Storm
1
Greetings,
As far my Panels have a thin layer of shadows at them. Is it possible to disable that shadow on the panels?
You can by using:
xprop -remove _KDE_NET_WM_SHADOW
as a startup script or run it manually.
Or try what our kind friend @cscs recommended in the archived forum at one point:
Storm
3
Thanks. It’s working. (Made a script).
system
Closed
4
