Elantech Touchpad id=17 [slave pointer (2)]
It this particular case my touchpad has id=17 and its full name is “ETPS/2 Elantech Touchpad”.
The command to set a property is xinput set-prop
. The property to enable or disable the touchpad is Device Enabled
, so to enable or disable it type:
Turn touchpad ON: xinput set-prop <id> "Device Enabled" 1
(where <id>
is your device id, in my case 17)
Turn touchpad OFF: xinput set-prop <id> "Device Enabled" 0
Turn palm detection ON: xinput set-prop <id> "Palm Detection" 1
Turn palm detection OFF: xinput set-prop <id> "Palm Detection" 0
To query available properties: xinput list-props <id>
OR xinput list-props <full-name>
, this should be quite similair to synclient -l
Links for further reading
ubuntu - wiki - input
NOTE
When setting properties through either xinput
or synclient
the properties are not set to the other tool. They are also not set in unity-control-center.
Hope this helps!
good idea!, unfortunately on my laptop no touchpad control…
system
Closed
17 June 2021 17:36
7
